00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.descriptor.data; 00032 00033 import java.io.IOException; 00034 00035 import org.objectweb.proactive.core.descriptor.services.ServiceUser; 00036 import org.objectweb.proactive.core.descriptor.services.UniversalService; 00037 import org.objectweb.proactive.core.process.ExternalProcess; 00038 00039 00050 public interface VirtualMachine extends ServiceUser { 00051 00057 public void setNbNodes(String nodeNumber) throws java.io.IOException; 00058 00064 public String getNbNodesOnCreatedVMs(); 00065 00070 public void setName(String s); 00071 00076 public String getName(); 00077 00078 // /** 00079 // * Sets the acquisitionMethod field to the given value 00080 // * @param s 00081 // */ 00082 // public void setAcquisitionMethod(String s); 00083 // 00084 // /** 00085 // * Returns the AcquisitionMethod value 00086 // * @return String 00087 // */ 00088 // public String getAcquisitionMethod(); 00089 // /** 00090 // * Sets the port number of the acquisition process 00091 // * @param s 00092 // */ 00093 // public void setPortNumber(String s); 00094 // 00095 // /** 00096 // * Return the Acquisition port number 00097 // * @param s 00098 // */ 00099 // public String getPortNumber(); 00100 00105 public void setProcess(ExternalProcess p); 00106 00111 public ExternalProcess getProcess(); 00112 00117 public void setService(UniversalService service); 00118 00123 public UniversalService getService(); 00124 00130 public String getHostName(); 00131 00136 public void setCreatorId(String creatorId); 00137 00142 public String getCreatorId(); 00143 00149 public boolean hasProcess(); 00150 }
1.5.1
