00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.util;
00032
00033 import java.net.InetAddress;
00034 import java.net.UnknownHostException;
00035
00036 import org.apache.log4j.Logger;
00037 import org.objectweb.proactive.core.Constants;
00038 import org.objectweb.proactive.core.config.ProActiveConfiguration;
00039 import org.objectweb.proactive.core.util.log.Loggers;
00040 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00041
00042
00046 public class UrlBuilder {
00047     private static String[] LOCAL_URLS = {
00048             "///", "//localhost.localdomain", "//localhost", "//127.0.0.1"
00049         };
00050     private final static int DEFAULT_REGISTRY_PORT = 1099;
00051     static Logger logger = ProActiveLogger.getLogger(Loggers.UTIL);
00052
00053
00054
00055
00056     public UrlBuilder() {
00057     }
00058
00059
00060
00061
00062
00069     public static String checkUrl(String url)
00070         throws java.net.UnknownHostException {
00071         String protocol = getProtocol(url);
00072         String noProtocolUrl = internalCheck(removeProtocol(url, protocol));
00073         return readHostAndName(noProtocolUrl, protocol);
00074     }
00075
00076     public static String buildUrl(String host, String name, String protocol) {
00077         return buildUrl(host, name, protocol, DEFAULT_REGISTRY_PORT);
00078     }
00079
00088     public static String buildUrl(String host, String name, String protocol,
00089         int port) {
00090         protocol = checkProtocol(protocol);
00091         String noProtocolUrl = buildUrl(host, name, port);
00092         if (protocol.equals(Constants.DEFAULT_PROTOCOL_IDENTIFIER)) {
00093             return noProtocolUrl;
00094         } else {
00095             return protocol + noProtocolUrl;
00096         }
00097     }
00098
00107     public static String buildUrlFromProperties(String host, String name) {
00108         String port = null;
00109         String protocol = System.getProperty("proactive.communication.protocol");
00110         if (protocol.equals("rmi") || protocol.equals("ibis")) {
00111             port = System.getProperty("proactive.rmi.port");
00112         }
00113         if (protocol.equals("http")) {
00114             port = System.getProperty("proactive.http.port");
00115         }
00116         if (checkProtocol(protocol).equals("jini:") || (port == null)) {
00117             return buildUrl(host, name, protocol);
00118         } else {
00119             return buildUrl(host, name, protocol, new Integer(port).intValue());
00120         }
00121     }
00122
00123     public static String buildVirtualNodeUrl(String url)
00124         throws java.net.UnknownHostException {
00125         String vnName = getNameFromUrl(url);
00126         vnName = vnName.concat("_VN");
00127         String host = getHostNameFromUrl(url);
00128         String protocol = getProtocol(url);
00129         int port = getPortFromUrl(url);
00130         return buildUrl(host, vnName, protocol, port);
00131     }
00132
00133     public static String appendVnSuffix(String name) {
00134         return name.concat("_VN");
00135     }
00136
00137     public static String removeVnSuffix(String url) {
00138
00139         int index = url.lastIndexOf("_VN");
00140         if (index == -1) {
00141             return url;
00142         }
00143         return url.substring(0, index);
00144     }
00145
00151     public static String getNameFromUrl(String url) {
00152         int n = url.lastIndexOf("/");
00153         String name = url.substring(n + 1);
00154         return name;
00155     }
00156
00163     public static String getHostNameAndPortFromUrl(String url)
00164         throws UnknownHostException {
00165         String validUrl = checkUrl(url);
00166         int n = validUrl.indexOf("//");
00167         int m = validUrl.lastIndexOf("/");
00168         if (m == (n + 1)) {
00169
00170
00171             return validUrl.substring(n + 2, validUrl.length());
00172         } else {
00173
00174             return validUrl.substring(n + 2, m);
00175         }
00176     }
00177
00182     public static String getProtocol(String nodeURL) {
00183         if (nodeURL == null) {
00184             return Constants.DEFAULT_PROTOCOL_IDENTIFIER;
00185         }
00186         int n = nodeURL.indexOf("://");
00187         if (n <= 0) {
00188             return Constants.DEFAULT_PROTOCOL_IDENTIFIER;
00189         }
00190         return nodeURL.substring(0, n + 1);
00191     }
00192
00196     public static String removeProtocol(String url, String protocol) {
00197         protocol = checkProtocol(protocol);
00198         if (url.startsWith(protocol)) {
00199             return url.substring(protocol.length());
00200         }
00201         return url;
00202     }
00203
00204     public static String getHostNameFromUrl(String url)
00205         throws java.net.UnknownHostException {
00206         String validUrl = checkUrl(url);
00207         int n = validUrl.indexOf("//");
00208         int m = validUrl.lastIndexOf("/");
00209         if (m == (n + 1)) {
00210
00211
00212             return getHostFromUrl(validUrl.substring(n + 2, validUrl.length()));
00213         } else {
00214
00215             return getHostFromUrl(validUrl.substring(n + 2, m));
00216         }
00217     }
00218
00219     public static String checkProtocol(String protocol) {
00220         if (protocol.indexOf(":") == -1) {
00221             return protocol.concat(":");
00222         }
00223         return protocol;
00224     }
00225
00226     public static String removePortFromHost(String hostname) {
00227         int n = hostname.lastIndexOf(":");
00228         if (n > -1) {
00229             return hostname.substring(0, n);
00230         }
00231         return hostname;
00232     }
00233
00239     public static int getPortFromUrl(String url) {
00240         try {
00241             String validUrl = checkUrl(url);
00242             int n = validUrl.indexOf("//");
00243             int m = validUrl.lastIndexOf("/");
00244             if (m == (n + 1)) {
00245                 return getPortNumber(validUrl.substring(n + 2));
00246             } else {
00247                 return getPortNumber(validUrl.substring(n + 2, m));
00248             }
00249         } catch (java.net.UnknownHostException e) {
00250             logger.info("Cannot resolve hostname " + e.getMessage());
00251             int n = url.indexOf("//");
00252             int m = url.lastIndexOf("/");
00253             if (m == (n + 1)) {
00254                 return getPortNumber(url.substring(n + 2));
00255             } else {
00256                 return getPortNumber(url.substring(n + 2, m));
00257             }
00258         }
00259     }
00260
00261     public static String getHostNameorIP(InetAddress address) {
00262         if (System.getProperty("proactive.hostname") != null) {
00263             return System.getProperty("proactive.hostname");
00264         }
00265         if ("true".equals(System.getProperty("proactive.useIPaddress"))) {
00266             return address.getHostAddress();
00267         } else {
00268             return address.getCanonicalHostName();
00269         }
00270     }
00271
00272     public static String removeUsername(String url) {
00273
00274
00275         int index = url.indexOf("@");
00276
00277         if (index >= 0) {
00278             String username = url.substring(0, index);
00279             url = url.substring(index + 1, url.length());
00280
00281             try {
00282                 HostsInfos.setUserName(getHostNameFromUrl(url), username);
00283             } catch (UnknownHostException e) {
00284                 e.printStackTrace();
00285             }
00286         }
00287
00288         return url;
00289     }
00290
00291
00292
00293
00294
00295
00296
00297
00298
00299
00300
00301
00302
00303     private static String buildUrl(String host, String name, int port) {
00304         if (port == DEFAULT_REGISTRY_PORT) {
00305             if (name.equals("")) {
00306                 return "//" + host;
00307             } else {
00308                 return "//" + host + "/" + name;
00309             }
00310         } else {
00311             if (name.equals("")) {
00312                 return "//" + host + ":" + port;
00313             } else {
00314                 return "//" + host + ":" + port + "/" + name;
00315             }
00316         }
00317     }
00318
00319     private static String readHostAndName(String urlToRead, String protocol)
00320         throws java.net.UnknownHostException {
00321         java.net.InetAddress hostInetAddress = java.net.InetAddress.getLocalHost();
00322         for (int i = 0; i < LOCAL_URLS.length; i++) {
00323             if (urlToRead.toLowerCase().startsWith(LOCAL_URLS[i])) {
00324
00325                 String name = urlToRead.substring(LOCAL_URLS[i].length());
00326                 if (name.startsWith("/")) {
00327
00328                     return buildUrl(UrlBuilder.getHostNameorIP(hostInetAddress),
00329                         name.substring(1), protocol);
00330                 } else {
00331
00332                     if (name.indexOf(":") < 0) {
00333                         return buildUrl(UrlBuilder.getHostNameorIP(
00334                                 hostInetAddress), name, protocol);
00335                     } else if (name.indexOf("/") < 0) {
00336
00337                         return buildHostUrl("//" +
00338                             UrlBuilder.getHostNameorIP(hostInetAddress) + name,
00339                             protocol);
00340                     }
00341
00342
00343                     return buildUrl(UrlBuilder.getHostNameorIP(hostInetAddress),
00344                         name.substring(name.lastIndexOf("/") + 1, name.length()),
00345                         protocol,
00346                         new Integer(name.substring(1, name.lastIndexOf("/"))).intValue());
00347                 }
00348             }
00349         }
00350
00351
00352         int n = urlToRead.indexOf('/', 2);
00353         if (n < 3) {
00354             if (n == -1) {
00355
00356                 return buildHostUrl(urlToRead, protocol);
00357             } else {
00358                 throw new java.net.UnknownHostException(
00359                     "Cannot determine the name of the host in this url=" +
00360                     urlToRead);
00361             }
00362         }
00363
00364
00365         String hostname = getHostFromUrl(urlToRead.substring(2, n));
00366
00367
00368         hostInetAddress = java.net.InetAddress.getByName(hostname);
00369
00370         int portNumber = getPortNumber(urlToRead.substring(2, n));
00371
00372         String name = urlToRead.substring(n + 1);
00373
00374         return buildUrl(UrlBuilder.getHostNameorIP(hostInetAddress), name,
00375             protocol, portNumber);
00376     }
00377
00383     private static String buildHostUrl(String urlToRead, String protocol)
00384         throws UnknownHostException {
00385         protocol = checkProtocol(protocol);
00386         String urlTemp;
00387         String hostname = getHostFromUrl(urlToRead.substring(2,
00388                     urlToRead.length()));
00389
00390
00391         int portNumber = getPortNumber(urlToRead.substring(2, urlToRead.length()));
00392         if (portNumber == DEFAULT_REGISTRY_PORT) {
00393             urlTemp = "//" + hostname;
00394         } else {
00395             urlTemp = "//" + hostname + ":" + portNumber;
00396         }
00397         if (protocol.equals(Constants.DEFAULT_PROTOCOL_IDENTIFIER)) {
00398             return urlTemp;
00399         } else {
00400             return protocol + urlTemp;
00401         }
00402     }
00403
00409     private static int getPortNumber(String url) {
00410
00411         int portNumber = DEFAULT_REGISTRY_PORT;
00412         int index = url.lastIndexOf(":");
00413         if (index > -1) {
00414             portNumber = Integer.parseInt(url.substring(index + 1, url.length()));
00415         }
00416
00417
00418
00419
00420         if (ProActiveConfiguration.osgiServletEnabled()) {
00421             if (index != -1) {
00422                 String suite = url.substring(index);
00423
00424
00425                 int portLength = suite.indexOf('/');
00426
00427
00428                 if (portLength != -1) {
00429                     String portString = suite.substring(1, portLength);
00430
00431
00432                     return Integer.parseInt(portString);
00433                 }
00434             }
00435         }
00436
00437         return portNumber;
00438     }
00439
00445     private static String getHostFromUrl(String url) {
00446         int index = url.lastIndexOf(":");
00447
00448
00449         if (index > -1) {
00450             return url.substring(0, index);
00451         }
00452
00453
00454         return url;
00455     }
00456
00457     private static String internalCheck(String url) {
00458         if (!url.startsWith("//")) {
00459             url = "//" + url;
00460         }
00461         if (url.charAt(url.length() - 1) == '/') {
00462             url = url.substring(0, url.length() - 1);
00463         }
00464         return url;
00465     }
00466 }
