org/objectweb/proactive/core/ssh/UnusedTunnel.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.ssh;
00032
00033 import org.objectweb.proactive.core.ssh.SshParameters;
00034 import org.objectweb.proactive.core.ssh.SshTunnel;
00035
00036
00042 public class UnusedTunnel {
00043     private SshTunnel _tunnel;
00044     private long _time;
00045
00046     public UnusedTunnel(SshTunnel tunnel) {
00047         _tunnel = tunnel;
00048         _time = System.currentTimeMillis();
00049     }
00050
00051     public SshTunnel getTunnel() {
00052         return _tunnel;
00053     }
00054
00055     public boolean isOldEnough() {
00056         long current = System.currentTimeMillis();
00057         if ((current - _time) >= SshParameters.getTunnelGCPeriod()) {
00058             return true;
00059         } else {
00060             return false;
00061         }
00062     }
00063 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
