00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core; 00032 00033 import java.rmi.dgc.VMID; 00034 00035 00043 public class UniqueRuntimeID implements java.io.Serializable { 00044 private java.rmi.dgc.VMID vmID; 00045 private String vmName; 00046 00047 // 00048 // -- CONSTRUCTORS ----------------------------------------------- 00049 // 00050 00054 public UniqueRuntimeID() { 00055 } 00056 00057 public UniqueRuntimeID(String vmName) { 00058 this.vmID = new java.rmi.dgc.VMID(); 00059 this.vmName = vmName; 00060 } 00061 00062 public UniqueRuntimeID(String vmName, VMID vmID) { 00063 this.vmID = vmID; 00064 this.vmName = vmName; 00065 } 00066 00067 // 00068 // -- PUBLIC METHODS ----------------------------------------------- 00069 // 00070 00077 public java.rmi.dgc.VMID getVMID() { 00078 return vmID; 00079 } 00080 00085 public String getVMName() { 00086 return vmName; 00087 } 00088 00093 public String toString() { 00094 return "" + vmName + " " + vmID; 00095 } 00096 00102 public int hashCode() { 00103 return vmName.hashCode(); 00104 } 00105 00110 public boolean equals(Object o) { 00111 //System.out.println("Now checking for equality"); 00112 if (o instanceof UniqueRuntimeID) { 00113 UniqueRuntimeID uri = (UniqueRuntimeID) o; 00114 return vmName.equals(uri.vmName) && vmID.equals(uri.vmID); 00115 } else { 00116 return false; 00117 } 00118 } 00119 }
