org/objectweb/proactive/core/process/unicore/UnicorePasswordGUI.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.process.unicore;
00032
00033 import java.awt.*;
00034 import java.awt.event.*;
00035
00036 import javax.swing.*;
00037
00038
00045 public class UnicorePasswordGUI extends JFrame implements ActionListener {
00046     String keypassword = "";
00047     JTextField password;
00048
00049     public synchronized String getKeyPassword() {
00050         while (keypassword.length() <= 0) {
00051             try {
00052                 wait();
00053             } catch (InterruptedException e) {
00054             }
00055         }
00056         notifyAll();
00057
00058         return keypassword;
00059     }
00060
00061     public synchronized void setKeyPassword(String keypassword) {
00062         this.keypassword = keypassword;
00063         notifyAll();
00064     }
00065
00066     public UnicorePasswordGUI() {
00067         super("ProActive Unicore Client");
00068
00069         JButton ok = new JButton("OK");
00070         ok.addActionListener(this);
00071
00072         password = new JPasswordField(12);
00073         //password.setEchoChar('*');
00074         Container panel = this.getContentPane();
00075         panel.setLayout(new BorderLayout());
00076
00077         panel.add(new JLabel("Input Unicore Keystore Password"),
00078             BorderLayout.NORTH);
00079         panel.add(password, BorderLayout.CENTER);
00080         panel.add(ok, BorderLayout.SOUTH);
00081
00082         this.pack();
00083         this.setVisible(true);
00084     }
00085
00086     public void actionPerformed(ActionEvent e) {
00087         setKeyPassword(password.getText());
00088         this.dispose();
00089     }
00090
00091     public static void main(String[] args) {
00092         UnicorePasswordGUI upGUI = new UnicorePasswordGUI();
00093         System.out.println("password:" + upGUI.getKeyPassword());
00094     }
00095 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
