org/objectweb/proactive/core/ssh/TryCache.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.ssh;
00032
00033
00042 public class TryCache {
00043     private java.util.Hashtable<String, Boolean> _hash;
00044
00045     public TryCache() {
00046         _hash = new java.util.Hashtable<String, Boolean>();
00047     }
00048
00049     private String getKey(String host, int port) {
00050         return host;
00051     }
00052
00053     public boolean everTried(String host, int port) {
00054         String key = getKey(host, port);
00055         Boolean bool = _hash.get(key);
00056         if (bool != null) {
00057             // already tried this connection once.
00058             return true;
00059         } else {
00060             // never tried before.
00061             return false;
00062         }
00063     }
00064
00069     public boolean needToTry(String host, int port) {
00070         String key = getKey(host, port);
00071         Boolean bool = _hash.get(key);
00072         if (bool != null) {
00073             if (bool.booleanValue()) {
00074                 // tried with success before.
00075                 return true;
00076             } else {
00077                 // previous try failed.
00078                 return false;
00079             }
00080         } else {
00081             // never tried before.
00082             return true;
00083         }
00084     }
00085
00086     public void recordTrySuccess(String host, int port) {
00087         String key = getKey(host, port);
00088         _hash.put(key, new Boolean(true));
00089     }
00090
00091     public void recordTryFailure(String host, int port) {
00092         String key = getKey(host, port);
00093         _hash.put(key, new Boolean(false));
00094     }
00095 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
