org/objectweb/proactive/ext/scilab/gui/TreeEngineRenderer.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.scilab.gui;
00032
00033 import java.awt.Color;
00034 import java.awt.Component;
00035
00036 import javax.swing.JTree;
00037 import javax.swing.tree.DefaultTreeCellRenderer;
00038
00039 public class TreeEngineRenderer extends DefaultTreeCellRenderer {
00040
00041         public Component getTreeCellRendererComponent(JTree tree, Object value,
00042                       boolean selected, boolean expanded, boolean leaf, int row,
00043                       boolean hasFocus) {
00044
00045                 DefaultTreeCellRenderer renderer = (DefaultTreeCellRenderer) super.getTreeCellRendererComponent(tree, value, selected, expanded, leaf, row, hasFocus);
00046
00047                     if (value instanceof TreeEngineNode) {
00048
00049                         TreeEngineNode nodeEngine = ((TreeEngineNode) value);
00050                         renderer.setText(nodeEngine.toString());
00051                         if(!nodeEngine.isLeaf() && !nodeEngine.isRoot() && nodeEngine.getState() == TreeEngineNode.SUSPECT){
00052                                 renderer.setForeground(Color.RED);
00053                         }else{
00054                                 renderer.setForeground(Color.BLACK);
00055                         }
00056                     }
00057
00058                     return renderer;
00059         }
00060 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
