org/objectweb/proactive/ext/mixedlocation/TimedRequestWithMixedLocation.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.mixedlocation;
00032
00033 import org.objectweb.proactive.core.body.UniversalBody;
00034 import org.objectweb.proactive.core.body.ft.protocols.FTManager;
00035 import org.objectweb.proactive.core.body.future.FutureProxy;
00036 import org.objectweb.proactive.core.mop.MethodCall;
00037 import org.objectweb.proactive.core.mop.StubObject;
00038 import org.objectweb.proactive.ext.locationserver.LocationServer;
00039 import org.objectweb.proactive.ext.locationserver.TimedRequestWithLocationServer;
00040
00041
00042 public class TimedRequestWithMixedLocation
00043     extends TimedRequestWithLocationServer {
00044     private static final int MAX_TRIES = 30;
00045     private static int counter = 0;
00046     private int tries;
00047     transient protected LocationServer server;
00048     protected long startTime;
00049
00050     public TimedRequestWithMixedLocation(MethodCall methodCall,
00051         UniversalBody sender, boolean isOneWay, long nextSequenceID,
00052         LocationServer server) {
00053         super(methodCall, sender, isOneWay, nextSequenceID, server);
00054     }
00055
00056     protected int sendRequest(UniversalBody destinationBody)
00057         throws java.io.IOException {
00058         System.out.println("RequestWithMixedLocation: sending to universal " +
00059             counter);
00060         int ftres = FTManager.NON_FT;
00061         try {
00062             ftres = destinationBody.receiveRequest(this);
00063         } catch (Exception e) {
00064             //  e.printStackTrace();
00065             this.backupSolution(destinationBody);
00066         }
00067         return ftres;
00068     }
00069
00073     protected void backupSolution(UniversalBody destinationBody)
00074         throws java.io.IOException {
00075         boolean ok = false;
00076         tries = 0;
00077         System.out.println(
00078             "RequestWithMixedLocationr: backupSolution() contacting server " +
00079             server);
00080         System.out.println(
00081             "RequestWithMixedLocation.backupSolution() : looking for " +
00082             destinationBody);
00083         //get the new location from the server
00084         while (!ok && (tries < MAX_TRIES)) {
00085             UniversalBody mobile = (UniversalBody) server.searchObject(destinationBody.getID());
00086             System.out.println(
00087                 "RequestWithMixedLocation: backupSolution() server has sent an answer");
00088
00089             //we want to bypass the stub/proxy
00090             UniversalBody newDestinationBody = (UniversalBody) ((FutureProxy) ((StubObject) mobile).getProxy()).getResult();
00091
00092             // !!!!
00093             // !!!! should put a counter here to stop calling if continuously failing
00094             // !!!!
00095             try {
00096                 // sendRequest(newDestinationBody);
00097                 newDestinationBody.receiveRequest(this);
00098                 //everything went fine, we have to update the current location of the object
00099                 //so that next requests don't go through the server
00100                 System.out.println(
00101                     "RequestWithMixedLocation: backupSolution() updating location");
00102                 if (sender != null) {
00103                     sender.updateLocation(newDestinationBody.getID(),
00104                         newDestinationBody.getRemoteAdapter());
00105                 }
00106                 ok = true;
00107             } catch (Exception e) {
00108                 System.out.println(
00109                     "RequestWithMixedLocation: backupSolution() failed");
00110                 tries++;
00111                 try {
00112                     Thread.sleep(500);
00113                 } catch (Exception e2) {
00114                     e2.printStackTrace();
00115                 }
00116             }
00117         }
00118     }
00119 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
