00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.descriptor.services; 00032 00033 import java.util.Map; 00034 00035 00036 public class TechnicalServiceXmlType { 00037 private String id; 00038 private Class type; 00039 private Map args; 00040 00041 public TechnicalServiceXmlType() { 00042 } 00043 00044 public TechnicalServiceXmlType(String id, Class type, Map args) { 00045 this.id = id; 00046 this.type = type; 00047 this.args = args; 00048 } 00049 00053 public Map getArgs() { 00054 return args; 00055 } 00056 00060 public void setArgs(Map args) { 00061 this.args = args; 00062 } 00063 00067 public String getId() { 00068 return id; 00069 } 00070 00074 public void setId(String id) { 00075 this.id = id; 00076 } 00077 00081 public Class getType() { 00082 return type; 00083 } 00084 00088 public void setType(Class type) { 00089 this.type = type; 00090 } 00091 }
