org/objectweb/proactive/scheduler/TaskScheduler.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.scheduler;
00032
00033 import java.util.Vector;
00034
00035 import org.apache.log4j.Logger;
00036 import org.objectweb.proactive.ProActive;
00037 import org.objectweb.proactive.core.node.Node;
00038 import org.objectweb.proactive.core.util.log.Loggers;
00039 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00040
00041
00042 public class TaskScheduler {
00043     //creates a logger
00044     private static Logger logger = ProActiveLogger.getLogger(Loggers.TASK_SCHEDULER);
00045     private Scheduler scheduler = null;
00046
00047     public TaskScheduler() {
00048     }
00049
00050     public void connectTo(String schedulerURL) throws Exception {
00051         this.scheduler = Scheduler.connectTo(schedulerURL);
00052         if (scheduler == null) {
00053             logger.error(
00054                 "Couldnt connect to scheduler. Please make sure that the deamon is running and is accessible");
00055             throw new Exception("Scheduler doesnt exist");
00056         }
00057         if (logger.isDebugEnabled()) {
00058             logger.debug("Connected to scheduler.");
00059         }
00060     }
00061
00062     //gets nodes, creates the active object performs the computation and finally frees the resources
00063     public void submit(ProActiveTask task) throws Exception {
00064         int estimatedTime = 3;
00065         if (scheduler == null) {
00066             logger.error("Not connected to scheduler");
00067             throw new Exception(
00068                 "Not connected to scheduler, please create a new one or connect to an existing one.");
00069         }
00070
00071         Vector nodes = scheduler.getNodes(1, estimatedTime);
00072
00073         Node node1 = (Node) nodes.get(0);
00074         String jobId = node1.getNodeInformation().getJobID();
00075
00076         ActiveExecuter executer1 = (ActiveExecuter) ProActive.newActive(ActiveExecuter.class.getName(),
00077                 new Object[] { task }, node1);
00078
00079         executer1.start();
00080
00081         scheduler.del(jobId);
00082     }
00083 }
Generated on Mon Jan 22 15:16:12 2007 for ProActive by  doxygen 1.5.1
