org/objectweb/proactive/benchmarks/timit/config/Tag.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.benchmarks.timit.config;
00032
00033 import java.util.HashMap;
00034 import java.util.Iterator;
00035
00036 import org.jdom.Attribute;
00037 import org.jdom.Element;
00038
00046 public abstract class Tag {
00047
00048     private HashMap<String, String> attributes; // <variable name,value>
00049
00053     public Tag() {
00054         this.attributes = new HashMap<String, String>();
00055     }
00056
00063     public Tag(Element eBench) {
00064         this();
00065         Iterator it = eBench.getAttributes().iterator();
00066         while (it.hasNext()) {
00067             Attribute attr = (Attribute) it.next();
00068             this.addAttribute(attr.getName(), attr.getValue());
00069         }
00070     }
00071
00078     public void addAttribute(String name, String value) {
00079         this.attributes.put(name.toLowerCase(), value);
00080     }
00081
00085     public String get(String name) {
00086         return this.attributes.get(name.toLowerCase());
00087     }
00088
00092     public String toString() {
00093         String result = "[";
00094         Iterator<String> it = this.attributes.keySet().iterator();
00095         while (it.hasNext()) {
00096             String key = it.next();
00097             String value = this.attributes.get(key);
00098             result += key + "=" + value + (it.hasNext() ? ", " : "");
00099         }
00100         return result + "]\n";
00101     }
00102 }
Generated on Mon Jan 22 15:16:04 2007 for ProActive by  doxygen 1.5.1
