org/objectweb/proactive/core/ssh/rmissh/SshSocket.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.ssh.rmissh;
00032
00033 import java.io.*;
00034 import java.net.*;
00035 import java.nio.channels.*;
00036
00037 import org.apache.log4j.Logger;
00038 import org.objectweb.proactive.core.ssh.SshParameters;
00039 import org.objectweb.proactive.core.ssh.SshTunnel;
00040 import org.objectweb.proactive.core.ssh.SshTunnelFactory;
00041 import org.objectweb.proactive.core.ssh.TryCache;
00042 import org.objectweb.proactive.core.util.log.Loggers;
00043 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00044
00045
00052 public class SshSocket extends Socket {
00053     static Logger logger = ProActiveLogger.getLogger(Loggers.SSH);
00054     private SshTunnel _tunnel;
00055     private Socket _socket;
00056     static private TryCache _tryCache = null;
00057
00058     static private TryCache getTryCache() {
00059         if (_tryCache == null) {
00060             _tryCache = new TryCache();
00061         }
00062         return _tryCache;
00063     }
00064
00065     protected void finalize() throws Throwable {
00066         super.finalize();
00067         logger.debug("finalizing SshSocket for tunnel " + _tunnel.getPort());
00068         SshTunnelFactory.reportUnusedTunnel(_tunnel);
00069         _tunnel = null;
00070         _socket.close();
00071         _socket = null;
00072     }
00073
00074     public SshSocket(String host, int port) throws IOException {
00075         logger.debug("try socket to " + host + ":" + port);
00076         if (SshParameters.getTryNormalFirst() &&
00077                 getTryCache().needToTry(host, port)) {
00078             try {
00079                 InetSocketAddress address = new InetSocketAddress(host, port);
00080                 _socket = new Socket();
00081                 _socket.connect(address, SshParameters.getConnectTimeout());
00082                 getTryCache().recordTrySuccess(host, port);
00083                 logger.debug("success normal socket to " + host + ":" + port);
00084                 return;
00085             } catch (Exception e) {
00086                 logger.debug("failure normal socket to " + host + ":" + port);
00087                 getTryCache().recordTryFailure(host, port);
00088                 _socket = null;
00089             }
00090         }
00091         logger.debug("try ssh socket to " + host + ":" + port);
00092         _tunnel = SshTunnelFactory.createTunnel(host, port);
00093         InetSocketAddress address = new InetSocketAddress("127.0.0.1",
00094                 _tunnel.getPort());
00095         _socket = new Socket();
00096         _socket.connect(address, SshParameters.getConnectTimeout());
00097         logger.debug("Opened TCP connection 127.0.0.1:" + _tunnel.getPort() +
00098             " -> " + host + ":" + port);
00099     }
00100
00101     public void connect() throws IOException {
00102         //assert false;
00103     }
00104
00105     public void connect(SocketAddress endpoint, int timeout)
00106         throws IOException {
00107         // assert false;
00108     }
00109
00110     public void bind(SocketAddress bindpoint) throws IOException {
00111         // assert false;
00112     }
00113
00114     public InetAddress getInetAddress() {
00115         try {
00116             return _tunnel.getInetAddress();
00117         } catch (UnknownHostException e) {
00118             return null;
00119         }
00120     }
00121
00122     public InetAddress getLocalAddress() {
00123         return _socket.getLocalAddress();
00124     }
00125
00126     public int getPort() {
00127         return _tunnel.getPort();
00128     }
00129
00130     public int getLocalPort() {
00131         return _socket.getLocalPort();
00132     }
00133
00134     public SocketAddress getRemoteSocketAddress() {
00135         return new InetSocketAddress(getInetAddress(), getPort());
00136     }
00137
00138     public SocketAddress getLocalSocketAddress() {
00139         return new InetSocketAddress(getLocalAddress(), getLocalPort());
00140     }
00141
00142     public SocketChannel getChannel() {
00143         return _socket.getChannel();
00144     }
00145
00146     public InputStream getInputStream() throws IOException {
00147         return _socket.getInputStream();
00148     }
00149
00150     public OutputStream getOutputStream() throws IOException {
00151         return _socket.getOutputStream();
00152     }
00153
00154     public void setTcpNoDelay(boolean on) throws SocketException {
00155         _socket.setTcpNoDelay(on);
00156     }
00157
00158     public boolean getTcpNoDelay() throws SocketException {
00159         return _socket.getTcpNoDelay();
00160     }
00161
00162     public void setSoLinger(boolean on, int linger) throws SocketException {
00163         _socket.setSoLinger(on, linger);
00164     }
00165
00166     public int getSoLinger() throws SocketException {
00167         return _socket.getSoLinger();
00168     }
00169
00170     public void sendUrgentData(int data) throws IOException {
00171         _socket.sendUrgentData(data);
00172     }
00173
00174     public void setOOBInline(boolean on) throws SocketException {
00175         _socket.setOOBInline(on);
00176     }
00177
00178     public boolean getOOBInline() throws SocketException {
00179         return _socket.getOOBInline();
00180     }
00181
00182     public synchronized void setSoTimeout(int timeout)
00183         throws SocketException {
00184         _socket.setSoTimeout(timeout);
00185     }
00186
00187     public synchronized int getSoTimeout() throws SocketException {
00188         return _socket.getSoTimeout();
00189     }
00190
00191     public synchronized void setSendBufferSize(int size)
00192         throws SocketException {
00193         _socket.setSendBufferSize(size);
00194     }
00195
00196     public synchronized int getSendBufferSize() throws SocketException {
00197         return _socket.getSendBufferSize();
00198     }
00199
00200     public synchronized void setReceiveBufferSize(int size)
00201         throws SocketException {
00202         _socket.setReceiveBufferSize(size);
00203     }
00204
00205     public synchronized int getReceiveBufferSize() throws SocketException {
00206         return _socket.getReceiveBufferSize();
00207     }
00208
00209     public void setKeepAlive(boolean on) throws SocketException {
00210         _socket.setKeepAlive(on);
00211     }
00212
00213     public boolean getKeepAlive() throws SocketException {
00214         return _socket.getKeepAlive();
00215     }
00216
00217     public void setTrafficClass(int tc) throws SocketException {
00218         _socket.setTrafficClass(tc);
00219     }
00220
00221     public int getTrafficClass() throws SocketException {
00222         return _socket.getTrafficClass();
00223     }
00224
00225     public void setReuseAddress(boolean on) throws SocketException {
00226         _socket.setReuseAddress(on);
00227     }
00228
00229     public boolean getReuseAddress() throws SocketException {
00230         return _socket.getReuseAddress();
00231     }
00232
00233     public synchronized void close() throws IOException {
00234         _socket.close();
00235         try {
00236             SshTunnelFactory.reportUnusedTunnel(_tunnel);
00237         } catch (Exception e) {
00238             e.printStackTrace();
00239         }
00240         _tunnel = null;
00241     }
00242
00243     public void shutdownInput() throws IOException {
00244         _socket.shutdownInput();
00245     }
00246
00247     public void shutdownOutput() throws IOException {
00248         _socket.shutdownOutput();
00249     }
00250
00251     public String toString() {
00252         return _socket.toString();
00253     }
00254
00255     public boolean isConnected() {
00256         return _socket.isConnected();
00257     }
00258
00259     public boolean isBound() {
00260         return _socket.isBound();
00261     }
00262
00263     public boolean isClosed() {
00264         return _socket.isClosed();
00265     }
00266
00267     public boolean isInputShutdown() {
00268         return _socket.isInputShutdown();
00269     }
00270
00271     public boolean isOutputShutdown() {
00272         return _socket.isOutputShutdown();
00273     }
00274 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
