org/objectweb/proactive/core/ssh/rmissh/SshRMIClientSocketFactory.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.ssh.rmissh;
00032
00033 import java.io.IOException;
00034 import java.net.InetAddress;
00035 import java.net.Socket;
00036 import java.net.UnknownHostException;
00037 import java.rmi.server.RMIClientSocketFactory;
00038
00039 import org.objectweb.proactive.core.util.HostsInfos;
00040
00041
00045 public class SshRMIClientSocketFactory implements RMIClientSocketFactory,
00046     java.io.Serializable {
00047     String username;
00048     String hostname;
00049
00050     public SshRMIClientSocketFactory() {
00051         this.username = System.getProperty("user.name");
00052         try {
00053             this.hostname = InetAddress.getLocalHost().getCanonicalHostName();
00054         } catch (UnknownHostException e) {
00055             this.hostname = "locahost";
00056         }
00057     }
00058
00059     public Socket createSocket(String host, int port) throws IOException {
00060         String realName = HostsInfos.getSecondaryName(host);
00061         Socket socket = new SshSocket(realName, port);
00062         return socket;
00063     }
00064
00065     public boolean equals(Object obj) {
00066         // the equals method is class based, since all instances are functionally equivalent.
00067         // We could if needed compare on an instance basic for instance with the host and port
00068         // Same for hashCode
00069         return this.getClass().equals(obj.getClass());
00070     }
00071
00072     public int hashCode() {
00073         return this.getClass().hashCode();
00074     }
00075
00076     private void readObject(java.io.ObjectInputStream in)
00077         throws java.io.IOException, ClassNotFoundException {
00078         in.defaultReadObject();
00079         HostsInfos.setUserName(hostname, username);
00080     }
00081 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
