00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.scheduler.policy; 00032 00033 import org.objectweb.proactive.scheduler.*; 00034 00035 00044 public class SpacePolicy extends AbstractPolicy { 00045 public SpacePolicy() { 00046 super(); 00047 00048 // TODO Auto-generated constructor stub 00049 } 00050 00051 public SpacePolicy(RessourceManager ressourceManager) { 00052 super(ressourceManager); 00053 } 00054 00061 public boolean isToBeServed(GenericJob job1, GenericJob job2) { 00062 // TODO Auto-generated method stub 00063 int ressourceNb1 = job1.getRessourceNb(); 00064 int ressourceNb2 = job2.getRessourceNb(); 00065 00066 if ((ressourceNb1 < ressourceNb2) || 00067 ((ressourceNb1 == ressourceNb2) && 00068 (job1.getSubmitDate().before(job2.getSubmitDate())))) { 00069 return true; 00070 } else { 00071 return false; 00072 } 00073 } 00074 }
1.5.1
