00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.process; 00032 00033 import org.objectweb.proactive.core.util.RemoteProcessMessageLogger; 00034 00035 00054 public class SimpleExternalProcess extends AbstractExternalProcess { 00055 private String targetCommand; 00056 00057 // 00058 // -- CONSTRUCTORS ----------------------------------------------- 00059 // 00060 00065 public SimpleExternalProcess(String targetCommand) { 00066 this(new StandardOutputMessageLogger(), targetCommand); 00067 } 00068 00074 public SimpleExternalProcess(RemoteProcessMessageLogger messageLogger, 00075 String targetCommand) { 00076 this(messageLogger, messageLogger, targetCommand); 00077 } 00078 00085 public SimpleExternalProcess( 00086 RemoteProcessMessageLogger inputMessageLogger, 00087 RemoteProcessMessageLogger errorMessageLogger, String targetCommand) { 00088 super(inputMessageLogger, errorMessageLogger); 00089 this.targetCommand = targetCommand; 00090 } 00091 00092 // 00093 // -- PUBLIC METHODS ----------------------------------------------- 00094 // 00095 00099 public String getProcessId() { 00100 return "simpleprocess"; 00101 } 00102 00106 public int getNodeNumber() { 00107 return 1; 00108 } 00109 00113 public UniversalProcess getFinalProcess() { 00114 checkStarted(); 00115 return this; 00116 } 00117 00118 public static void main(String[] args) { 00119 try { 00120 String targetCommand = null; 00121 if (args.length > 0) { 00122 targetCommand = args[0]; 00123 } else { 00124 targetCommand = "ls -las"; 00125 } 00126 SimpleExternalProcess p = new SimpleExternalProcess(targetCommand); 00127 p.startProcess(); 00128 } catch (Exception e) { 00129 e.printStackTrace(); 00130 } 00131 } 00132 00133 // 00134 // -- PROTECTED METHODS ----------------------------------------------- 00135 // 00136 protected String buildCommand() { 00137 return targetCommand; 00138 } 00139 00140 // 00141 // -- PRIVATE METHODS ----------------------------------------------- 00142 // 00143 }
1.5.1
