org/objectweb/proactive/ext/security/crypto/SigningEngine.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.security.crypto;
00032
00033 import java.io.Serializable;
00034 import java.security.PrivateKey;
00035 import java.security.PublicKey;
00036 import java.security.Signature;
00037 import java.security.SignedObject;
00038
00039
00040 public class SigningEngine implements Serializable {
00041     private transient Signature signingEngine;
00042
00043     public SigningEngine() {
00044         try {
00045             signingEngine = Signature.getInstance("SHA-1/RSA", "BC");
00046         } catch (Exception e) {
00047             System.out.println("Exception in SigningEngine instanciation : " +
00048                 e);
00049             e.printStackTrace();
00050         }
00051     }
00052
00053     public Object signObject(Serializable object, PrivateKey privateKey) {
00054         try {
00055             return new SignedObject(object, privateKey, signingEngine);
00056         } catch (Exception e) {
00057             System.out.println("Exception in object signature : " + e);
00058             System.out.println(privateKey);
00059             e.printStackTrace();
00060         }
00061
00062         return null;
00063     }
00064
00065     public boolean checkSignature(Object signedObject, PublicKey publicKey) {
00066         try {
00067             if (((SignedObject) signedObject).verify(publicKey, signingEngine)) {
00068                 return true;
00069             }
00070         } catch (Exception e) {
00071             System.out.println("Exception object signature checking :" + e);
00072             e.printStackTrace();
00073         }
00074
00075         return false;
00076     }
00077 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
