org/objectweb/proactive/core/descriptor/xml/ServiceDefinitionHandler.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.descriptor.xml;
00032
00033 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00034 import org.objectweb.proactive.core.descriptor.services.FaultToleranceService;
00035 import org.objectweb.proactive.core.descriptor.services.P2PDescriptorService;
00036 import org.objectweb.proactive.core.descriptor.services.RMIRegistryLookupService;
00037 import org.objectweb.proactive.core.descriptor.services.SchedulerLookupService;
00038 import org.objectweb.proactive.core.descriptor.services.UniversalService;
00039 import org.objectweb.proactive.core.xml.handler.BasicUnmarshaller;
00040 import org.objectweb.proactive.core.xml.handler.CollectionUnmarshaller;
00041 import org.objectweb.proactive.core.xml.handler.PassiveCompositeUnmarshaller;
00042 import org.objectweb.proactive.core.xml.handler.SingleValueUnmarshaller;
00043 import org.objectweb.proactive.core.xml.handler.UnmarshallerHandler;
00044 import org.objectweb.proactive.core.xml.io.Attributes;
00045 import org.objectweb.proactive.scheduler.GenericJob;
00046 import org.objectweb.proactive.scheduler.Scheduler;
00047 import org.xml.sax.SAXException;
00048
00049
00050 public class ServiceDefinitionHandler extends PassiveCompositeUnmarshaller
00051     implements ProActiveDescriptorConstants {
00052     ProActiveDescriptor pad;
00053     Scheduler scheduler;
00054     protected String serviceId;
00055     private String jobId;
00056
00057     public ServiceDefinitionHandler(ProActiveDescriptor pad) {
00058         super(false);
00059         this.pad = pad;
00060         this.addHandler(RMI_LOOKUP_TAG, new RMILookupHandler());
00061         this.addHandler(FT_CONFIG_TAG, new FaultToleranceHandler());
00062         this.addHandler(P2P_SERVICE_TAG, new P2PServiceHandler());
00063         this.addHandler(PROACTIVE_SCHEDULER_TAG, new ProActiveSchedulerHandler());
00064     }
00065
00066     public ServiceDefinitionHandler(Scheduler scheduler, String jobId,
00067         ProActiveDescriptor pad) {
00068         super(false);
00069         this.pad = pad;
00070         this.scheduler = scheduler;
00071         this.jobId = jobId;
00072         this.addHandler(RMI_LOOKUP_TAG, new RMILookupHandler());
00073         this.addHandler(FT_CONFIG_TAG, new FaultToleranceHandler());
00074         this.addHandler(P2P_SERVICE_TAG, new P2PServiceHandler());
00075         this.addHandler(PROACTIVE_SCHEDULER_TAG, new ProActiveSchedulerHandler());
00076     }
00077
00078     /* (non-Javadoc)
00079      * @see org.objectweb.proactive.core.xml.handler.AbstractUnmarshallerDecorator#notifyEndActiveHandler(java.lang.String, org.objectweb.proactive.core.xml.handler.UnmarshallerHandler)
00080      */
00081     protected void notifyEndActiveHandler(String name,
00082         UnmarshallerHandler activeHandler) throws SAXException {
00083         UniversalService service = (UniversalService) activeHandler.getResultObject();
00084         pad.addService(serviceId, service);
00085     }
00086
00087     /* (non-Javadoc)
00088      * @see org.objectweb.proactive.core.xml.handler.UnmarshallerHandler#startContextElement(java.lang.String, org.objectweb.proactive.core.xml.io.Attributes)
00089      */
00090     public void startContextElement(String name, Attributes attributes)
00091         throws SAXException {
00092         this.serviceId = attributes.getValue("id");
00093     }
00094
00095     protected class RMILookupHandler extends BasicUnmarshaller {
00096         public RMILookupHandler() {
00097         }
00098
00099         public void startContextElement(String name, Attributes attributes)
00100             throws org.xml.sax.SAXException {
00101             String lookupUrl = attributes.getValue("url");
00102             RMIRegistryLookupService rmiService = new RMIRegistryLookupService(lookupUrl);
00103             setResultObject(rmiService);
00104         }
00105     } // end of inner class RMILookupHandler
00106
00107     protected class ProActiveSchedulerHandler
00108         extends PassiveCompositeUnmarshaller {
00109         protected SchedulerLookupService schedulerLookupService;
00110
00111         public ProActiveSchedulerHandler() {
00112             super(false);
00113         }
00114
00115         public void startContextElement(String name, Attributes attributes)
00116             throws org.xml.sax.SAXException {
00117             String schedulerUrl = attributes.getValue("schedulerUrl");
00118             schedulerLookupService = new SchedulerLookupService(schedulerUrl);
00119
00120             String nbOfNodes = attributes.getValue("numberOfNodes");
00121
00122             if (!checkNonEmpty(nbOfNodes)) {
00123                 throw new org.xml.sax.SAXException(
00124                     "ProActiveScheduler Tag without any numberOfNodes defined");
00125             }
00126
00127             schedulerLookupService.setNodeNumber(Integer.parseInt(nbOfNodes));
00128
00129             if (scheduler != null) {
00130                 String jvmParam = attributes.getValue("jvmParameters");
00131                 GenericJob job = scheduler.getTmpJob(jobId);
00132                 if (checkNonEmpty(nbOfNodes)) {
00133                     job.setJVMParameters(jvmParam);
00134                 }
00135
00136                 String minNumberOfNodes = attributes.getValue(
00137                         "minNumberOfNodes");
00138                 if (checkNonEmpty(minNumberOfNodes)) {
00139                     schedulerLookupService.setMinNodeNumber(Integer.parseInt(
00140                             minNumberOfNodes));
00141                 } else {
00142                     schedulerLookupService.setMinNodeNumber(Integer.parseInt(
00143                             nbOfNodes));
00144                 }
00145             }
00146         }
00147
00148         public Object getResultObject() throws org.xml.sax.SAXException {
00149             return schedulerLookupService;
00150         }
00151     } // end of inner class ProActiveSchedulerHandler
00152
00153     protected class P2PServiceHandler extends PassiveCompositeUnmarshaller {
00154         protected P2PDescriptorService p2pDescriptorService;
00155
00156         public P2PServiceHandler() {
00157             super(false);
00158             CollectionUnmarshaller ch = new CollectionUnmarshaller(String.class);
00159             ch.addHandler(PEER_TAG, new SingleValueUnmarshaller());
00160             this.addHandler(PEERS_SET_TAG, ch);
00161         }
00162
00163         public void startContextElement(String name, Attributes attributes)
00164             throws org.xml.sax.SAXException {
00165             p2pDescriptorService = new P2PDescriptorService();
00166             String askedNodes = attributes.getValue("nodesAsked");
00167             if (checkNonEmpty(askedNodes)) {
00168                 if (askedNodes.equals("MAX")) {
00169                     p2pDescriptorService.setNodeNumberToMAX();
00170                 } else {
00171                     p2pDescriptorService.setNodeNumber(Integer.parseInt(
00172                             askedNodes));
00173                 }
00174             }
00175
00176             String acq = attributes.getValue("acq");
00177             if (checkNonEmpty(acq)) {
00178                 p2pDescriptorService.setAcq(acq);
00179             }
00180
00181             String port = attributes.getValue("port");
00182             if (checkNonEmpty(port)) {
00183                 p2pDescriptorService.setPort(port);
00184             }
00185
00186             String noa = attributes.getValue("NOA");
00187             if (checkNonEmpty(noa)) {
00188                 p2pDescriptorService.setNoa(noa);
00189             }
00190
00191             String ttu = attributes.getValue("TTU");
00192             if (checkNonEmpty(ttu)) {
00193                 p2pDescriptorService.setTtu(ttu);
00194             }
00195
00196             String ttl = attributes.getValue("TTL");
00197             if (checkNonEmpty(ttl)) {
00198                 p2pDescriptorService.setTtl(ttl);
00199             }
00200
00201             String multi_proc_nodes = attributes.getValue("multi_proc_nodes");
00202             if (checkNonEmpty(multi_proc_nodes)) {
00203                 p2pDescriptorService.setMultiProcNodes(multi_proc_nodes);
00204             }
00205
00206             String xml_path = attributes.getValue("xml_path");
00207             if (checkNonEmpty(xml_path)) {
00208                 p2pDescriptorService.setXmlPath(xml_path);
00209             }
00210
00211             String node_family_regexp = attributes.getValue(
00212                     "node_family_regexp");
00213             if (checkNonEmpty(node_family_regexp)) {
00214                 p2pDescriptorService.setNodeFamilyRegexp(node_family_regexp);
00215             }
00216         }
00217
00218         protected void notifyEndActiveHandler(String name,
00219             UnmarshallerHandler activeHandler) throws SAXException {
00220             String[] peerList = (String[]) activeHandler.getResultObject();
00221             p2pDescriptorService.setPeerList(peerList);
00222         }
00223
00224         public Object getResultObject() throws org.xml.sax.SAXException {
00225             return p2pDescriptorService;
00226         }
00227     } // end of inner class P2PLookupHandler
00228
00229     protected class FaultToleranceHandler extends PassiveCompositeUnmarshaller {
00230         protected FaultToleranceService ftService;
00231
00232         public FaultToleranceHandler() {
00233             FTConfigHandler ftch = new FTConfigHandler();
00234             this.addHandler(FT_CKPTSERVER_TAG, ftch);
00235             this.addHandler(FT_RECPROCESS_TAG, ftch);
00236             this.addHandler(FT_LOCSERVER_TAG, ftch);
00237             this.addHandler(FT_RESSERVER_TAG, ftch);
00238             this.addHandler(FT_GLOBALSERVER_TAG, ftch);
00239             this.addHandler(FT_TTCVALUE_TAG, ftch);
00240             this.addHandler(FT_PROTO_TAG, ftch);
00241         }
00242
00243         public void startContextElement(String name, Attributes attributes)
00244             throws org.xml.sax.SAXException {
00245             this.ftService = new FaultToleranceService();
00246         }
00247
00248         public Object getResultObject() throws org.xml.sax.SAXException {
00249             return this.ftService;
00250         }
00251
00252         protected class FTConfigHandler extends BasicUnmarshaller {
00253             public void startContextElement(String name, Attributes attributes)
00254                 throws org.xml.sax.SAXException {
00255                 if (FT_RECPROCESS_TAG.equals(name)) {
00256                     FaultToleranceHandler.this.ftService.setRecoveryProcessURL(attributes.getValue(
00257                             "url"));
00258                 } else if (FT_LOCSERVER_TAG.equals(name)) {
00259                     FaultToleranceHandler.this.ftService.setLocationServerURL(attributes.getValue(
00260                             "url"));
00261                 } else if (FT_CKPTSERVER_TAG.equals(name)) {
00262                     FaultToleranceHandler.this.ftService.setCheckpointServerURL(attributes.getValue(
00263                             "url"));
00264                 } else if (FT_RESSERVER_TAG.equals(name)) {
00265                     FaultToleranceHandler.this.ftService.setAttachedResourceServer(attributes.getValue(
00266                             "url"));
00267                 } else if (FT_TTCVALUE_TAG.equals(name)) {
00268                     FaultToleranceHandler.this.ftService.setTtcValue(attributes.getValue(
00269                             "value"));
00270                 } else if (FT_GLOBALSERVER_TAG.equals(name)) {
00271                     FaultToleranceHandler.this.ftService.setGlobalServerURL(attributes.getValue(
00272                             "url"));
00273                 } else if (FT_PROTO_TAG.equals(name)) {
00274                     FaultToleranceHandler.this.ftService.setProtocolType(attributes.getValue(
00275                             "type"));
00276                 }
00277             }
00278         }
00279     }
00280 }
Generated on Mon Jan 22 15:16:07 2007 for ProActive by  doxygen 1.5.1
