org/objectweb/proactive/ext/security/SerializableKeyStore.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.security;
00032
00033 import java.io.ByteArrayInputStream;
00034 import java.io.ByteArrayOutputStream;
00035 import java.io.IOException;
00036 import java.io.Serializable;
00037 import java.security.KeyStore;
00038 import java.security.KeyStoreException;
00039 import java.security.NoSuchAlgorithmException;
00040 import java.security.NoSuchProviderException;
00041 import java.security.cert.CertificateException;
00042
00043
00048 public class SerializableKeyStore implements Serializable {
00049     protected transient KeyStore keyStore;
00050     protected byte[] encodedKeyStore;
00051
00052     public SerializableKeyStore(KeyStore keyStore) {
00053         this.keyStore = keyStore;
00054     }
00055
00056     private void writeObject(java.io.ObjectOutputStream out)
00057         throws IOException {
00058         ByteArrayOutputStream bout = new ByteArrayOutputStream();
00059
00060         try {
00061             keyStore.store(bout, "ha".toCharArray());
00062         } catch (KeyStoreException e) {
00063             e.printStackTrace();
00064         } catch (NoSuchAlgorithmException e) {
00065             e.printStackTrace();
00066         } catch (CertificateException e) {
00067             e.printStackTrace();
00068         } catch (IOException e) {
00069             e.printStackTrace();
00070         }
00071
00072         encodedKeyStore = bout.toByteArray();
00073         bout.close();
00074
00075         out.defaultWriteObject();
00076     }
00077
00078     private void readObject(java.io.ObjectInputStream in)
00079         throws IOException, ClassNotFoundException {
00080         in.defaultReadObject();
00081
00082         try {
00083             keyStore = KeyStore.getInstance("PKCS12", "BC");
00084             keyStore.load(new ByteArrayInputStream(encodedKeyStore),
00085                 "ha".toCharArray());
00086         } catch (KeyStoreException e) {
00087             // TODOSECURITYSECURITY Auto-generated catch block
00088             e.printStackTrace();
00089         } catch (NoSuchProviderException e) {
00090             // TODOSECURITYSECURITY Auto-generated catch block
00091             e.printStackTrace();
00092         } catch (NoSuchAlgorithmException e) {
00093             // TODOSECURITYSECURITY Auto-generated catch block
00094             e.printStackTrace();
00095         } catch (CertificateException e) {
00096             // TODOSECURITYSECURITY Auto-generated catch block
00097             e.printStackTrace();
00098         } catch (IOException e) {
00099             // TODOSECURITYSECURITY Auto-generated catch block
00100             e.printStackTrace();
00101         }
00102     }
00103
00104     public KeyStore getKeyStore() {
00105         return keyStore;
00106     }
00107 }
Generated on Mon Jan 22 15:16:11 2007 for ProActive by  doxygen 1.5.1
