org/objectweb/proactive/calcium/skeletons/Seq.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.calcium.skeletons;
00032
00033 import java.util.Vector;
00034
00035 import org.objectweb.proactive.calcium.Task;
00036 import org.objectweb.proactive.calcium.exceptions.EnvironmentException;
00037 import org.objectweb.proactive.calcium.interfaces.Execute;
00038 import org.objectweb.proactive.calcium.interfaces.Instruction;
00039 import org.objectweb.proactive.calcium.interfaces.Skeleton;
00040 import org.objectweb.proactive.calcium.statistics.Timer;
00041
00042
00052 public class Seq<T> implements Skeleton<T>, Instruction<T> {
00053
00054         Execute<T> secCode;
00055         int muscleId;
00056
00057         public Seq(Execute<T> secCode){
00058                 this.secCode=secCode;
00059                 muscleId=0;
00060         }
00061
00062         public Vector<Instruction<T>> getInstructionStack() {
00063
00064                 Vector<Instruction<T>> v=new Vector<Instruction<T>>();
00065                 v.add(this);
00066                 return v;
00067         }
00068
00069         public Task<T> compute(Task<T> t) throws RuntimeException, EnvironmentException {
00070
00071                 Timer timer = new Timer();
00072                 T resultObject=secCode.execute(t.getObject());
00073                 timer.stop();
00074
00075                 //Task<T> resultTask= t.reBirth(resultObject);
00076                 //resultTask.getStats().trackWorkout(secCode, timer);
00077                 //return resultTask;
00078
00079                 t.setObject(resultObject);
00080                 t.getStats().getWorkout().track(secCode,timer);
00081                 return t;
00082         }
00083
00084         public String toString(){
00085                 return "Seq("+this.secCode.getClass()+")";
00086         }
00087 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
