org/objectweb/proactive/ext/security/SecurityEntity.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.security;
00032
00033 import java.io.IOException;
00034 import java.security.PublicKey;
00035 import java.security.cert.X509Certificate;
00036 import java.util.ArrayList;
00037
00038 import org.objectweb.proactive.ext.security.crypto.KeyExchangeException;
00039 import org.objectweb.proactive.ext.security.exceptions.RenegotiateSessionException;
00040 import org.objectweb.proactive.ext.security.exceptions.SecurityNotAvailableException;
00041 import org.objectweb.proactive.ext.security.securityentity.Entity;
00042
00043
00049 public interface SecurityEntity {
00050
00057     public X509Certificate getCertificate()
00058         throws SecurityNotAvailableException, IOException;
00059
00067     public long startNewSession(Communication policy)
00068         throws SecurityNotAvailableException, RenegotiateSessionException,
00069             IOException;
00070
00076     public PublicKey getPublicKey()
00077         throws SecurityNotAvailableException, IOException;
00078
00087     public byte[] randomValue(long sessionID, byte[] clientRandomValue)
00088         throws SecurityNotAvailableException, RenegotiateSessionException,
00089             IOException;
00090
00104     public byte[][] publicKeyExchange(long sessionID, byte[] myPublicKey,
00105         byte[] myCertificate, byte[] signature)
00106         throws SecurityNotAvailableException, RenegotiateSessionException,
00107             KeyExchangeException, IOException;
00108
00127     public byte[][] secretKeyExchange(long sessionID, byte[] encodedAESKey,
00128         byte[] encodedIVParameters, byte[] encodedClientMacKey,
00129         byte[] encodedLockData, byte[] parametersSignature)
00130         throws SecurityNotAvailableException, RenegotiateSessionException,
00131             IOException;
00132
00141     public SecurityContext getPolicy(SecurityContext securityContext)
00142         throws SecurityNotAvailableException, IOException;
00143
00148     public byte[] getCertificateEncoded()
00149         throws SecurityNotAvailableException, IOException;
00150
00156     public ArrayList<Entity> getEntities()
00157         throws SecurityNotAvailableException, IOException;
00158
00164     public void terminateSession(long sessionID)
00165         throws SecurityNotAvailableException, IOException;
00166 }
Generated on Mon Jan 22 15:16:11 2007 for ProActive by  doxygen 1.5.1
