00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.security; 00032 00033 00039 public interface SecurityConstants { 00040 public static final String XML_CERTIFICATE = "/Policy/Certificate"; 00041 public static final String XML_PRIVATE_KEY = "/Policy/PrivateKey"; 00042 public static final String XML_TRUSTED_CERTIFICATION_AUTHORITY = "/Policy/TrustedCertificationAuthority/CertificationAuthority"; 00043 public static final String XML_CERTIFICATION_AUTHORITY_CERTIFICATE = "Certificate"; 00044 public static final String KEYSTORE_APPLICATION_PATH = "applicationCertificate"; 00045 public static final String KEYSTORE_ENTITY_PATH = "entityEntry"; 00046 public static final int MAX_SESSION_VALIDATION_WAIT = 30; 00047 public static final int ENTITY_TYPE_OBJECT = 1; 00048 public static final int ENTITY_TYPE_NODE = 2; 00049 public static final int ENTITY_TYPE_RUNTIME = 3; 00050 }
1.5.1
