org/objectweb/proactive/ext/scilab/monitor/ScilabService.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.scilab.monitor;
00032
00033 import java.io.File;
00034 import java.io.IOException;
00035 import java.io.Serializable;
00036 import java.util.ArrayList;
00037 import java.util.HashMap;
00038
00039 import javasci.SciData;
00040
00041 import org.apache.log4j.Logger;
00042 import org.objectweb.proactive.ProActive;
00043 import org.objectweb.proactive.core.util.log.Loggers;
00044 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00045 import org.objectweb.proactive.core.util.wrapper.BooleanWrapper;
00046 import org.objectweb.proactive.ext.scilab.SciDeployEngine;
00047 import org.objectweb.proactive.ext.scilab.SciEngine;
00048 import org.objectweb.proactive.ext.scilab.SciResult;
00049 import org.objectweb.proactive.ext.scilab.SciTask;
00050
00060 public class ScilabService implements Serializable{
00061
00062         private HashMap<String, SciEngineInfo> mapEngine;
00063         private ArrayList<String> listIdEngineFree;
00064
00065         private ArrayList<SciTaskInfo> listTaskWait;
00066         private HashMap<String, SciTaskInfo> mapTaskRun;
00067         private HashMap<String, SciTaskInfo> mapTaskEnd;
00068
00069         private long countIdTask;
00070         private long countIdEngine;
00071
00072         private SciEventSource taskObservable;
00073         private SciEventSource engineObservable;
00074
00075         private static Logger logger = ProActiveLogger.getLogger(Loggers.SCILAB_SERVICE);
00076
00080         public ScilabService() {
00081                 this.mapEngine = new HashMap<String, SciEngineInfo>();
00082                 this.listIdEngineFree = new ArrayList<String>();
00083
00084                 this.listTaskWait = new ArrayList<SciTaskInfo>();
00085                 this.mapTaskRun = new HashMap<String, SciTaskInfo>();
00086                 this.mapTaskEnd = new HashMap<String, SciTaskInfo>();
00087
00088                 this.taskObservable = new SciEventSource();
00089                 this.engineObservable = new SciEventSource();
00090
00091                 (new Thread(){
00092                         public void run(){
00093                                 executeTasks();
00094                         }
00095                 }).start();
00096
00097
00098                 (new Thread(){
00099                         public void run(){
00100                                 retrieveResults();
00101                         }
00102                 }).start();
00103         }
00104
00113         public synchronized int deployEngine(String nameVirtualNode, String pathDescriptor, String arrayIdEngine[]){
00114                 logger.debug("->ScilabService In:deployEngine:" + nameVirtualNode);
00115                 HashMap mapNewEngine = SciDeployEngine.deploy(nameVirtualNode, pathDescriptor, arrayIdEngine);
00116                 SciEngine sciEngine;
00117                 String idEngine;
00118                 BooleanWrapper isActivate;
00119
00120                 for(int i=0; i<arrayIdEngine.length; i++){
00121                         idEngine = arrayIdEngine[i];
00122                         sciEngine = (SciEngine)mapNewEngine.get(idEngine);
00123
00124                         if(sciEngine == null)
00125                                 continue;
00126
00127                         isActivate = sciEngine.activate();
00128                         mapEngine.put(idEngine, new SciEngineInfo(idEngine, sciEngine, isActivate));
00129                 }
00130
00131                 this.listIdEngineFree.addAll(mapNewEngine.keySet());
00132                 this.engineObservable.fireSciEvent(null);
00133                 notifyAll();
00134                 return mapNewEngine.size();
00135         }
00136
00137         public synchronized int deployEngine(String nameVirtualNode, String pathDescriptor){
00138                 long countTmp = this.countIdEngine;
00139                 int nbEngine = SciDeployEngine.getNbMappedNodes(nameVirtualNode, pathDescriptor);
00140                 String arrayIdEngine[] = new String[nbEngine];
00141                 for(int i=0; i<arrayIdEngine.length; i++){
00142                         arrayIdEngine[i] = "Engine" + countTmp++;
00143                 }
00144
00145                 nbEngine = this.deployEngine(nameVirtualNode, pathDescriptor, arrayIdEngine);
00146                 this.countIdEngine += nbEngine;
00147                 return nbEngine;
00148         }
00149
00150         public synchronized int deployEngine(String nameVirtualNode, String pathDescriptor, int nbEngine){
00151                 long countTmp = this.countIdEngine;
00152                 String arrayIdEngine[] = new String[nbEngine];
00153                 for(int i=0; i<arrayIdEngine.length; i++){
00154                         arrayIdEngine[i] = "Engine" + countTmp++;
00155                 }
00156
00157                 nbEngine = this.deployEngine(nameVirtualNode, pathDescriptor, arrayIdEngine);
00158                 this.countIdEngine += nbEngine;
00159                 return nbEngine;
00160         }
00161
00167         public synchronized void sendTask(SciTask sciTask){
00168                 logger.debug("->ScilabService In:sendTask:" + sciTask.getId());
00169                 SciTaskInfo sciTaskInfo = new SciTaskInfo(sciTask);
00170                 sciTaskInfo.setState(SciTaskInfo.PENDING);
00171                 this.listTaskWait.add(sciTaskInfo);
00172                 this.taskObservable.fireSciEvent(new SciEvent(sciTaskInfo));
00173                 notifyAll();
00174         }
00175
00176         public synchronized void sendTask(String pathScript, String jobInit, String dataOut[]) throws IOException{
00177                 this.sendTask(pathScript, jobInit, dataOut, SciTaskInfo.NORMAL);
00178         }
00179
00180         public synchronized void sendTask(String pathScript, String jobInit, String dataOut[], int Priority) throws IOException{
00181                 logger.debug("->ScilabService In:sendTask");
00182
00183
00184                 SciTask sciTask = new SciTask("Task" + this.countIdTask++);
00185
00186                 File f = new File(pathScript);
00187
00188                 sciTask.setJob(f);
00189                 sciTask.setJobInit(jobInit);
00190
00191                 for(int i=0; i< dataOut.length; i++){
00192                         logger.debug("->ScilabService DataOut:sendTask:" + dataOut[i]);
00193                         if(dataOut[i].trim().equals("")){
00194                                 continue;
00195                         }
00196                         sciTask.addDataOut(new SciData(dataOut[i]));
00197                 }
00198
00199                 SciTaskInfo sciTaskInfo = new SciTaskInfo(sciTask);
00200                 sciTaskInfo.setFileScript(f);
00201
00202                 sciTaskInfo.setState(SciTaskInfo.PENDING);
00203                 sciTaskInfo.setPriority(Priority);
00204
00205                 this.listTaskWait.add(sciTaskInfo);
00206                 this.taskObservable.fireSciEvent(new SciEvent(sciTaskInfo));
00207                 notifyAll();
00208
00209         }
00210
00215         public synchronized void killTask(String idTask){
00216                 logger.debug("->ScilabService In:killTask:" + idTask);
00217
00218                 SciTaskInfo sciTaskInfo = this.mapTaskRun.remove(idTask);
00219
00220                 if(sciTaskInfo == null){
00221                         return;
00222                 }
00223
00224                 String idEngine = sciTaskInfo.getIdEngine();
00225                 SciEngineInfo sciEngineInfo = mapEngine.get(idEngine);
00226
00227
00228                 SciEngine sciEngine = sciEngineInfo.getSciEngine();
00229                 sciEngine.killWorker();
00230
00231                 BooleanWrapper isActivate = sciEngine.activate();
00232                 sciEngineInfo.setIsActivate(isActivate);
00233                 sciEngineInfo.setIdCurrentTask(null);
00234
00235                 sciTaskInfo.setState(SciTaskInfo.KILLED);
00236
00237                 this.listIdEngineFree.add(idEngine);
00238                 this.taskObservable.fireSciEvent(new SciEvent(sciTaskInfo));
00239         }
00240
00245         public synchronized void restartEngine(String idEngine){
00246                 logger.debug("->ScilabService In:restartEngine:" + idEngine);
00247
00248                 SciEngineInfo sciEngineInfo = this.mapEngine.get(idEngine);
00249
00250                 if(sciEngineInfo == null){
00251                         return;
00252                 }
00253
00254                 String idTask = sciEngineInfo.getIdCurrentTask();
00255                 SciTaskInfo sciTaskInfo;
00256
00257                 if(idTask != null){
00258                         sciTaskInfo = this.mapTaskRun.remove(idTask);
00259                         sciTaskInfo.setState(SciTaskInfo.KILLED);
00260                         sciEngineInfo.setIdCurrentTask(null);
00261                         this.listIdEngineFree.add(idEngine);
00262                         this.taskObservable.fireSciEvent(new SciEvent(sciTaskInfo));
00263                 }
00264
00265                 SciEngine sciEngine = sciEngineInfo.getSciEngine();
00266                 sciEngine.killWorker();
00267                 BooleanWrapper isActivate = sciEngine.activate();
00268                 sciEngineInfo.setIsActivate(isActivate);
00269         }
00270
00271
00276         public synchronized void cancelTask(String idTask){
00277                 logger.debug("->ScilabService In:cancelTask:" + idTask);
00278                 SciTaskInfo sciTaskInfo;
00279                 for(int i=0; i<this.listTaskWait.size(); i++){
00280                         sciTaskInfo = this.listTaskWait.get(i);
00281
00282                         if(idTask.equals(sciTaskInfo.getIdTask())){
00283                                 this.listTaskWait.remove(i);
00284                                 sciTaskInfo.setState(SciTaskInfo.CANCELLED);
00285                                 this.taskObservable.fireSciEvent(new SciEvent(sciTaskInfo));
00286                                 break;
00287                         }
00288                 }
00289         }
00290
00295         public synchronized void removeTask(String idTask){
00296                 logger.debug("->ScilabService In:removeTask:" + idTask);
00297                 SciTaskInfo sciTaskInfo = this.mapTaskEnd.remove(idTask);
00298                 sciTaskInfo.setState(SciTaskInfo.REMOVED);
00299                 this.taskObservable.fireSciEvent(new SciEvent(sciTaskInfo));
00300         }
00301
00302
00303         private synchronized void retrieveResults(){
00304                 logger.debug("->ScilabService In:retrieveResult");
00305                 SciResult sciResult;
00306                 SciTaskInfo sciTaskInfo;
00307                 String idEngine;
00308                 SciEngineInfo sciEngineInfo;
00309                 Object keys[];
00310
00311                 while (true) {
00312                         keys= this.mapTaskRun.keySet().toArray();
00313                         for (int i = 0; i < keys.length; i++) {
00314                                 sciTaskInfo = this.mapTaskRun.get(keys[i]);
00315                                 sciResult = sciTaskInfo.getSciResult();
00316                                 if (!ProActive.isAwaited(sciResult)) {
00317                                         logger.debug("->ScilabService loop:retrieveResult:" + keys[i]);
00318
00319                                         this.mapTaskRun.remove(keys[i]);
00320                                         sciTaskInfo.setState(sciResult.getState());
00321
00322                                         idEngine = sciTaskInfo.getIdEngine();
00323                                         sciEngineInfo = mapEngine.get(idEngine);
00324
00325                                         sciEngineInfo.setIdCurrentTask(null);
00326                                         this.listIdEngineFree.add(idEngine);
00327                                         sciTaskInfo.setDateEnd();
00328                                         this.mapTaskEnd.put(sciTaskInfo.getIdTask(), sciTaskInfo);
00329                                         this.taskObservable.fireSciEvent(new SciEvent(sciTaskInfo));
00330                                         notifyAll();
00331                                 }
00332                         }
00333                         try {
00334                                 wait(1000);
00335                         } catch (InterruptedException e) {
00336                         }
00337                 }
00338         }
00339
00340         private SciTaskInfo getNextTask(){
00341                 logger.debug("->ScilabService loop:getNextTask");
00342                 SciTaskInfo sciTaskInfo;
00343
00344                 if (this.listTaskWait.size() == 0) return null;
00345
00346                 for(int i=0; i<this.listTaskWait.size(); i++){
00347                         sciTaskInfo = this.listTaskWait.get(i);
00348
00349                         if(sciTaskInfo.getPriority() == SciTaskInfo.HIGH){
00350                                 return this.listTaskWait.remove(i);
00351                         }
00352                 }
00353
00354                 for(int i=0; i<this.listTaskWait.size(); i++){
00355                         sciTaskInfo = this.listTaskWait.get(i);
00356
00357                         if(sciTaskInfo.getPriority() == SciTaskInfo.NORMAL){
00358                                 return this.listTaskWait.remove(i);
00359                         }
00360                 }
00361
00362                 return this.listTaskWait.remove(0);
00363         }
00364
00365
00366         private SciEngineInfo getNextEngine(){
00367                 logger.debug("->ScilabService loop:getNextEngine");
00368                 String idEngine;
00369                 SciEngineInfo sciEngineInfo;
00370                 BooleanWrapper isActivate;
00371                 int i = 0;
00372                 int count = this.listIdEngineFree.size();
00373
00374                 while (i<count){
00375                         idEngine = this.listIdEngineFree.remove(0);
00376                         sciEngineInfo = mapEngine.get(idEngine);
00377                         isActivate = sciEngineInfo.getIsActivate();
00378                         logger.debug("->ScilabService test0:getNextEngine:" + idEngine);
00379                         if(ProActive.isAwaited(isActivate)){
00380                                 logger.debug("->ScilabService test1:getNextEngine:" + idEngine);
00381                                 this.listIdEngineFree.add(idEngine);
00382                         }
00383                         else if(isActivate.booleanValue()){
00384                                 logger.debug("->ScilabService test2:getNextEngine:" + idEngine);
00385                                 return sciEngineInfo;
00386                         }else{
00387                                 logger.debug("->ScilabService test3:getNextEngine:" + idEngine);
00388                                 this.listIdEngineFree.add(idEngine);
00389                                 SciEngine sciEngine = sciEngineInfo.getSciEngine();
00390                                 sciEngineInfo.setIsActivate(sciEngine.activate());
00391                         }
00392                         i++;
00393                 }
00394                 return null;
00395         }
00396
00397
00398         private synchronized void executeTasks(){
00399                 logger.debug("->ScilabService In:executeTasks");
00400
00401                 SciTaskInfo sciTaskInfo;
00402                 SciEngineInfo sciEngineInfo;
00403
00404
00405                 while(true){
00406                         if (this.listTaskWait.size() == 0) {
00407                                 try {
00408                                         logger.debug("->ScilabService test0:executeTask");
00409                                         wait();
00410                                 } catch (InterruptedException e) {
00411                                 }
00412
00413                                 continue;
00414                         }
00415
00416                         sciEngineInfo = this.getNextEngine();
00417                         if(sciEngineInfo == null){
00418                                 try {
00419                                         logger.debug("->ScilabService test1:executeTask");
00420                                         wait(1000);
00421                                 } catch (InterruptedException e) {
00422                                 }
00423                                 continue;
00424                         }
00425
00426                         sciTaskInfo = this.getNextTask();
00427                         if(sciTaskInfo == null){
00428                                 try {
00429                                         logger.debug("->ScilabService test2:executeTask");
00430                                         wait(1000);
00431                                 } catch (InterruptedException e) {
00432                                 }
00433                                 continue;
00434                         }
00435
00436                         this.executeTask(sciEngineInfo, sciTaskInfo);
00437                 }
00438         }
00439
00440         private synchronized void executeTask(SciEngineInfo sciEngineInfo, SciTaskInfo sciTaskInfo) {
00441                 logger.debug("->ScilabService In:executeTask");
00442                 SciResult sciResult;
00443                 SciEngine sciEngine;
00444
00445                 sciEngineInfo.setIdCurrentTask(sciTaskInfo.getIdTask());
00446
00447                 sciEngine = sciEngineInfo.getSciEngine();
00448                 sciTaskInfo.setIdEngine(sciEngineInfo.getIdEngine());
00449                 sciTaskInfo.setState(SciTaskInfo.RUNNING);
00450                 sciResult = sciEngine.execute(sciTaskInfo.getSciTask());
00451
00452                 sciTaskInfo.setSciResult(sciResult);
00453                 this.mapTaskRun.put(sciTaskInfo.getIdTask(), sciTaskInfo);
00454                 this.taskObservable.fireSciEvent(new SciEvent(sciTaskInfo));
00455                 notifyAll();
00456         }
00457
00458
00459         public synchronized void addEventListenerTask(SciEventListener evtListener){
00460                 taskObservable.addSciEventListener(evtListener);
00461         }
00462
00463         public synchronized void addEventListenerEngine(SciEventListener evtListener){
00464                 engineObservable.addSciEventListener(evtListener);
00465         }
00466
00467         public synchronized void removeEventListenerTask(SciEventListener evtListener){
00468                 taskObservable.removeSciEventListener(evtListener);
00469         }
00470
00471         public synchronized void removeAllEventListenerTask(){
00472                 taskObservable = null;
00473                 taskObservable = new SciEventSource();
00474         }
00475
00476         public synchronized void removeAllEventListenerEngine(){
00477                 engineObservable = null;
00478                 engineObservable = new SciEventSource();
00479         }
00480
00481         public synchronized void removeEventListenerEngine(SciEventListener evtListener){
00482                 engineObservable.removeSciEventListener(evtListener);
00483         }
00484
00489         public synchronized SciTaskInfo getTaskEnd(String idTask){
00490                 return mapTaskEnd.get(idTask);
00491         }
00492
00496         public synchronized int getNbEngine(){
00497                 return mapEngine.size();
00498         }
00499
00504         public synchronized HashMap<String, SciTaskInfo> getMapTaskEnd() {
00505                 return (HashMap<String, SciTaskInfo>) mapTaskEnd.clone();
00506         }
00507
00508
00512         public synchronized HashMap<String, SciTaskInfo> getMapTaskRun() {
00513                 return  (HashMap<String, SciTaskInfo>) mapTaskRun.clone();
00514         }
00515
00519         public synchronized HashMap<String, SciEngineInfo> getMapEngine() {
00520                 return (HashMap<String, SciEngineInfo>) mapEngine.clone();
00521         }
00522
00526         public synchronized ArrayList<SciTaskInfo> getListTaskWait() {
00527                 return (ArrayList<SciTaskInfo>) listTaskWait.clone();
00528         }
00529
00534         public synchronized void exit(){
00535                 logger.debug("->ScilabService In:exit");
00536                 SciEngineInfo sciEngineInfo;
00537                 SciEngine sciEngine;
00538
00539                 Object keys[] = mapEngine.keySet().toArray();
00540                 for(int i=0; i<keys.length; i++){
00541                         sciEngineInfo = mapEngine.get(keys[i]);
00542                         sciEngine = sciEngineInfo.getSciEngine();
00543                         try{
00544                         sciEngine.exit();
00545                         }catch(RuntimeException e ){
00546
00547                         }
00548                 }
00549         }
00550 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
