org/objectweb/proactive/ext/scilab/test/SciTestSeqPi.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.scilab.test;
00032 import java.io.BufferedReader;
00033 import java.io.BufferedWriter;
00034 import java.io.FileReader;
00035 import java.io.FileWriter;
00036 import java.io.PrintWriter;
00037
00038 import javasci.SciData;
00039 import javasci.Scilab;
00040
00041 import org.objectweb.proactive.ext.scilab.util.SciMath;
00042
00043 class  SciTestSeqPi {
00044
00045     public static void main(String[] args) throws Exception{
00046
00047        if(args.length != 2){
00048            System.out.println("Invalid number of parameter : " + args.length);
00049            return;
00050        }
00051
00052        BufferedReader reader = new BufferedReader(new FileReader(args[0]));
00053        PrintWriter writer = new PrintWriter(new BufferedWriter(new FileWriter(args[1])));
00054
00055        int precision;
00056        String line;
00057        double startTime;
00058        double endTime;
00059
00060        while((line = reader.readLine()) != null){
00061
00062            if(line.trim().startsWith("#"))
00063                                 continue;
00064
00065            if(line.trim().equals(""))
00066                   break;
00067
00068            precision = Integer.parseInt(line);
00069            startTime = System.currentTimeMillis();
00070            Scilab.exec(SciMath.formulaPi("pi", 0, precision));
00071            SciData sciPi = (SciData) Scilab.receiveDataByName("pi");
00072            endTime = System.currentTimeMillis();
00073
00074            System.out.println(sciPi);
00075            writer.println(precision  + " " +(endTime - startTime));
00076        }
00077
00078        reader.close();
00079        writer.close();
00080    }
00081 }
00082
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
