org/objectweb/proactive/ext/scilab/test/SciTestSeqMult.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.scilab.test;
00032
00033 import java.io.BufferedReader;
00034 import java.io.BufferedWriter;
00035 import java.io.FileReader;
00036 import java.io.FileWriter;
00037 import java.io.PrintWriter;
00038
00039 import javasci.SciData;
00040 import javasci.SciDoubleMatrix;
00041 import javasci.Scilab;
00042
00043 public class SciTestSeqMult {
00044
00045         public static void main(String[] args) throws Exception {
00046
00047                 if (args.length != 2) {
00048                         System.out.println("Invalid number of parameter : " + args.length);
00049                         return;
00050                 }
00051
00052                 BufferedReader reader = new BufferedReader(new FileReader(args[0]));
00053                 PrintWriter writer = new PrintWriter(new BufferedWriter(new FileWriter(
00054                                 args[1])));
00055
00056                 double[] m1;
00057                 double[] m2;
00058
00059                 String line;
00060                 int nbRow;
00061                 int nbCol;
00062
00063                 double startTime;
00064                 double endTime;
00065
00066                 while ((line = reader.readLine()) != null) {
00067                         if(line.trim().startsWith("#"))
00068                                 continue;
00069
00070                         if (line.trim().equals(""))
00071                                 break;
00072
00073                         nbRow = Integer.parseInt(line);
00074                         nbCol = Integer.parseInt(line);
00075
00076                         m1 = new double[nbRow * nbCol];
00077                         m2 = new double[nbRow * nbCol];
00078                         for (int i = 0; i < nbRow * nbCol; i++) {
00079                                 m1[i] = Math.random() * 10.0;
00080                                 m2[i] = Math.random() * 10.0;
00081                         }
00082
00083                         startTime = System.currentTimeMillis();
00084                         Scilab.sendData(new SciDoubleMatrix("A", nbRow, nbCol, m1));
00085                         Scilab.sendData(new SciDoubleMatrix("B", nbRow, nbCol, m2));
00086                         Scilab.sendData(new SciData("C"));
00087                         Scilab.exec("C=A*B;");
00088
00089                         SciData sciResult = Scilab.receiveDataByName("C");
00090                         endTime = System.currentTimeMillis();
00091
00092                         System.out.println(endTime - startTime);
00093                         //System.out.println(sciResult);
00094                 writer.println(nbRow  + " " + (endTime - startTime));
00095                 }
00096
00097                 reader.close();
00098                 writer.close();
00099         }
00100 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
