org/objectweb/proactive/ext/scilab/test/SciTestSeqMandel.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.scilab.test;
00032
00033 import java.io.BufferedReader;
00034 import java.io.BufferedWriter;
00035 import java.io.FileReader;
00036 import java.io.FileWriter;
00037 import java.io.PrintWriter;
00038
00039 import javasci.SciData;
00040 import javasci.Scilab;
00041
00042 import org.objectweb.proactive.ext.scilab.util.SciMath;
00043
00044 public class SciTestSeqMandel {
00045
00046         public static void main(String[] args) throws Exception {
00047
00048                 if(args.length !=8){
00049                         System.out.println("Invalid number of parameter : " + args.length);
00050                         return;
00051                 }
00052
00053                 BufferedReader reader = new BufferedReader(new FileReader(args[6]));
00054                 PrintWriter writer = new PrintWriter(new BufferedWriter(new FileWriter(args[7])));
00055
00056                 int xres = Integer.parseInt(args[0]);
00057                 int yres = Integer.parseInt(args[1]);
00058                 double xmin = Double.parseDouble(args[2]) ;
00059                 double xmax = Double.parseDouble(args[3]) ;
00060                 double ymin = Double.parseDouble(args[4]) ;
00061                 double ymax = Double.parseDouble(args[5]) ;
00062                 int precision;
00063
00064                 String line;
00065                 double startTime;
00066                 double endTime;
00067
00068                 for(int i = 0; (line = reader.readLine()) != null; i++){
00069
00070                         if(line.trim().startsWith("#"))
00071                                 continue;
00072
00073                         if(line.trim().equals(""))
00074                                 break;
00075
00076                         precision = Integer.parseInt(line.trim());
00077
00078                         startTime = System.currentTimeMillis();
00079                         Scilab.exec(SciMath.formulaMandelbrot("Fract", xres, yres, xmin, xmax, ymin, ymax, precision));
00080                         SciData sciFract = (SciData) Scilab.receiveDataByName("Fract");
00081                         endTime = System.currentTimeMillis();
00082
00083                         System.out.println(xres +" " + yres + " " + precision + " " + (endTime - startTime));
00084                         writer.println(xres +" " + yres + " " + precision + " " + (endTime - startTime));
00085                 }
00086
00087                 reader.close();
00088                 writer.close();
00089         }
00090
00091 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
