org/objectweb/proactive/ext/scilab/test/SciTestParMandel.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.scilab.test;
00032
00033 import java.io.BufferedReader;
00034 import java.io.BufferedWriter;
00035 import java.io.FileReader;
00036 import java.io.FileWriter;
00037 import java.io.PrintWriter;
00038
00039 import org.objectweb.proactive.ext.scilab.monitor.ScilabService;
00040 import org.objectweb.proactive.ext.scilab.util.FutureDoubleMatrix;
00041 import org.objectweb.proactive.ext.scilab.util.GridMatrix;
00042
00043 public class SciTestParMandel {
00044
00045         public static void main(String[] args) throws Exception{
00046                 ScilabService service = new  ScilabService();
00047
00048                 if(args.length !=11){
00049                         System.out.println("Invalid number of parameter : " + args.length);
00050                         return;
00051                 }
00052
00053                 int nbEngine = Integer.parseInt(args[2]);
00054                 service.deployEngine(args[0], args[1], nbEngine);
00055                 Thread.sleep(nbEngine * 4000);
00056
00057                 BufferedReader reader = new BufferedReader(new FileReader(args[9]));
00058                 PrintWriter writer = new PrintWriter(new BufferedWriter(new FileWriter(args[10])));
00059
00060                 int xres = Integer.parseInt(args[3]);
00061                 int yres = Integer.parseInt(args[4]);
00062                 double xmin = Double.parseDouble(args[5]) ;
00063                 double xmax = Double.parseDouble(args[6]) ;
00064                 double ymin = Double.parseDouble(args[7]) ;
00065                 double ymax = Double.parseDouble(args[8]) ;
00066                 int precision;
00067                 int nbBloc;
00068
00069                 String line;
00070                 String arrayLine[];
00071                 FutureDoubleMatrix mandelResult;
00072
00073                 double startTime;
00074                 double endTime;
00075                 double result[];
00076
00077                 for(int i = 0; (line = reader.readLine()) != null; i++){
00078
00079                         if(line.trim().startsWith("#"))
00080                                 continue;
00081
00082                         if(line.trim().equals(""))
00083                                 break;
00084
00085                         arrayLine = line.split(" ");
00086
00087                         precision = Integer.parseInt(arrayLine[1].trim());
00088                         nbBloc = Integer.parseInt(arrayLine[0].trim());
00089
00090                         startTime = System.currentTimeMillis();
00091                         mandelResult = GridMatrix.calMandelbrot(service, "mandel" + i, xres, yres, xmin, xmax, ymin, ymax, precision, nbBloc);
00092                         result= mandelResult.get();
00093                         service.removeAllEventListenerTask();
00094                         endTime = System.currentTimeMillis();
00095
00096                         System.out.println(nbEngine + " " + xres +" " + yres + " " + precision + " " + nbBloc + " " + (endTime - startTime));
00097                         writer.println(nbEngine + " " + xres +" " + yres + " " + precision + " " + nbBloc + " " + (endTime - startTime));
00098
00099                         /*for(int k=0; k<mandelResult.getNbRow(); k++){
00100                                 System.out.println("");
00101                                 for(int j=0; j<mandelResult.getNbCol(); j++){
00102                                         System.out.print(result[k*mandelResult.getNbCol() + j]  + " ");
00103                                 }
00104                         }*/
00105                 }
00106
00107                 reader.close();
00108                 writer.close();
00109                 service.exit();
00110                 System.exit(0);
00111
00112         }
00113
00114 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
