org/objectweb/proactive/ext/scilab/test/SciTest4.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.scilab.test;
00032
00033 import java.io.BufferedReader;
00034 import java.io.BufferedWriter;
00035 import java.io.FileReader;
00036 import java.io.FileWriter;
00037 import java.io.PrintWriter;
00038
00039 import javasci.SciData;
00040 import javasci.SciDoubleMatrix;
00041
00042 import org.objectweb.proactive.ProActive;
00043 import org.objectweb.proactive.ext.scilab.SciEngineWorker;
00044 import org.objectweb.proactive.ext.scilab.SciResult;
00045 import org.objectweb.proactive.ext.scilab.SciTask;
00046
00047 public class SciTest4 {
00048
00052         public static void main(String[] args) throws Exception {
00053                 if (args.length != 2) {
00054                         System.out.println("Invalid number of parameter : " + args.length);
00055                         return;
00056                 }
00057
00058
00059                 SciEngineWorker sciEngineWorker  =  (SciEngineWorker) ProActive.newActive(SciEngineWorker.class.getName(), null);
00060
00061                 BufferedReader reader = new BufferedReader(new FileReader(args[0]));
00062                 PrintWriter writer = new PrintWriter(new BufferedWriter(new FileWriter(args[1])));
00063
00064                 double[] m1;
00065                 double[] m2;
00066
00067                 String line;
00068                 int nbRow;
00069                 int nbCol;
00070
00071                 double startTime;
00072                 double endTime;
00073
00074                 while ((line = reader.readLine()) != null) {
00075                         if(line.trim().startsWith("#"))
00076                                 continue;
00077
00078                         if (line.trim().equals(""))
00079                                 break;
00080
00081                         nbRow = Integer.parseInt(line);
00082                         nbCol = Integer.parseInt(line);
00083
00084                         m1 = new double[nbRow * nbCol];
00085                         m2 = new double[nbRow * nbCol];
00086                         for (int i = 0; i < nbRow * nbCol; i++) {
00087                                 m1[i] = (double) (Math.random() * 10);
00088                                 m2[i] = (double) (Math.random() * 10);
00089                         }
00090
00091                         SciDoubleMatrix sciMatrix1 = new SciDoubleMatrix("M1", nbRow, nbCol, m1);
00092                         SciDoubleMatrix sciMatrix2 = new SciDoubleMatrix("M2", nbRow, nbCol, m2);
00093                         SciData sciMatrix3 = new SciData("M3");
00094
00095                         SciTask sciTask = new SciTask("mult");
00096                         sciTask.addDataIn(sciMatrix1);
00097                         sciTask.addDataIn(sciMatrix2);
00098                         sciTask.addDataOut(sciMatrix3);
00099                         sciTask.setJob(sciMatrix3.getName() + "=" + sciMatrix1.getName() + "*" + sciMatrix1.getName() + ";");
00100
00101                         startTime = System.currentTimeMillis();
00102
00103                         SciResult sciResult = sciEngineWorker.execute(sciTask);
00104                         sciMatrix3 = (SciData) sciResult.getList().get(0);
00105
00106                         endTime = System.currentTimeMillis();
00107
00108                         //System.out.println(sciMatrix3);
00109                 writer.println(nbRow  + " " + (endTime - startTime));
00110                 }
00111
00112                 reader.close();
00113                 writer.close();
00114
00115                 System.exit(0);
00116         }
00117
00118 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
