00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.ext.scilab.test;
00032
00033 import java.util.HashMap;
00034 import java.util.Vector;
00035
00036 import javasci.SciData;
00037 import javasci.SciDoubleMatrix;
00038
00039 import org.objectweb.proactive.ProActive;
00040 import org.objectweb.proactive.core.util.wrapper.BooleanWrapper;
00041 import org.objectweb.proactive.ext.scilab.SciDeployEngine;
00042 import org.objectweb.proactive.ext.scilab.SciEngine;
00043 import org.objectweb.proactive.ext.scilab.SciResult;
00044 import org.objectweb.proactive.ext.scilab.SciTask;
00045
00046 public class SciTest3 {
00047 private String arrayEngine[];
00048 private HashMap mapEngine;
00049 private int countEngine = 0;
00050
00051 public SciTest3(String nameVN, String pathDescriptor, String[] arrayEngine){
00052
00053 Vector<BooleanWrapper> listStateEngine = new Vector<BooleanWrapper>();
00054 this.arrayEngine = arrayEngine;
00055 SciData m1 = new SciDoubleMatrix("a",1, 1, new double[]{10});
00056 SciData m2 = new SciDoubleMatrix("b",1, 1, new double[]{20});
00057 SciData m3 = new SciData("x");
00058 SciData m4 = new SciData("y");
00059
00060
00061 mapEngine = SciDeployEngine.deploy(nameVN, pathDescriptor, arrayEngine);
00062
00063
00064 for(int i=0; i<mapEngine.size(); i++){
00065 listStateEngine.add(((SciEngine) mapEngine.get(arrayEngine[i])).activate());
00066 }
00067
00068 ProActive.waitForAll(listStateEngine);
00069
00070 for(int i=0; i<mapEngine.size(); i++){
00071 if(!listStateEngine.get(i).booleanValue()){
00072 System.out.println("->Activation Error");
00073 return;
00074 }
00075 }
00076
00077
00078 SciEngine sciEngine;
00079
00080 SciTask task1 = new SciTask("id1");
00081 task1.addDataIn(m1);
00082 task1.addDataIn(m2);
00083 task1.addDataOut(m3);
00084 task1.setJob("x = a+b;");
00085
00086 sciEngine = (SciEngine) mapEngine.get(this.getNextEngine());
00087
00088
00089 SciResult result1 = sciEngine.execute(task1);
00090
00091 SciTask task3 = new SciTask("id3");
00092 task3.addDataIn(m1);
00093 task3.addDataOut(m1);
00094 task3.setJob("a = a*2;");
00095
00096 sciEngine = (SciEngine) mapEngine.get(this.getNextEngine());
00097
00098 SciResult result3 = sciEngine.execute(task3);
00099
00100
00101 SciTask task2 = new SciTask("id2");
00102
00103
00104 task2.addDataIn(result1.get("x"));
00105 task2.addDataIn(m2);
00106 task2.addDataOut(m4);
00107 task2.setJob("y = x+b;");
00108
00109 sciEngine = (SciEngine) mapEngine.get(this.getNextEngine());
00110
00111 SciResult result2 = sciEngine.execute(task2);
00112
00113 System.out.println(result1.get("x").toString());
00114 System.out.println(result3.get("a").toString());
00115 System.out.println(result2.get("y").toString());
00116
00117
00118 System.exit(0);
00119 }
00120
00121
00122
00123 public String getNextEngine(){
00124 countEngine++;
00125 if(countEngine == mapEngine.size()){
00126 countEngine = 0;
00127 }
00128 return arrayEngine[countEngine];
00129 }
00130
00131 public static void main(String[] args) {
00132 if(args.length != 3){
00133 System.out.println("Invalid number of parameter : " + args.length);
00134 return;
00135 }
00136
00137 int nbEngine = Integer.parseInt(args[2]);
00138 String arrayId[] = new String[nbEngine];
00139
00140 for(int i=0; i< nbEngine; i++){
00141 arrayId[i] = "Scilab" + i;
00142 }
00143
00144 new SciTest3(args[0], args[1], arrayId);
00145 }
00146 }
