org/objectweb/proactive/ext/scilab/util/SciMath.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.scilab.util;
00032
00033 public class SciMath {
00034
00035         public static String formulaPi(String pi, int iBloc, int  sizeBloc){
00036                 return
00037                     pi + " = 0;" +
00038                 "j = " + iBloc * sizeBloc + ";" +
00039                     "n = j + " + sizeBloc + ";" +
00040                     "for i = j:n, " +
00041                     pi + " = " + pi + " + ((-1)**i/(2**(10*i))* (- (2**5/(4*i+1)) - (1/(4*i+3)) + (2**8/(10*i+1)) - (2**6/(10*i+3)) - (2**2/(10*i+5))  - (2**2/(10*i+7)) + (1/(10*i+9))));" +
00042                     "end;" +
00043                     pi + " = " + pi + "/(2**6);";
00044         }
00045
00046         public static String formulaMandelbrot(String name, int nbRow, int nbCol, double xmin, double xmax, double ymin, double ymax, int precision){
00047                 return
00048                 name + "("+ nbRow +","+ nbCol+ ") = -1; "+
00049                 "xres = " + (xmax - xmin)/nbCol + "; "+
00050                 "yres = " + (ymax - ymin)/nbRow + "; "+
00051                 "a = " + xmin + "; "+
00052                 "for i = 1:" + nbCol + ", " +
00053                     "a = a + xres; " +
00054                     "b = " + ymin + "; "+
00055                         "for j = 1:" + nbRow + ", " +
00056                                 "b = b + yres; " +
00057                             "x = 0; " +
00058                                 "y = 0; " +
00059                                 "for k = 0:" + precision + ", " +
00060                                         "tmp = x; "+
00061                                         "x = (x**2) - (y**2) + a; "+
00062                                         "y = (2 * tmp * y) + b; " +
00063                                         "tmp = (x**2) + (y**2); "+
00064                                         "if tmp < 4 then " +
00065                                                 name + "(j,i) = k; "+
00066                                         "end, "+
00067                                 "end; " +
00068                         "end; " +
00069                 "end; ";
00070         }
00071 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
