00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.ext.scilab;
00032
00033 import java.io.BufferedWriter;
00034 import java.io.File;
00035 import java.io.FileWriter;
00036 import java.io.IOException;
00037 import java.io.Serializable;
00038 import java.util.ArrayList;
00039
00040 import javasci.SciData;
00041 import javasci.Scilab;
00042
00043 import org.apache.log4j.Logger;
00044 import org.objectweb.proactive.core.util.log.Loggers;
00045 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00046
00047 public class SciEngineWorker implements Serializable{
00048 private SciTask sciTask;
00049 private SciResult sciResult;
00050 private long dateStart;
00051 private long dateEnd;
00052 private boolean isStateFull = false;
00053 private static Logger logger = ProActiveLogger.getLogger(Loggers.SCILAB_TASK);
00054 private static SciEngineWorker sciEngineWorker;
00055
00056
00057 public SciEngineWorker(){
00058 Scilab.init();
00059 }
00060
00066 public SciResult execute(SciTask sciTask){
00067 logger.debug("->SciEngineTask In:execute:" + sciTask.getId());
00068 this.sciTask = sciTask;
00069 this.sciResult = new SciResult(sciTask.getId());
00070
00071 this.setListDataToScilab();
00072
00073 this.dateStart = System.currentTimeMillis();
00074 try{
00075 if(executeJob()){
00076 getListDataToScilab();
00077 this.sciResult.setState(SciResult.SUCCESS);
00078 }else{
00079 this.sciResult.setState(SciResult.ABORT);
00080 System.out.println("->SciEngine test:execute\n");
00081 }
00082 }catch(Exception e){
00083 e.printStackTrace();
00084 this.sciResult.setState(SciResult.ABORT);
00085 }
00086
00087 this.dateEnd = System.currentTimeMillis();
00088 this.sciResult.setTimeExecution(this.dateEnd - this.dateStart);
00089 return sciResult;
00090 }
00091
00096 private void setListDataToScilab(){
00097 ArrayList listData = this.sciTask.getListDataIn();
00098
00099 SciData data;
00100 for (int i = 0; i < listData.size(); i++) {
00101 data = (SciData) listData.get(i);
00102 Scilab.sendData(data);
00103 }
00104 }
00105
00110 private void clearScilab(){
00111 ArrayList listData = this.sciTask.getListDataOut();
00112 SciData data;
00113 Scilab.exec("clearglobal();");
00114 for (int i = 0; i < listData.size(); i++) {
00115 data = (SciData) listData.get(i);
00116 Scilab.exec("clear " + data.getName() + ";");
00117 }
00118 }
00119
00124 private void getListDataToScilab(){
00125 ArrayList listData = this.sciTask.getListDataOut();
00126 SciData data;
00127 for (int i = 0; i < listData.size(); i++) {
00128 data = (SciData) listData.get(i);
00129 data = Scilab.receiveDataByName(data.getName());
00130 this.sciResult.add(data);
00131 }
00132
00133 if(!isStateFull){
00134 clearScilab();
00135 }
00136 }
00137
00141 private boolean executeJob(){
00142 String job = sciTask.getJobInit() + "\n" + sciTask.getJob();
00143 BufferedWriter out;
00144 File temp;
00145 boolean isValid;
00146 try {
00147 temp = File.createTempFile("scilab", ".sce");
00148 temp.deleteOnExit();
00149 out = new BufferedWriter(new FileWriter(temp));
00150 out.write(job);
00151 out.close();
00152 logger.debug("->SciEngineTask:executeJob:test1:" + temp.getAbsolutePath());
00153 isValid = Scilab.exec("exec(''"+temp.getAbsolutePath()+"'');");
00154 } catch (IOException e) {
00155 isValid = false;
00156 }
00157
00158 return isValid;
00159 }
00160
00161 public synchronized static SciResult executeTask(SciTask sciTask){
00162 if(sciEngineWorker == null){
00163 sciEngineWorker = new SciEngineWorker();
00164 }
00165 return sciEngineWorker.execute(sciTask);
00166 }
00167
00168 public void exit(){
00169 System.exit(0);
00170 }
00171
00172 }
