org/objectweb/proactive/ext/scilab/monitor/SciEngineInfo.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.scilab.monitor;
00032
00033 import org.objectweb.proactive.ext.scilab.SciEngine;
00034
00035 import org.objectweb.proactive.ProActive;
00036 import org.objectweb.proactive.core.util.wrapper.BooleanWrapper;
00037
00038
00042 public class SciEngineInfo {
00043         private String idEngine;
00044         private String idCurrentTask;
00045         private SciEngine sciEngine;
00046         private BooleanWrapper isActivate; //a future to test if the Scilab engine is activated
00047
00048         public SciEngineInfo (String idEngine, SciEngine sciEngine, BooleanWrapper isActivate){
00049                 this.idEngine = idEngine;
00050                 this.sciEngine = sciEngine;
00051                 this.isActivate = isActivate;
00052         }
00053
00054         public String getIdEngine() {
00055                 return idEngine;
00056         }
00057
00058         public SciEngine getSciEngine() {
00059                 return sciEngine;
00060         }
00061
00062         public String getSciEngineUrl(){
00063                 return ProActive.getActiveObjectNodeUrl(this.sciEngine);
00064         }
00065
00066         public BooleanWrapper getIsActivate() {
00067                 return isActivate;
00068         }
00069
00070         public void setIsActivate(BooleanWrapper isActivate) {
00071                 this.isActivate = isActivate;
00072         }
00073
00074         public String getIdCurrentTask() {
00075                 return idCurrentTask;
00076         }
00077
00078         public void setIdCurrentTask(String idCurrentTask) {
00079                 this.idCurrentTask = idCurrentTask;
00080         }
00081 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
