00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.ext.scilab;
00032
00033 import java.io.IOException;
00034 import java.util.HashMap;
00035
00036 import org.apache.log4j.Logger;
00037 import org.objectweb.proactive.ActiveObjectCreationException;
00038 import org.objectweb.proactive.ProActive;
00039 import org.objectweb.proactive.core.ProActiveException;
00040 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00041 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00042 import org.objectweb.proactive.core.node.Node;
00043 import org.objectweb.proactive.core.node.NodeException;
00044 import org.objectweb.proactive.core.util.log.Loggers;
00045 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00046
00053 public class SciDeployEngine {
00054         private static Logger logger = ProActiveLogger.getLogger(Loggers.SCILAB_DEPLOY);
00055         private static HashMap<String, Node> mapNode = new HashMap<String, Node>();
00056
00061         public static String[] getListVirtualNode(String pathDescriptor){
00062                 logger.debug("->SciDeployEngine In:getListVirtualNode:" + pathDescriptor);
00063
00064                 ProActiveDescriptor desc;
00065                 VirtualNode arrayVn[];
00066                 String arrayNameVn[] = null;
00067                 try {
00068                         desc = ProActive.getProactiveDescriptor("file:" + pathDescriptor);
00069                         arrayVn = desc.getVirtualNodes();
00070                         arrayNameVn = new String[arrayVn.length];
00071
00072                         for(int i=0; i<arrayVn.length; i++){
00073                                 arrayNameVn[i] = arrayVn[i].getName();
00074                         }
00075
00076                 } catch (ProActiveException e) {
00077                         e.printStackTrace();
00078                 }
00079
00080                 return arrayNameVn;
00081         }
00082
00083         public static synchronized int getNbMappedNodes(String nameVirtualNode, String pathDescriptor){
00084                 ProActiveDescriptor desc;
00085                 VirtualNode vn;
00086                 try {
00087                         desc = ProActive.getProactiveDescriptor("file:" + pathDescriptor);
00088                         vn = desc.getVirtualNode(nameVirtualNode);
00089                         return vn.getNbMappedNodes();
00090                 }catch (ProActiveException e) {
00091                         e.printStackTrace();
00092                 }
00093                 return -1;
00094         }
00095
00102         public synchronized static HashMap<String, SciEngine> deploy(String nameVirtualNode, String pathDescriptor, String[] arrayIdEngine){
00103                 logger.debug("->SciDeployEngine In:deploy:" + pathDescriptor);
00104                 ProActiveDescriptor desc;
00105                 VirtualNode vn;
00106                 Node nodes[];
00107                 SciEngine sciEngine;
00108                 HashMap<String, SciEngine> mapEngine = new HashMap<String, SciEngine>();
00109
00110                 try {
00111                         desc = ProActive.getProactiveDescriptor("file:" + pathDescriptor);
00112                         vn = desc.getVirtualNode(nameVirtualNode);
00113                         vn.activate();
00114                         nodes = vn.getNodes();
00115
00116                         int length = (nodes.length >arrayIdEngine.length)? arrayIdEngine.length:nodes.length;
00117
00118                         for(int i=0; i<length; i++){
00119                                 sciEngine = deploy(arrayIdEngine[i], nodes[i]);
00120                                 mapEngine.put(arrayIdEngine[i], sciEngine);
00121                         }
00122                 } catch (ProActiveException e) {
00123                         e.printStackTrace();
00124                 }
00125                 return mapEngine;
00126         }
00127
00136         private synchronized static SciEngine deploy(String idEngine, Node currentNode) throws ActiveObjectCreationException, NodeException {
00137                 Object param[] = new Object[]{idEngine};
00138                 SciEngine sciEngine  = (SciEngine) ProActive.newActive(SciEngine.class.getName(), param, currentNode);
00139                 mapNode.put(idEngine, currentNode);
00140                 try{
00141                         ProActive.setImmediateService(sciEngine, "killWorker");
00142                         ProActive.setImmediateService(sciEngine, "exit");
00143                 }catch(IOException e){
00144                         e.printStackTrace();
00145                 }
00146                 return sciEngine;
00147         }
00148
00149
00158         public static SciEngine deploy(String idEngine) throws ActiveObjectCreationException, NodeException {
00159                 logger.debug("->SciDeployEngine In:deploy");
00160                 Object param[] = new Object[]{idEngine};
00161                 SciEngine sciEngine  =  (SciEngine) ProActive.newActive(SciEngine.class.getName(), param);
00162                 try{
00163                         ProActive.setImmediateService(sciEngine, "killWorker");
00164                         ProActive.setImmediateService(sciEngine, "exit");
00165                 }catch(IOException e){
00166                         e.printStackTrace();
00167                 }
00168                 return sciEngine;
00169         }
00170
00171         public static Node getEngineNode(String idEngine){
00172                 return mapNode.get(idEngine);
00173         }
00174 }
