00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.ssh;
00032
00033 import java.io.InputStream;
00034
00035 import com.jcraft.jsch.Channel;
00036 import com.jcraft.jsch.ChannelExec;
00037 import com.jcraft.jsch.JSch;
00038 import com.jcraft.jsch.Session;
00039
00051 public class SSHClient
00052 {
00053
00058     private static String buildCmdLine(String[] args, int index)
00059     {
00060         String cmd = "";
00061
00062         for (int i = index; i < args.length; i++)
00063         {
00064             cmd += " " + args[i];
00065         }
00066
00067         return cmd;
00068     }
00069
00070     public static void main(String[] args)
00071     {
00072
00073         if (args.length < 2)
00074         {
00075             System.err.println("not enought arguments\n" + "usage : " + SSHClient.class.getName()
00076                                + " username@host [-p password] cmdline");
00077             System.exit(1);
00078         }
00079
00080
00081
00082
00083
00084
00085         try
00086         {
00087
00088             String host = "";
00089             String password = "";
00090             String command = "";
00091             String user = "";
00092             int index = 0;
00093
00094             if ("-p".equals(args[index]))
00095             {
00096                 password = args[index + 1];
00097                 index += 2;
00098             }
00099
00100             if ("-l".equals(args[index]))
00101             {
00102                 user = args[index + 1];
00103                 index += 2;
00104             }
00105
00106             host = args[index];
00107             index++;
00108             command = buildCmdLine(args, index);
00109
00110             JSch jsch = new JSch();
00111
00112             Session session = jsch.getSession(user, host, 22);
00113             session.setPassword(password);
00114
00115             java.util.Hashtable<String, String> config = new java.util.Hashtable<String, String>();
00116             config.put("StrictHostKeyChecking", "no");
00117             session.setConfig(config);
00118
00119
00120
00121             session.connect(3000);
00122
00123             Channel channel = session.openChannel("exec");
00124             ((ChannelExec) channel).setCommand(command);
00125             channel.setXForwarding(true);
00126
00127             channel.setInputStream(System.in);
00128
00129
00130             ((ChannelExec) channel).setErrStream(System.err);
00131
00132             InputStream in = channel.getInputStream();
00133
00134             channel.connect();
00135
00136             byte[] tmp = new byte[1024];
00137             while (true)
00138             {
00139                 while (in.available() > 0)
00140                 {
00141                     int i = in.read(tmp, 0, 1024);
00142                     if (i < 0)
00143                         break;
00144                     System.out.print(new String(tmp, 0, i));
00145                 }
00146                 if (channel.isClosed())
00147                 {
00148                     in.close();
00149
00150                     break;
00151                 }
00152                 try
00153                 {
00154                     Thread.sleep(1000);
00155                 }
00156                 catch (Exception ee)
00157                 {
00158                 }
00159             }
00160             channel.disconnect();
00161             session.disconnect();
00162
00163         }
00164         catch (Exception e)
00165         {
00166             e.printStackTrace();
00167         }
00168         System.exit(0);
00169     }
00170
00171 }
00172
