org/objectweb/proactive/core/event/RuntimeRegistrationEventProducerImpl.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.event;
00032
00033 import org.objectweb.proactive.core.runtime.ProActiveRuntime;
00034
00035
00036 public class RuntimeRegistrationEventProducerImpl extends AbstractEventProducer
00037     implements RuntimeRegistrationEventProducer {
00038     //
00039     //-------------------implements RuntimeRegistrationEventProducer------------------
00040     //
00041
00045     public void addRuntimeRegistrationEventListener(
00046         RuntimeRegistrationEventListener listener) {
00047         addListener(listener);
00048     }
00049
00053     public void removeRuntimeRegistrationEventListener(
00054         RuntimeRegistrationEventListener listener) {
00055         removeListener(listener);
00056     }
00057
00058     //
00059     //-------------------inherited methods from AbstractEventProducer------------------
00060     //
00061
00065     protected void notifyOneListener(ProActiveListener proActiveListener,
00066         ProActiveEvent event) {
00067         RuntimeRegistrationEvent runtimeRegistrationEvent = (RuntimeRegistrationEvent) event;
00068         RuntimeRegistrationEventListener runtimeRegistrationEventListener = (RuntimeRegistrationEventListener) proActiveListener;
00069
00070         //notify the listener that a registration occurs
00071         runtimeRegistrationEventListener.runtimeRegistered(runtimeRegistrationEvent);
00072     }
00073
00074     //
00075     //-------------------PROTECTED METHODS------------------
00076     //
00077     protected void notifyListeners(ProActiveRuntime proActiveRuntime, int type,
00078         ProActiveRuntime registeredRuntime, String creatorID, String protocol,
00079         String vmName) {
00080         if (hasListeners()) {
00081             notifyAllListeners(new RuntimeRegistrationEvent(proActiveRuntime,
00082                     type, registeredRuntime, creatorID, protocol, vmName));
00083         } else {
00084             if (logger.isDebugEnabled()) {
00085                 logger.debug("no listener");
00086             }
00087         }
00088     }
00089 }
Generated on Mon Jan 22 15:16:07 2007 for ProActive by  doxygen 1.5.1
