00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.runtime;
00032
00033 import org.apache.log4j.Logger;
00034 import org.objectweb.proactive.core.Constants;
00035 import org.objectweb.proactive.core.ProActiveException;
00036 import org.objectweb.proactive.core.UniqueID;
00037 import org.objectweb.proactive.core.config.ProActiveConfiguration;
00038 import org.objectweb.proactive.core.rmi.ClassServerHelper;
00039 import org.objectweb.proactive.core.util.log.Loggers;
00040 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00041
00042
00070 public abstract class RuntimeFactory {
00071     public static Logger runtimeLogger = ProActiveLogger.getLogger(Loggers.RUNTIME);
00072
00073
00074
00075
00077     private static java.util.HashMap<String, String> protocolFactoryMapping = new java.util.HashMap<String, String>();
00078     private static java.util.HashMap<String, RuntimeFactory> instanceFactoryMapping = new java.util.HashMap<String, RuntimeFactory>();
00079
00080
00081
00082
00083
00084     static {
00085         ProActiveConfiguration.load();
00086         createClassServer();
00087         registerProtocolFactories();
00088
00089     }
00090
00091
00092
00093
00094
00102     public static synchronized void setFactory(String protocol,
00103         String factoryClassName) {
00104         if (runtimeLogger.isDebugEnabled()) {
00105             runtimeLogger.debug("protocol =  " + protocol + " " +
00106                 factoryClassName);
00107         }
00108         protocolFactoryMapping.put(protocol, factoryClassName);
00109     }
00110
00118     public static synchronized void setFactory(String protocol,
00119         RuntimeFactory factoryObject) {
00120         protocolFactoryMapping.put(protocol, factoryObject.getClass().getName());
00121         instanceFactoryMapping.put(protocol, factoryObject);
00122     }
00123
00128     public static boolean isRuntimeLocal(ProActiveRuntime proActiveRuntime) {
00129         return proActiveRuntime.getVMInformation().getVMID().equals(UniqueID.getCurrentVMID());
00130     }
00131
00138     public static synchronized ProActiveRuntime getDefaultRuntime()
00139         throws ProActiveException {
00140         ProActiveRuntime defaultRuntime = null;
00141         try {
00142
00143             defaultRuntime = getProtocolSpecificRuntime(System.getProperty(
00144                         "proactive.communication.protocol") + ":");
00145             if (runtimeLogger.isDebugEnabled()) {
00146                 runtimeLogger.debug("default runtime = " +
00147                     defaultRuntime.getURL());
00148             }
00149         } catch (ProActiveException e) {
00150
00151             if (runtimeLogger.isDebugEnabled()) {
00152                 runtimeLogger.debug("Error with the default ProActiveRuntime");
00153             }
00154             throw new ProActiveException("Error when getting the default ProActiveRuntime",
00155                 e);
00156         }
00157         return defaultRuntime;
00158     }
00159
00168     public static ProActiveRuntime getProtocolSpecificRuntime(String protocol)
00169         throws ProActiveException {
00170         RuntimeFactory factory = getFactory(protocol);
00171         ProActiveRuntime proActiveRuntime = factory.getProtocolSpecificRuntimeImpl();
00172         if (proActiveRuntime == null) {
00173             throw new ProActiveException(
00174                 "Cannot create a ProActiveRuntime based on " + protocol);
00175         }
00176         return proActiveRuntime;
00177     }
00178
00187     public static ProActiveRuntime getRuntime(String proActiveRuntimeURL,
00188         String protocol) throws ProActiveException {
00189         runtimeLogger.debug("proActiveRunTimeURL " + proActiveRuntimeURL + " " +
00190             protocol);
00191
00192
00193
00194         RuntimeFactory factory = getFactory(protocol);
00195
00196
00197         if (runtimeLogger.isDebugEnabled()) {
00198             runtimeLogger.debug("factory = " + factory);
00199         }
00200         return factory.getRemoteRuntimeImpl(proActiveRuntimeURL);
00201     }
00202
00203
00204
00205
00206
00213     protected ProActiveRuntimeAdapterImpl createRuntimeAdapter(
00214         RemoteProActiveRuntime remoteProActiveRuntime)
00215         throws ProActiveException {
00216         return new ProActiveRuntimeAdapterImpl(remoteProActiveRuntime);
00217     }
00218
00226     protected abstract ProActiveRuntime getProtocolSpecificRuntimeImpl()
00227         throws ProActiveException;
00228
00232     protected abstract ProActiveRuntime getRemoteRuntimeImpl(String s)
00233         throws ProActiveException;
00234
00240     protected abstract ProActiveRuntimeAdapterImpl createRuntimeAdapter()
00241         throws ProActiveException;
00242
00243
00244
00245
00246     private static void createClassServer() {
00247         try {
00248             new ClassServerHelper().initializeClassServer();
00249         } catch (Exception e) {
00250             if (runtimeLogger.isInfoEnabled()) {
00251                 runtimeLogger.info("Error with the ClassServer : " +
00252                     e.getMessage());
00253             }
00254         }
00255     }
00256
00257     private static void registerProtocolFactories() {
00258         setFactory(Constants.JINI_PROTOCOL_IDENTIFIER,
00259             "org.objectweb.proactive.core.runtime.jini.JiniRuntimeFactory");
00260
00261         setFactory(Constants.IBIS_PROTOCOL_IDENTIFIER,
00262             "org.objectweb.proactive.core.runtime.ibis.IbisRuntimeFactory");
00263
00264         setFactory(Constants.XMLHTTP_PROTOCOL_IDENTIFIER,
00265             "org.objectweb.proactive.core.runtime.http.HttpRuntimeFactory");
00266
00267         setFactory(Constants.RMISSH_PROTOCOL_IDENTIFIER,
00268             "org.objectweb.proactive.core.runtime.rmi.SshRmiRuntimeFactory");
00269
00270         setFactory(Constants.RMI_PROTOCOL_IDENTIFIER,
00271             "org.objectweb.proactive.core.runtime.rmi.RmiRuntimeFactory");
00272     }
00273
00274     private static RuntimeFactory createRuntimeFactory(Class factoryClass,
00275         String protocol) throws ProActiveException {
00276         try {
00277             RuntimeFactory nf = (RuntimeFactory) factoryClass.newInstance();
00278             instanceFactoryMapping.put(protocol, nf);
00279             return nf;
00280         } catch (Exception e) {
00281             e.printStackTrace();
00282             throw new ProActiveException("Error while creating the factory " +
00283                 factoryClass.getName() + " for the protocol " + protocol);
00284         }
00285     }
00286
00287     private static RuntimeFactory createRuntimeFactory(
00288         String factoryClassName, String protocol) throws ProActiveException {
00289         Class factoryClass = null;
00290         if (runtimeLogger.isDebugEnabled()) {
00291             runtimeLogger.debug("factoryClassName " + factoryClassName);
00292         }
00293         try {
00294             factoryClass = Class.forName(factoryClassName);
00295         } catch (ClassNotFoundException e) {
00296             e.printStackTrace();
00297             throw new ProActiveException(
00298                 "Error while getting the class of the factory " +
00299                 factoryClassName + " for the protocol " + protocol);
00300         }
00301         return createRuntimeFactory(factoryClass, protocol);
00302     }
00303
00304     private static synchronized RuntimeFactory getFactory(String protocol)
00305         throws ProActiveException {
00306         if (runtimeLogger.isDebugEnabled()) {
00307             runtimeLogger.debug("protocol = " + protocol);
00308         }
00309
00310         RuntimeFactory factory = instanceFactoryMapping.get(protocol);
00311         if (factory != null) {
00312             return factory;
00313         }
00314
00315         String factoryClassName = protocolFactoryMapping.get(protocol);
00316         if (runtimeLogger.isDebugEnabled()) {
00317             runtimeLogger.debug("factoryClassName  = " + factoryClassName);
00318         }
00319         if (factoryClassName != null) {
00320             return createRuntimeFactory(factoryClassName, protocol);
00321         }
00322         throw new ProActiveException(
00323             "No RuntimeFactory is registered for the protocol " + protocol);
00324     }
00325 }
