00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.runtime.rmi; 00032 00033 import java.rmi.RemoteException; 00034 00035 import org.objectweb.proactive.core.ProActiveException; 00036 import org.objectweb.proactive.core.config.ProActiveConfiguration; 00037 import org.objectweb.proactive.core.rmi.ClassServerHelper; 00038 import org.objectweb.proactive.core.rmi.RegistryHelper; 00039 import org.objectweb.proactive.core.runtime.ProActiveRuntime; 00040 import org.objectweb.proactive.core.runtime.ProActiveRuntimeAdapterForwarderImpl; 00041 import org.objectweb.proactive.core.runtime.ProActiveRuntimeAdapterImpl; 00042 import org.objectweb.proactive.core.runtime.ProActiveRuntimeForwarder; 00043 import org.objectweb.proactive.core.runtime.RemoteProActiveRuntime; 00044 import org.objectweb.proactive.core.runtime.RuntimeFactory; 00045 import org.objectweb.proactive.core.util.UrlBuilder; 00046 00047 00048 public class RmiRuntimeFactory extends RuntimeFactory { 00049 //protected final static int MAX_RETRY = 5; 00050 //protected java.util.Random random; 00051 protected static RegistryHelper registryHelper = new RegistryHelper(); 00052 protected static ClassServerHelper classServerHelper = new ClassServerHelper(); 00053 protected static ProActiveRuntime defaultRmiRuntime = null; 00054 protected static ProActiveRuntimeForwarder defaultRmiRuntimeForwarder = null; 00055 00056 // 00057 // -- CONSTRUCTORS ----------------------------------------------- 00058 // 00059 public RmiRuntimeFactory() throws java.io.IOException { 00060 if ((System.getSecurityManager() == null) && 00061 !("false".equals(System.getProperty("proactive.securitymanager")))) { 00062 System.setSecurityManager(new java.rmi.RMISecurityManager()); 00063 } 00064 00065 //registryHelper.initializeRegistry(); 00066 } 00067 00068 // 00069 // -- PUBLIC METHODS ----------------------------------------------- 00070 // 00071 public static void setClassServerClasspath(String v) { 00072 classServerHelper.setClasspath(v); 00073 } 00074 00075 public static void setShouldCreateClassServer(boolean v) { 00076 classServerHelper.setShouldCreateClassServer(v); 00077 } 00078 00079 public static void setRegistryPortNumber(int v) { 00080 registryHelper.setRegistryPortNumber(v); 00081 } 00082 00083 public static void setShouldCreateRegistry(boolean v) { 00084 registryHelper.setShouldCreateRegistry(v); 00085 } 00086 00087 // 00088 // -- PROTECTED METHODS ----------------------------------------------- 00089 // 00090 // protected ProActiveRuntime createRemoteRuntimeImpl(String s, boolean replacePreviousBinding) throws ProActiveException { 00091 // return createRuntimeAdapter(s, replacePreviousBinding); 00092 // } 00093 protected synchronized ProActiveRuntime getProtocolSpecificRuntimeImpl() 00094 throws ProActiveException { 00095 //return createRuntimeAdapter(s,false); 00096 if (defaultRmiRuntime == null) { 00097 try { 00098 registryHelper.initializeRegistry(); 00099 } catch (RemoteException e) { 00100 e.printStackTrace(); 00101 } 00102 00103 if (ProActiveConfiguration.isForwarder()) { 00104 defaultRmiRuntime = createRuntimeAdapterForwarder(); 00105 } else { 00106 defaultRmiRuntime = createRuntimeAdapter(); 00107 } 00108 } 00109 00110 return defaultRmiRuntime; 00111 } 00112 00113 protected ProActiveRuntime getRemoteRuntimeImpl(String s) 00114 throws ProActiveException { 00115 //if (s == null) return null; 00116 try { 00117 RemoteProActiveRuntime remoteProActiveRuntime; 00118 String URL = UrlBuilder.removeProtocol(s, "rmi:"); 00119 remoteProActiveRuntime = (RemoteProActiveRuntime) java.rmi.Naming.lookup(URL); 00120 //System.out.println(remoteProActiveRuntime.getClass().getName()); 00121 return createRuntimeAdapter(remoteProActiveRuntime); 00122 } catch (java.rmi.RemoteException e) { 00123 throw new ProActiveException("Remote", e); 00124 } catch (java.rmi.NotBoundException e) { 00125 throw new ProActiveException("NotBound", e); 00126 } catch (java.net.MalformedURLException e) { 00127 throw new ProActiveException("Malformed URL:" + s, e); 00128 } 00129 } 00130 00131 protected ProActiveRuntimeAdapterImpl createRuntimeAdapter() 00132 throws ProActiveException { 00133 RmiProActiveRuntimeImpl impl; 00134 try { 00135 impl = new RmiProActiveRuntimeImpl(); 00136 } catch (java.rmi.RemoteException e) { 00137 throw new ProActiveException("Cannot create the RemoteProActiveRuntimeImpl", 00138 e); 00139 } catch (java.rmi.AlreadyBoundException e) { 00140 throw new ProActiveException("Cannot bind remoteProactiveRuntime", e); 00141 } 00142 return new ProActiveRuntimeAdapterImpl(impl); 00143 } 00144 00145 protected ProActiveRuntimeAdapterForwarderImpl createRuntimeAdapterForwarder() 00146 throws ProActiveException { 00147 RmiProActiveRuntimeForwarderImpl impl; 00148 try { 00149 impl = new RmiProActiveRuntimeForwarderImpl(); 00150 } catch (java.rmi.RemoteException e) { 00151 throw new ProActiveException("Cannot create the RemoteProActiveRuntimeImpl", 00152 e); 00153 } catch (java.rmi.AlreadyBoundException e) { 00154 throw new ProActiveException("Cannot bind remoteProactiveRuntime", e); 00155 } 00156 return new ProActiveRuntimeAdapterForwarderImpl(impl); 00157 } 00158 00159 public static RegistryHelper getRegistryHelper() { 00160 return registryHelper; 00161 } 00162 }
1.5.1
