org/objectweb/proactive/core/component/adl/Registry.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.component.adl;
00032
00033 import java.util.Hashtable;
00034 import java.util.Iterator;
00035
00036 import org.apache.log4j.Logger;
00037 import org.objectweb.fractal.adl.ADLException;
00038 import org.objectweb.fractal.api.Component;
00039 import org.objectweb.fractal.api.NoSuchInterfaceException;
00040 import org.objectweb.fractal.util.Fractal;
00041 import org.objectweb.proactive.core.group.Group;
00042 import org.objectweb.proactive.core.group.ProActiveGroup;
00043 import org.objectweb.proactive.core.util.log.Loggers;
00044 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00045
00046
00052 public class Registry {
00053     private static Logger logger = ProActiveLogger.getLogger(Loggers.COMPONENTS_ADL);
00054     static private Registry instance = null;
00055     private Hashtable table;
00056
00057     private Registry() {
00058         table = new Hashtable();
00059     }
00060
00065     static public Registry instance() {
00066         if (instance == null) {
00067             instance = new Registry();
00068         }
00069         return instance;
00070     }
00071
00075     public void addComponent(Component component) throws ADLException {
00076         if (ProActiveGroup.isGroup(component)) {
00077             Group group = ProActiveGroup.getGroup(component);
00078             Iterator it = group.iterator();
00079             while (it.hasNext()) {
00080                 addComponent((Component) it.next());
00081             }
00082         } else {
00083             try {
00084                 String name = Fractal.getNameController(component).getFcName();
00085                 if (table.containsKey(name)) {
00086                     throw new ADLException("A component with the name " + name +
00087                         " is already stored in the registry", null);
00088                 }
00089                 table.put(name, component);
00090                 if (logger.isDebugEnabled()) {
00091                     logger.debug("added component " + name +
00092                         " to the local registry");
00093                 }
00094             } catch (NoSuchInterfaceException e) {
00095                 throw new ADLException("It is not possible to register a component without a NameController controller",
00096                     null);
00097             }
00098         }
00099     }
00100
00104     public Component getComponent(String name) {
00105         return (Component) table.get(name);
00106     }
00107
00112     public void clear() {
00113         table.clear();
00114     }
00115 }
Generated on Mon Jan 22 15:16:06 2007 for ProActive by  doxygen 1.5.1
