00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.component.adl; 00032 00033 import org.objectweb.fractal.adl.ADLException; 00034 import org.objectweb.fractal.api.Component; 00035 00036 00045 public class RegistryManagerImpl implements RegistryManager { 00046 Registry registry; 00047 00048 public RegistryManagerImpl() { 00049 registry = Registry.instance(); 00050 } 00051 00052 /* (non-Javadoc) 00053 * @see org.objectweb.fractal.adl.RegistryManager#addComponent(org.objectweb.fractal.api.Component) 00054 */ 00055 public void addComponent(Component component) throws ADLException { 00056 registry.addComponent(component); 00057 } 00058 00059 /* (non-Javadoc) 00060 * @see org.objectweb.fractal.adl.RegistryManager#getComponent(java.lang.String) 00061 */ 00062 public Component getComponent(String name) { 00063 return registry.getComponent(name); 00064 } 00065 00066 /* (non-Javadoc) 00067 * @see org.objectweb.fractal.adl.RegistryManager#clear() 00068 */ 00069 public void clear() { 00070 registry.clear(); 00071 } 00072 }
 1.5.1
 1.5.1
