00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.rmi; 00032 00033 00034 import org.apache.log4j.Logger; 00035 import org.objectweb.proactive.core.util.log.Loggers; 00036 import org.objectweb.proactive.core.util.log.ProActiveLogger; 00037 00038 00039 public class RegistryHelper { 00040 static Logger logger = ProActiveLogger.getLogger(Loggers.RMI); 00041 protected final static int DEFAULT_REGISTRY_PORT = 1099; 00042 00046 protected int registryPortNumber = DEFAULT_REGISTRY_PORT; 00047 protected boolean shouldCreateRegistry = true; 00048 protected boolean registryChecked; 00049 protected static java.rmi.registry.Registry registry; 00050 00051 //following boolean is used to know which runtime has created RMI registry 00052 protected static boolean registryCreator = false; 00053 00054 // 00055 // -- Constructors ----------------------------------------------- 00056 // 00057 public RegistryHelper() { 00058 String port = System.getProperty("proactive.rmi.port"); 00059 if (port != null) { 00060 setRegistryPortNumber(new Integer(port).intValue()); 00061 } 00062 } 00063 00064 // 00065 // -- PUBLIC METHODS ----------------------------------------------- 00066 // 00067 public int getRegistryPortNumber() { 00068 return registryPortNumber; 00069 } 00070 00071 public void setRegistryPortNumber(int v) { 00072 registryPortNumber = v; 00073 registryChecked = false; 00074 } 00075 00076 public boolean shouldCreateRegistry() { 00077 return shouldCreateRegistry; 00078 } 00079 00080 public void setShouldCreateRegistry(boolean v) { 00081 shouldCreateRegistry = v; 00082 } 00083 00084 public synchronized void initializeRegistry() 00085 throws java.rmi.RemoteException { 00086 try { 00087 if (!shouldCreateRegistry) { 00088 return; // don't bother 00089 } 00090 if (registryChecked) { 00091 return; // already done for this VM 00092 } 00093 getOrCreateRegistry(registryPortNumber); 00094 registryChecked = true; 00095 } catch (Exception e) { 00096 e.printStackTrace(); 00097 } 00098 } 00099 00100 public static java.rmi.registry.Registry getRegistry() { 00101 return registry; 00102 } 00103 00104 public static boolean getRegistryCreator() { 00105 return registryCreator; 00106 } 00107 00108 // 00109 // -- PRIVATE METHODS ----------------------------------------------- 00110 // 00111 private static java.rmi.registry.Registry createRegistry(int port) 00112 throws java.rmi.RemoteException { 00113 registry = java.rmi.registry.LocateRegistry.createRegistry(port); 00114 registryCreator = true; 00115 return registry; 00116 } 00117 00118 private static java.rmi.registry.Registry detectRegistry(int port) { 00119 // java.rmi.registry.Registry registry = null; 00120 try { 00121 // whether an effective registry exists or not we should get a reference 00122 registry = java.rmi.registry.LocateRegistry.getRegistry(port); 00123 if (registry == null) { 00124 return null; 00125 } 00126 00127 // doing a lookup should produce ConnectException if registry doesn't exist 00128 // and no exception or NotBoundException if the registry does exist. 00129 java.rmi.Remote r = registry.lookup("blah!"); 00130 logger.info("Detected an existing RMI Registry on port " + port); 00131 return registry; 00132 } catch (java.rmi.NotBoundException e) { 00133 logger.info("Detected an existing RMI Registry on port " + port); 00134 return registry; 00135 } catch (java.rmi.RemoteException e) { 00136 return null; 00137 } 00138 } 00139 00140 private static java.rmi.registry.Registry getOrCreateRegistry(int port) 00141 throws java.rmi.RemoteException { 00142 registry = detectRegistry(port); 00143 if (registry != null) { 00144 return registry; 00145 } 00146 00147 // no registry created 00148 try { 00149 registry = createRegistry(port); 00150 logger.info("Created a new registry on port " + port); 00151 return registry; 00152 } catch (java.rmi.RemoteException e) { 00153 // problem to bind the registry : may be somebody created one in the meantime 00154 // try to find the rmi registry one more time 00155 registry = detectRegistry(port); 00156 if (registry != null) { 00157 return registry; 00158 } 00159 logger.error("Cannot detect an existing RMI Registry on port " + 00160 port + " nor create one e=" + e); 00161 throw e; 00162 } 00163 } 00164 }
