00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.security.crypto; 00032 00033 import java.security.*; 00034 00035 00036 public class RandomLongGenerator { 00037 private byte[] seed; 00038 private SecureRandom secureRandom; 00039 00040 public RandomLongGenerator() { 00041 secureRandom = new SecureRandom(); 00042 } 00043 00044 public long generateLong(int nbBytes) { 00045 if (nbBytes > 8) { 00046 nbBytes = 8; 00047 } 00048 00049 seed = new byte[nbBytes]; 00050 seed = secureRandom.generateSeed(nbBytes); 00051 00052 long ra2 = 0; 00053 00054 for (int i = 0; i < 4; i++) { 00055 ra2 = ra2 + 00056 ((Math.abs(new Byte(seed[i]).longValue())) * new Double(Math.pow( 00057 10, (-3 + (3 * (i + 1))))).longValue()); 00058 } 00059 00060 return ra2; 00061 } 00062 }
1.5.1
