00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.process.rsh; 00032 00033 import java.io.IOException; 00034 00035 import org.objectweb.proactive.core.process.ExternalProcess; 00036 import org.objectweb.proactive.core.process.HierarchicalProcess; 00037 import org.objectweb.proactive.core.process.JVMProcess; 00038 00039 00049 public class RSHHierarchicalProcess extends RSHProcess 00050 implements HierarchicalProcess { 00051 00053 private ExternalProcess hierarchicalProcess; 00054 00056 public void setHierarchicalProcess(ExternalProcess process) { 00057 hierarchicalProcess = process; 00058 } 00059 00061 public ExternalProcess getHierarchicalProcess() { 00062 return hierarchicalProcess; 00063 } 00064 00066 public boolean isHierarchical() { 00067 return true; 00068 } 00069 00071 public int getNodeNumber() { 00072 return hierarchicalProcess.getNodeNumber(); 00073 } 00074 00076 public void startProcess() throws IOException { 00077 // Be sure that a forwarder runtime will be launched on the forwarder host 00078 JVMProcess finalProcess = (JVMProcess) getFinalProcess(); 00079 String bClass = finalProcess.getClassname(); 00080 finalProcess.setClassname( 00081 "org.objectweb.proactive.core.runtime.StartHierarchical"); 00082 super.startProcess(); 00083 finalProcess.setClassname(bClass); 00084 } 00085 }
1.5.1
