00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.descriptor.xml; 00032 00033 import org.objectweb.proactive.core.xml.handler.BasicUnmarshaller; 00034 import org.objectweb.proactive.core.xml.io.Attributes; 00035 00036 00044 public class ProcessReferenceHandler extends BasicUnmarshaller { 00045 public ProcessReferenceHandler() { 00046 } 00047 00048 public void startContextElement(String name, Attributes attributes) 00049 throws org.xml.sax.SAXException { 00050 String refid = attributes.getValue("refid"); 00051 if (logger.isDebugEnabled()) { 00052 logger.debug("refid " + refid); 00053 } 00054 if (checkNonEmpty(refid)) { 00055 setResultObject(refid); 00056 } else { 00057 throw new org.xml.sax.SAXException( 00058 "The Id of the referenced definition cannot be set to an empty string"); 00059 } 00060 } 00061 }
1.5.1
