00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.descriptor.xml;
00032
00033 import java.util.StringTokenizer;
00034
00035 import javax.naming.directory.InvalidAttributeValueException;
00036
00037 import org.glite.wms.jdlj.*;
00038 import org.objectweb.proactive.core.ProActiveException;
00039 import org.objectweb.proactive.core.descriptor.data.ProActiveDescriptor;
00040 import org.objectweb.proactive.core.process.AbstractListProcessDecorator;
00041 import org.objectweb.proactive.core.process.DependentListProcess;
00042 import org.objectweb.proactive.core.process.ExternalProcess;
00043 import org.objectweb.proactive.core.process.ExternalProcessDecorator;
00044 import org.objectweb.proactive.core.process.HierarchicalProcess;
00045 import org.objectweb.proactive.core.process.IndependentListProcess;
00046 import org.objectweb.proactive.core.process.JVMProcess;
00047 import org.objectweb.proactive.core.process.filetransfer.FileTransferWorkShop;
00048 import org.objectweb.proactive.core.process.glite.GLiteProcess;
00049 import org.objectweb.proactive.core.process.globus.GlobusProcess;
00050 import org.objectweb.proactive.core.process.gridengine.GridEngineSubProcess;
00051 import org.objectweb.proactive.core.process.lsf.LSFBSubProcess;
00052 import org.objectweb.proactive.core.process.mpi.MPIProcess;
00053 import org.objectweb.proactive.core.process.nordugrid.NGProcess;
00054 import org.objectweb.proactive.core.process.oar.OARGRIDSubProcess;
00055 import org.objectweb.proactive.core.process.oar.OARSubProcess;
00056 import org.objectweb.proactive.core.process.pbs.PBSSubProcess;
00057 import org.objectweb.proactive.core.process.prun.PrunSubProcess;
00058 import org.objectweb.proactive.core.process.rsh.maprsh.MapRshProcess;
00059 import org.objectweb.proactive.core.process.unicore.UnicoreProcess;
00060 import org.objectweb.proactive.core.util.HostsInfos;
00061 import org.objectweb.proactive.core.xml.handler.AbstractUnmarshallerDecorator;
00062 import org.objectweb.proactive.core.xml.handler.BasicUnmarshaller;
00063 import org.objectweb.proactive.core.xml.handler.BasicUnmarshallerDecorator;
00064 import org.objectweb.proactive.core.xml.handler.CollectionUnmarshaller;
00065 import org.objectweb.proactive.core.xml.handler.PassiveCompositeUnmarshaller;
00066 import org.objectweb.proactive.core.xml.handler.SingleValueUnmarshaller;
00067 import org.objectweb.proactive.core.xml.handler.UnmarshallerHandler;
00068 import org.objectweb.proactive.core.xml.io.Attributes;
00069 import org.xml.sax.SAXException;
00070
00071
00072
00073 public class ProcessDefinitionHandler extends AbstractUnmarshallerDecorator
00074         implements ProActiveDescriptorConstants {
00075     protected String id;
00076     protected ProActiveDescriptor proActiveDescriptor;
00077     protected ExternalProcess targetProcess;
00078
00079     public ProcessDefinitionHandler(ProActiveDescriptor proActiveDescriptor) {
00080         super(false);
00081         this.proActiveDescriptor = proActiveDescriptor;
00082         this.addHandler(JVM_PROCESS_TAG,
00083                 new JVMProcessHandler(proActiveDescriptor));
00084         this.addHandler(RSH_PROCESS_TAG,
00085                 new RSHProcessHandler(proActiveDescriptor));
00086         this.addHandler(MAPRSH_PROCESS_TAG,
00087                 new MapRshProcessHandler(proActiveDescriptor));
00088         this.addHandler(SSH_PROCESS_TAG,
00089                 new SSHProcessHandler(proActiveDescriptor));
00090         this.addHandler(RLOGIN_PROCESS_TAG,
00091                 new RLoginProcessHandler(proActiveDescriptor));
00092         this.addHandler(BSUB_PROCESS_TAG,
00093                 new BSubProcessHandler(proActiveDescriptor));
00094         this.addHandler(GLOBUS_PROCESS_TAG,
00095                 new GlobusProcessHandler(proActiveDescriptor));
00096         this.addHandler(PRUN_PROCESS_TAG,
00097                 new PrunProcessHandler(proActiveDescriptor));
00098         this.addHandler(PBS_PROCESS_TAG,
00099                 new PBSProcessHandler(proActiveDescriptor));
00100         this.addHandler(GRID_ENGINE_PROCESS_TAG,
00101                 new GridEngineProcessHandler(proActiveDescriptor));
00102         this.addHandler(OAR_PROCESS_TAG,
00103                 new OARProcessHandler(proActiveDescriptor));
00104         this.addHandler(GLITE_PROCESS_TAG,
00105                 new GLiteProcessHandler(proActiveDescriptor));
00106         this.addHandler(OARGRID_PROCESS_TAG,
00107                 new OARGRIDProcessHandler(proActiveDescriptor));
00108         this.addHandler(HIERARCHICAL_PROCESS_TAG,
00109                 new HierarchicalProcessHandler(proActiveDescriptor));
00110         this.addHandler(MPI_PROCESS_TAG,
00111                 new MPIProcessHandler(proActiveDescriptor));
00112         this.addHandler(DEPENDENT_PROCESS_SEQUENCE_TAG,
00113                 new DependentProcessSequenceHandler(proActiveDescriptor));
00114         this.addHandler(SEQUENTIAL_PROCESS_TAG,
00115                 new SequentialProcessHandler(proActiveDescriptor));
00116         ProcessListHandler handler = new ProcessListHandler(proActiveDescriptor);
00117         this.addHandler(PROCESS_LIST_TAG, handler);
00118         this.addHandler(PROCESS_LIST_BYHOST_TAG, handler);
00119         this.addHandler(UNICORE_PROCESS_TAG,
00120                 new UnicoreProcessHandler(proActiveDescriptor));
00121         this.addHandler(NG_PROCESS_TAG,
00122                 new NGProcessHandler(proActiveDescriptor));
00123         this.addHandler(CLUSTERFORK_PROCESS_TAG,
00124                 new ClusterForkProcessHandler(proActiveDescriptor));
00125     }
00126
00131     protected void notifyEndActiveHandler(String name,
00132                                           UnmarshallerHandler activeHandler) throws SAXException {
00133
00134
00135
00136
00137
00138
00139
00140     }
00141
00145     public Object getResultObject() throws SAXException {
00146         ExternalProcess result = targetProcess;
00147         targetProcess = null;
00148
00149         return result;
00150     }
00151
00156     public void startContextElement(String name, Attributes attributes)
00157             throws SAXException {
00158         id = attributes.getValue("id");
00159     }
00160
00161     public class ProcessHandler extends AbstractUnmarshallerDecorator
00162             implements ProActiveDescriptorConstants {
00163         protected ProActiveDescriptor proActiveDescriptor;
00164         protected boolean isRef;
00165
00166         public ProcessHandler(ProActiveDescriptor proActiveDescriptor) {
00167             super();
00168             this.proActiveDescriptor = proActiveDescriptor;
00169             addHandler(ENVIRONMENT_TAG, new EnvironmentHandler());
00170             addHandler(PROCESS_REFERENCE_TAG, new ProcessReferenceHandler());
00171             addHandler(COMMAND_PATH_TAG, new CommandPathHanlder());
00172             addHandler(FILE_TRANSFER_DEPLOY_TAG,
00173                     new FileTransferStructureHandler("deploy"));
00174             addHandler(FILE_TRANSFER_RETRIEVE_TAG,
00175                     new FileTransferStructureHandler("retrieve"));
00176         }
00177
00178         public void startContextElement(String name, Attributes attributes)
00179                 throws org.xml.sax.SAXException {
00180             String className = attributes.getValue("class");
00181
00182             if (!checkNonEmpty(className)) {
00183                 throw new org.xml.sax.SAXException(
00184                         "Process defined without specifying the class");
00185             }
00186
00187             try {
00188                 targetProcess = proActiveDescriptor.createProcess(id, className);
00189             } catch (ProActiveException e) {
00190
00191                 throw new org.xml.sax.SAXException(e.getMessage());
00192             }
00193
00194             String closeStream = attributes.getValue("closeStream");
00195
00196             if (checkNonEmpty(closeStream) && closeStream.equals("yes")) {
00197                 targetProcess.closeStream();
00198             }
00199
00200             String hostname = attributes.getValue("hostname");
00201
00202             if (checkNonEmpty(hostname)) {
00203                 targetProcess.setHostname(hostname);
00204             }
00205
00206             String username = attributes.getValue("username");
00207
00208             if (checkNonEmpty(username)) {
00209                 targetProcess.setUsername(username);
00210             }
00211         }
00212
00213
00214
00215
00216
00217         public Object getResultObject() throws org.xml.sax.SAXException {
00218             return null;
00219         }
00220
00221
00222
00223
00224
00225         protected void notifyEndActiveHandler(String name,
00226                                               UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
00227             if (name.equals(ENVIRONMENT_TAG)) {
00228                 targetProcess.setEnvironment((String[]) activeHandler.getResultObject());
00229             } else if (name.equals(PROCESS_REFERENCE_TAG)) {
00230                 if (!(targetProcess instanceof ExternalProcessDecorator)) {
00231                     throw new org.xml.sax.SAXException(
00232                             "found a Process defined inside a non composite process");
00233                 }
00234
00235                 ExternalProcessDecorator cep = (ExternalProcessDecorator) targetProcess;
00236                 Object result = activeHandler.getResultObject();
00237                 proActiveDescriptor.registerProcess(cep, (String) result);
00238             } else if (name.equals(COMMAND_PATH_TAG)) {
00239                 targetProcess.setCommandPath((String) activeHandler.getResultObject());
00240             }
00241         }
00242
00243
00244
00245
00246
00247         protected class EnvironmentHandler extends BasicUnmarshaller {
00248             private java.util.ArrayList<String> variables;
00249
00250             public EnvironmentHandler() {
00251             }
00252
00253             public void startContextElement(String name, Attributes attributes)
00254                     throws org.xml.sax.SAXException {
00255                 variables = new java.util.ArrayList<String>();
00256             }
00257
00258             public Object getResultObject() throws org.xml.sax.SAXException {
00259                 if (variables == null) {
00260                     isResultValid = false;
00261                 } else {
00262                     int n = variables.size();
00263                     String[] result = new String[n];
00264
00265                     if (n > 0) {
00266                         variables.toArray(result);
00267                     }
00268
00269                     setResultObject(result);
00270                     variables.clear();
00271                     variables = null;
00272                 }
00273
00274                 return super.getResultObject();
00275             }
00276
00277             public void startElement(String name, Attributes attributes)
00278                     throws org.xml.sax.SAXException {
00279                 if (name.equals(VARIABLE_TAG)) {
00280                     String vName = attributes.getValue("name");
00281                     String vValue = attributes.getValue("value");
00282
00283                     if (checkNonEmpty(vName) && (vValue != null)) {
00284                         logger.info("Found environment variable name=" + vName +
00285                                 " value=" + vValue);
00286                         variables.add(vName + "=" + vValue);
00287                     }
00288                 }
00289             }
00290         }
00291
00292
00293         protected class CommandPathHanlder extends BasicUnmarshaller {
00294             public CommandPathHanlder() {
00295             }
00296
00297             public void startContextElement(String name, Attributes attributes)
00298                     throws org.xml.sax.SAXException {
00299                 String path = attributes.getValue("value");
00300
00301                 if (checkNonEmpty(path)) {
00302                     setResultObject(path);
00303                 } else {
00304                     throw new org.xml.sax.SAXException(
00305                             "The Id of the referenced definition cannot be set to an empty string");
00306                 }
00307             }
00308         }
00309
00310         protected class FileTransferStructureHandler
00311                 extends PassiveCompositeUnmarshaller {
00312
00313
00314
00315
00316
00317
00318             protected String fileTransferQueue;
00319             protected FileTransferWorkShop fileTransferStructure;
00320
00321             public FileTransferStructureHandler(String queue) {
00322                 super();
00323                 fileTransferQueue = queue;
00324                 fileTransferStructure = null;
00325
00326                 addHandler(FILE_TRANSFER_COPY_PROTOCOL_TAG,
00327                         new SingleValueUnmarshaller());
00328                 addHandler(FILE_TRANSFER_SRC_INFO_TAG,
00329                         new InfoAttributeHandler());
00330                 addHandler(FILE_TRANSFER_DST_INFO_TAG,
00331                         new InfoAttributeHandler());
00332             }
00333
00334             protected void notifyEndActiveHandler(String name,
00335                                                   UnmarshallerHandler activeHandler)
00336                     throws org.xml.sax.SAXException {
00337                 if (name.equals(FILE_TRANSFER_COPY_PROTOCOL_TAG)) {
00338                     fileTransferStructure.setFileTransferCopyProtocol((String) activeHandler.getResultObject());
00339                 }
00340             }
00341
00342             public void startContextElement(String name, Attributes attributes)
00343                     throws org.xml.sax.SAXException {
00344                 if (fileTransferQueue.equalsIgnoreCase("deploy")) {
00345                     fileTransferStructure = targetProcess.getFileTransferWorkShopDeploy();
00346                 } else {
00347                     fileTransferStructure = targetProcess.getFileTransferWorkShopRetrieve();
00348                 }
00349
00350                 String ftRefId = attributes.getValue("refid");
00351                 if (!checkNonEmpty(ftRefId)) {
00352                     throw new org.xml.sax.SAXException(name +
00353                             " defined without 'refid' attribute");
00354                 }
00355
00356                 if (ftRefId.equalsIgnoreCase(FILE_TRANSFER_IMPLICT_KEYWORD)) {
00357                     fileTransferStructure.setImplicit(true);
00358                 } else {
00359                     fileTransferStructure.setImplicit(false);
00360                     fileTransferStructure.addFileTransfer(proActiveDescriptor.getFileTransfer(
00361                             ftRefId));
00362                 }
00363             }
00364
00365             protected class InfoAttributeHandler extends BasicUnmarshaller {
00366                 public void startContextElement(String name,
00367                                                 Attributes attributes) throws org.xml.sax.SAXException {
00368                     String[] parameter = {
00369                             "prefix", "hostname", "username", "password"
00370                     };
00371
00372                     for (int i = 0; i < parameter.length; i++) {
00373                         String value = attributes.getValue(parameter[i]);
00374
00375                         if (checkNonEmpty(value)) {
00376                             if (name.equals(FILE_TRANSFER_SRC_INFO_TAG)) {
00377                                 fileTransferStructure.setFileTransferStructureSrcInfo(parameter[i],
00378                                         value);
00379                             } else if (name.equals(FILE_TRANSFER_DST_INFO_TAG)) {
00380                                 fileTransferStructure.setFileTransferStructureDstInfo(parameter[i],
00381                                         value);
00382                             } else {
00383                                 System.err.println(
00384                                         "Error skipping unknown tag name:" + name);
00385                             }
00386                         }
00387                     }
00388                 }
00389             }
00390         }
00391     }
00392
00393     public class ProcessListHandler extends ProcessHandler
00394             implements ProActiveDescriptorConstants {
00395         public ProcessListHandler(ProActiveDescriptor proActiveDescriptor) {
00396             super(proActiveDescriptor);
00397         }
00398
00399         public void startContextElement(String name, Attributes attributes)
00400                 throws org.xml.sax.SAXException {
00401             int padding = 0;
00402             int repeat = 1;
00403             String className = attributes.getValue("class");
00404
00405             if (!checkNonEmpty(className)) {
00406                 throw new org.xml.sax.SAXException(
00407                         "Process defined without specifying the class");
00408             }
00409
00410             try {
00411                 targetProcess = proActiveDescriptor.createProcess(id, className);
00412             } catch (ProActiveException e) {
00413
00414                 throw new org.xml.sax.SAXException(e.getMessage());
00415             }
00416
00417             String closeStream = attributes.getValue("closeStream");
00418
00419             String fixedName = attributes.getValue("fixedName");
00420             String list = attributes.getValue("list");
00421             String domain = attributes.getValue("domain");
00422             String spadding = attributes.getValue("padding");
00423             String hostlist = attributes.getValue("hostlist");
00424             String srepeat = attributes.getValue("repeat");
00425
00426             if (checkNonEmpty(spadding)) {
00427                 padding = Integer.parseInt(spadding);
00428             }
00429
00430             if (checkNonEmpty(srepeat)) {
00431                 repeat = Integer.parseInt(srepeat);
00432             }
00433
00434             if (checkNonEmpty(fixedName) && checkNonEmpty(list)) {
00435                 ((AbstractListProcessDecorator) targetProcess).setHostConfig(fixedName,
00436                         list, domain, padding, repeat);
00437             }
00438
00439             if (checkNonEmpty(hostlist)) {
00440                 ((AbstractListProcessDecorator) targetProcess).setHostList(hostlist,
00441                         domain);
00442             }
00443
00444             if (checkNonEmpty(closeStream) && closeStream.equals("yes")) {
00445                 targetProcess.closeStream();
00446             }
00447
00448             String username = attributes.getValue("username");
00449
00450             if (checkNonEmpty(username)) {
00451                 targetProcess.setUsername(username);
00452             }
00453         }
00454     }
00455
00456
00457     protected class PrunProcessHandler extends ProcessHandler {
00458         public PrunProcessHandler(ProActiveDescriptor proActiveDescriptor) {
00459             super(proActiveDescriptor);
00460             this.addHandler(PRUN_OPTIONS_TAG, new PrunOptionHandler());
00461
00462
00463         }
00464
00465         public void startContextElement(String name, Attributes attributes)
00466                 throws org.xml.sax.SAXException {
00467             super.startContextElement(name, attributes);
00468
00469             String queueName = (attributes.getValue("queue"));
00470
00471             if (checkNonEmpty(queueName)) {
00472                 ((PrunSubProcess) targetProcess).setQueueName(queueName);
00473             }
00474         }
00475
00476         protected class PrunOptionHandler extends PassiveCompositeUnmarshaller {
00477
00478
00479
00480             public PrunOptionHandler() {
00481
00482
00483                 UnmarshallerHandler pathHandler = new PathHandler();
00484                 this.addHandler(HOST_LIST_TAG, new SingleValueUnmarshaller());
00485                 this.addHandler(HOSTS_NUMBER_TAG, new SingleValueUnmarshaller());
00486                 this.addHandler(PROCESSOR_PER_NODE_TAG,
00487                         new SingleValueUnmarshaller());
00488                 this.addHandler(BOOKING_DURATION_TAG,
00489                         new SingleValueUnmarshaller());
00490                 this.addHandler(OUTPUT_FILE, new SingleValueUnmarshaller());
00491
00492                 BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
00493                 bch.addHandler(ABS_PATH_TAG, pathHandler);
00494                 bch.addHandler(REL_PATH_TAG, pathHandler);
00495
00496
00497             }
00498
00499             public void startContextElement(String name, Attributes attributes)
00500                     throws org.xml.sax.SAXException {
00501             }
00502
00503             protected void notifyEndActiveHandler(String name,
00504                                                   UnmarshallerHandler activeHandler)
00505                     throws org.xml.sax.SAXException {
00506
00507
00508                 PrunSubProcess prunSubProcess = (PrunSubProcess) targetProcess;
00509
00510
00511                 if (name.equals(HOST_LIST_TAG)) {
00512                     prunSubProcess.setHostList((String) activeHandler.getResultObject());
00513                 } else if (name.equals(HOSTS_NUMBER_TAG)) {
00514                     prunSubProcess.setHostsNumber((String) activeHandler.getResultObject());
00515                 } else if (name.equals(PROCESSOR_PER_NODE_TAG)) {
00516                     prunSubProcess.setProcessorPerNodeNumber((String) activeHandler.getResultObject());
00517
00518
00519
00520
00521
00522                 } else if (name.equals(BOOKING_DURATION_TAG)) {
00523                     prunSubProcess.setBookingDuration((String) activeHandler.getResultObject());
00524                 } else if (name.equals(OUTPUT_FILE)) {
00525                     prunSubProcess.setOutputFile((String) activeHandler.getResultObject());
00526                 } else {
00527                     super.notifyEndActiveHandler(name, activeHandler);
00528                 }
00529             }
00530         }
00531     }
00532
00533     protected class PBSProcessHandler extends ProcessHandler {
00534         public PBSProcessHandler(ProActiveDescriptor proActiveDescriptor) {
00535             super(proActiveDescriptor);
00536             this.addHandler(PBS_OPTIONS_TAG, new PBSOptionHandler());
00537         }
00538
00539         public void startContextElement(String name, Attributes attributes)
00540                 throws org.xml.sax.SAXException {
00541             super.startContextElement(name, attributes);
00542
00543             String interactive = (attributes.getValue("interactive"));
00544
00545             if (checkNonEmpty(interactive)) {
00546                 ((PBSSubProcess) targetProcess).setInteractive(interactive);
00547             }
00548
00549             String queueName = (attributes.getValue("queue"));
00550
00551             if (checkNonEmpty(queueName)) {
00552                 ((PBSSubProcess) targetProcess).setQueueName(queueName);
00553             }
00554         }
00555
00556         protected class PBSOptionHandler extends PassiveCompositeUnmarshaller {
00557             public PBSOptionHandler() {
00558                 UnmarshallerHandler pathHandler = new PathHandler();
00559                 this.addHandler(HOST_LIST_TAG, new SingleValueUnmarshaller());
00560                 this.addHandler(HOSTS_NUMBER_TAG, new SingleValueUnmarshaller());
00561                 this.addHandler(PROCESSOR_PER_NODE_TAG,
00562                         new SingleValueUnmarshaller());
00563                 this.addHandler(BOOKING_DURATION_TAG,
00564                         new SingleValueUnmarshaller());
00565                 this.addHandler(OUTPUT_FILE, new SingleValueUnmarshaller());
00566
00567                 BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
00568                 bch.addHandler(ABS_PATH_TAG, pathHandler);
00569                 bch.addHandler(REL_PATH_TAG, pathHandler);
00570                 this.addHandler(SCRIPT_PATH_TAG, bch);
00571             }
00572
00573             public void startContextElement(String name, Attributes attributes)
00574                     throws org.xml.sax.SAXException {
00575             }
00576
00577             protected void notifyEndActiveHandler(String name,
00578                                                   UnmarshallerHandler activeHandler)
00579                     throws org.xml.sax.SAXException {
00580                 PBSSubProcess pbsSubProcess = (PBSSubProcess) targetProcess;
00581
00582                 if (name.equals(HOST_LIST_TAG)) {
00583                     pbsSubProcess.setHostList((String) activeHandler.getResultObject());
00584                 } else if (name.equals(HOSTS_NUMBER_TAG)) {
00585                     pbsSubProcess.setHostsNumber((String) activeHandler.getResultObject());
00586                 } else if (name.equals(PROCESSOR_PER_NODE_TAG)) {
00587                     pbsSubProcess.setProcessorPerNodeNumber((String) activeHandler.getResultObject());
00588                 } else if (name.equals(SCRIPT_PATH_TAG)) {
00589                     pbsSubProcess.setScriptLocation((String) activeHandler.getResultObject());
00590                 } else if (name.equals(BOOKING_DURATION_TAG)) {
00591                     pbsSubProcess.setBookingDuration((String) activeHandler.getResultObject());
00592                 } else if (name.equals(OUTPUT_FILE)) {
00593                     pbsSubProcess.setOutputFile((String) activeHandler.getResultObject());
00594                 } else {
00595                     super.notifyEndActiveHandler(name, activeHandler);
00596                 }
00597             }
00598         }
00599     }
00600
00601     protected class GridEngineProcessHandler extends ProcessHandler {
00602         public GridEngineProcessHandler(ProActiveDescriptor proActiveDescriptor) {
00603             super(proActiveDescriptor);
00604             this.addHandler(GRID_ENGINE_OPTIONS_TAG,
00605                     new GridEngineOptionHandler());
00606         }
00607
00608         public void startContextElement(String name, Attributes attributes)
00609                 throws org.xml.sax.SAXException {
00610             super.startContextElement(name, attributes);
00611
00612             String queueName = (attributes.getValue("queue"));
00613             if (checkNonEmpty(queueName)) {
00614                 ((GridEngineSubProcess) targetProcess).setQueueName(queueName);
00615             }
00616         }
00617
00618         protected class GridEngineOptionHandler
00619                 extends PassiveCompositeUnmarshaller {
00620             public GridEngineOptionHandler() {
00621                 UnmarshallerHandler pathHandler = new PathHandler();
00622                 this.addHandler(HOST_LIST_TAG, new SingleValueUnmarshaller());
00623                 this.addHandler(HOSTS_NUMBER_TAG, new SingleValueUnmarshaller());
00624                 this.addHandler(PARALLEL_ENVIRONMENT_TAG,
00625                         new SingleValueUnmarshaller());
00626
00627
00628
00629                 this.addHandler(BOOKING_DURATION_TAG,
00630                         new SingleValueUnmarshaller());
00631
00632
00633
00634                 BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
00635                 bch.addHandler(ABS_PATH_TAG, pathHandler);
00636                 bch.addHandler(REL_PATH_TAG, pathHandler);
00637                 this.addHandler(SCRIPT_PATH_TAG, bch);
00638             }
00639
00640             public void startContextElement(String name, Attributes attributes)
00641                     throws org.xml.sax.SAXException {
00642             }
00643
00644             protected void notifyEndActiveHandler(String name,
00645                                                   UnmarshallerHandler activeHandler)
00646                     throws org.xml.sax.SAXException {
00647                 GridEngineSubProcess geSubProcess = (GridEngineSubProcess) targetProcess;
00648
00649                 if (name.equals(HOST_LIST_TAG)) {
00650                     geSubProcess.setHostList((String) activeHandler.getResultObject());
00651                 } else if (name.equals(HOSTS_NUMBER_TAG)) {
00652                     geSubProcess.setHostsNumber((String) activeHandler.getResultObject());
00653                 } else if (name.equals(PARALLEL_ENVIRONMENT_TAG)) {
00654                     geSubProcess.setParallelEnvironment((String) activeHandler.getResultObject());
00655                 } else if (name.equals(SCRIPT_PATH_TAG)) {
00656                     geSubProcess.setScriptLocation((String) activeHandler.getResultObject());
00657                 } else if (name.equals(BOOKING_DURATION_TAG)) {
00658                     geSubProcess.setBookingDuration((String) activeHandler.getResultObject());
00659                 } else {
00660                     super.notifyEndActiveHandler(name, activeHandler);
00661                 }
00662             }
00663         }
00664     }
00665
00666     protected class ClusterForkProcessHandler extends ProcessHandler {
00667         public ClusterForkProcessHandler(
00668                 ProActiveDescriptor proActiveDescriptor) {
00669             super(proActiveDescriptor);
00670         }
00671
00672         public void startContextElement(String name, Attributes attributes)
00673                 throws SAXException {
00674             super.startContextElement(name, attributes);
00675         }
00676     }
00677
00678     protected class OARProcessHandler extends ProcessHandler {
00679         public OARProcessHandler(ProActiveDescriptor proActiveDescriptor) {
00680             super(proActiveDescriptor);
00681             this.addHandler(OAR_OPTIONS_TAG, new OAROptionHandler());
00682         }
00683
00684         public void startContextElement(String name, Attributes attributes)
00685                 throws org.xml.sax.SAXException {
00686             super.startContextElement(name, attributes);
00687
00688             String interactive = (attributes.getValue("interactive"));
00689
00690             if (checkNonEmpty(interactive)) {
00691                 ((OARSubProcess) targetProcess).setInteractive(interactive);
00692             }
00693
00694             String queueName = (attributes.getValue("queue"));
00695
00696             if (checkNonEmpty(queueName)) {
00697                 ((OARSubProcess) targetProcess).setQueueName(queueName);
00698             }
00699
00700             String accessProtocol = (attributes.getValue("bookedNodesAccess"));
00701
00702             if (checkNonEmpty(accessProtocol)) {
00703                 ((OARSubProcess) targetProcess).setAccessProtocol(accessProtocol);
00704             }
00705         }
00706
00707         protected class OAROptionHandler extends PassiveCompositeUnmarshaller {
00708             public OAROptionHandler() {
00709                 UnmarshallerHandler pathHandler = new PathHandler();
00710
00711
00712
00713
00714                 this.addHandler(OAR_RESOURCE_TAG, new SingleValueUnmarshaller());
00715
00716                 BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
00717                 bch.addHandler(ABS_PATH_TAG, pathHandler);
00718                 bch.addHandler(REL_PATH_TAG, pathHandler);
00719                 this.addHandler(SCRIPT_PATH_TAG, bch);
00720             }
00721
00722             public void startContextElement(String name, Attributes attributes)
00723                     throws org.xml.sax.SAXException {
00724             }
00725
00726             protected void notifyEndActiveHandler(String name,
00727                                                   UnmarshallerHandler activeHandler)
00728                     throws org.xml.sax.SAXException {
00729                 OARSubProcess oarSubProcess = (OARSubProcess) targetProcess;
00730
00731                 if (name.equals(OAR_RESOURCE_TAG)) {
00732                     oarSubProcess.setResources((String) activeHandler.getResultObject());
00733                 }
00734
00735
00736
00737
00738
00739                 else if (name.equals(SCRIPT_PATH_TAG)) {
00740                     oarSubProcess.setScriptLocation((String) activeHandler.getResultObject());
00741                 } else {
00742                     super.notifyEndActiveHandler(name, activeHandler);
00743                 }
00744             }
00745         }
00746     }
00747
00748     protected class OARGRIDProcessHandler extends ProcessHandler {
00749         public OARGRIDProcessHandler(ProActiveDescriptor proActiveDescriptor) {
00750             super(proActiveDescriptor);
00751             this.addHandler(OARGRID_OPTIONS_TAG, new OARGRIDOptionHandler());
00752         }
00753
00754         public void startContextElement(String name, Attributes attributes)
00755                 throws org.xml.sax.SAXException {
00756             super.startContextElement(name, attributes);
00757
00758             String queueName = (attributes.getValue("queue"));
00759
00760             if (checkNonEmpty(queueName)) {
00761                 ((OARGRIDSubProcess) targetProcess).setQueueName(queueName);
00762             }
00763
00764             String accessProtocol = (attributes.getValue("bookedNodesAccess"));
00765
00766             if (checkNonEmpty(accessProtocol)) {
00767                 ((OARGRIDSubProcess) targetProcess).setAccessProtocol(accessProtocol);
00768             }
00769         }
00770
00771         protected class OARGRIDOptionHandler
00772                 extends PassiveCompositeUnmarshaller {
00773             public OARGRIDOptionHandler() {
00774                 UnmarshallerHandler pathHandler = new PathHandler();
00775
00776                 this.addHandler(OAR_RESOURCE_TAG, new SingleValueUnmarshaller());
00777                 this.addHandler(OARGRID_WALLTIME_TAG,
00778                         new SingleValueUnmarshaller());
00779
00780                 BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
00781                 bch.addHandler(ABS_PATH_TAG, pathHandler);
00782                 bch.addHandler(REL_PATH_TAG, pathHandler);
00783                 this.addHandler(SCRIPT_PATH_TAG, bch);
00784             }
00785
00786             public void startContextElement(String name, Attributes attributes)
00787                     throws org.xml.sax.SAXException {
00788             }
00789
00790             protected void notifyEndActiveHandler(String name,
00791                                                   UnmarshallerHandler activeHandler)
00792                     throws org.xml.sax.SAXException {
00793                 OARGRIDSubProcess oarGridSubProcess = (OARGRIDSubProcess) targetProcess;
00794
00795                 if (name.equals(OAR_RESOURCE_TAG)) {
00796                     oarGridSubProcess.setResources((String) activeHandler.getResultObject());
00797                 } else if (name.equals(OARGRID_WALLTIME_TAG)) {
00798                     oarGridSubProcess.setWallTime((String) activeHandler.getResultObject());
00799                 } else if (name.equals(SCRIPT_PATH_TAG)) {
00800                     oarGridSubProcess.setScriptLocation((String) activeHandler.getResultObject());
00801                 } else {
00802                     super.notifyEndActiveHandler(name, activeHandler);
00803                 }
00804             }
00805         }
00806     }
00807
00808     protected class HierarchicalProcessHandler extends ProcessHandler {
00809         public HierarchicalProcessHandler(
00810                 ProActiveDescriptor proActiveDescriptor) {
00811             super(proActiveDescriptor);
00812             addHandler(HIERARCHICIAL_REFERENCE_TAG,
00813                     new ProcessReferenceHandler());
00814         }
00815
00816         protected void notifyEndActiveHandler(String name,
00817                                               UnmarshallerHandler activeHandler) throws SAXException {
00818             if (name.equals(HIERARCHICIAL_REFERENCE_TAG)) {
00819                 if (!(targetProcess instanceof HierarchicalProcess)) {
00820                     throw new org.xml.sax.SAXException(
00821                             "found a hierarchical reference inside a non hierarchical process");
00822                 }
00823
00824                 HierarchicalProcess hp = (HierarchicalProcess) targetProcess;
00825                 Object result = activeHandler.getResultObject();
00826                 proActiveDescriptor.registerHierarchicalProcess(hp,
00827                         (String) result);
00828             } else {
00829                 super.notifyEndActiveHandler(name, activeHandler);
00830             }
00831         }
00832
00833         public void startContextElement(String name, Attributes attributes)
00834                 throws org.xml.sax.SAXException {
00835             String hostname = attributes.getValue("hostname");
00836             String internal_ip = attributes.getValue("internal_ip");
00837
00838             if (checkNonEmpty(internal_ip) && checkNonEmpty(hostname)) {
00839                 HostsInfos.setSecondaryName(internal_ip, hostname);
00840             }
00841
00842             super.startContextElement(name, attributes);
00843         }
00844     }
00845
00846     protected class JVMProcessHandler extends ProcessHandler {
00847         public JVMProcessHandler(ProActiveDescriptor proActiveDescriptor) {
00848             super(proActiveDescriptor);
00849
00850             UnmarshallerHandler pathHandler = new PathHandler();
00851
00852             {
00853                 CollectionUnmarshaller cu = new CollectionUnmarshaller(String.class);
00854                 cu.addHandler(ABS_PATH_TAG, pathHandler);
00855                 cu.addHandler(REL_PATH_TAG, pathHandler);
00856                 cu.addHandler(JVMPARAMETER_TAG, new SimpleValueHandler());
00857                 this.addHandler(CLASSPATH_TAG, cu);
00858                 this.addHandler(BOOT_CLASSPATH_TAG, cu);
00859                 this.addHandler(JVMPARAMETERS_TAG, cu);
00860             }
00861
00862             BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
00863             bch.addHandler(ABS_PATH_TAG, pathHandler);
00864             bch.addHandler(REL_PATH_TAG, pathHandler);
00865             bch.addHandler(JVMPARAMETER_TAG, new BasicUnmarshaller());
00866
00867
00868             this.addHandler(JAVA_PATH_TAG, bch);
00869             this.addHandler(POLICY_FILE_TAG, bch);
00870             this.addHandler(LOG4J_FILE_TAG, bch);
00871             this.addHandler(PROACTIVE_PROPS_FILE_TAG, bch);
00872             this.addHandler(CLASSNAME_TAG, new SingleValueUnmarshaller());
00873             this.addHandler(PARAMETERS_TAG, new SingleValueUnmarshaller());
00874             this.addHandler(EXTENDED_JVM_TAG, new ExtendedJVMHandler());
00875
00876
00877
00878         }
00879
00880
00881
00882
00883
00884
00885
00886
00887
00888         protected void notifyEndActiveHandler(String name,
00889                                               UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
00890
00891
00892
00893             JVMProcess jvmProcess = (JVMProcess) targetProcess;
00894
00895             if (name.equals(CLASSPATH_TAG)) {
00896                 String[] paths = (String[]) activeHandler.getResultObject();
00897
00898                 if (paths.length > 0) {
00899                     StringBuffer sb = new StringBuffer();
00900                     String pathSeparator = System.getProperty("path.separator");
00901                     sb.append(paths[0].trim());
00902
00903
00904
00905                     for (int i = 1; i < paths.length; i++) {
00906                         sb.append(pathSeparator);
00907                         sb.append(paths[i].trim());
00908                     }
00909
00910                     jvmProcess.setClasspath(sb.toString());
00911                 }
00912             } else if (name.equals(BOOT_CLASSPATH_TAG)) {
00913                 String[] paths = (String[]) activeHandler.getResultObject();
00914
00915                 if (paths.length > 0) {
00916                     StringBuffer sb = new StringBuffer();
00917                     String pathSeparator = System.getProperty("path.separator");
00918                     sb.append(paths[0].trim());
00919
00920                     for (int i = 1; i < paths.length; i++) {
00921                         sb.append(pathSeparator);
00922                         sb.append(paths[i].trim());
00923                     }
00924
00925                     jvmProcess.setBootClasspath(sb.toString());
00926                 }
00927             } else if (name.equals(JVMPARAMETERS_TAG)) {
00928                 String[] paths = (String[]) activeHandler.getResultObject();
00929
00930                 if (paths.length > 0) {
00931                     StringBuffer sb = new StringBuffer();
00932
00933                     for (int i = 0; i < paths.length; i++) {
00934
00935                         sb.append(paths[i]);
00936                         sb.append(" ");
00937                     }
00938
00939                     jvmProcess.setJvmOptions(sb.toString());
00940                 }
00941             } else if (name.equals(JAVA_PATH_TAG)) {
00942                 String jp = (String) activeHandler.getResultObject();
00943                 jvmProcess.setJavaPath(jp.trim());
00944             } else if (name.equals(POLICY_FILE_TAG)) {
00945                 jvmProcess.setPolicyFile(((String) activeHandler.getResultObject()).trim());
00946             } else if (name.equals(LOG4J_FILE_TAG)) {
00947                 jvmProcess.setLog4jFile(((String) activeHandler.getResultObject()).trim());
00948             } else if (name.equals(PROACTIVE_PROPS_FILE_TAG)) {
00949                 jvmProcess.setJvmOptions("-Dproactive.configuration=" +
00950                         (String) activeHandler.getResultObject());
00951             } else if (name.equals(CLASSNAME_TAG)) {
00952                 jvmProcess.setClassname((String) activeHandler.getResultObject());
00953             } else if (name.equals(PARAMETERS_TAG)) {
00954                 jvmProcess.setParameters((String) activeHandler.getResultObject());
00955             } else if (name.equals(EXTENDED_JVM_TAG)) {
00956                 try {
00957                     proActiveDescriptor.mapToExtendedJVM((JVMProcess) targetProcess,
00958                             (String) activeHandler.getResultObject());
00959                 } catch (ProActiveException e) {
00960                     throw new SAXException(e);
00961                 }
00962             } else {
00963                 super.notifyEndActiveHandler(name, activeHandler);
00964             }
00965         }
00966
00967         protected class ExtendedJVMHandler extends ProcessReferenceHandler {
00968             public ExtendedJVMHandler() {
00969             }
00970
00971             public void startContextElement(String name, Attributes attributes)
00972                     throws org.xml.sax.SAXException {
00973                 super.startContextElement(name, attributes);
00974
00975                 String overwrite = attributes.getValue("overwriteParameters");
00976
00977                 if ((overwrite != null) && overwrite.equals("yes")) {
00978                     ((JVMProcess) targetProcess).setOverwrite(true);
00979                 }
00980             }
00981         }
00982     }
00983
00984
00985     protected class RSHProcessHandler extends ProcessHandler {
00986         public RSHProcessHandler(ProActiveDescriptor proActiveDescriptor) {
00987             super(proActiveDescriptor);
00988         }
00989     }
00990
00991
00992     protected class MapRshProcessHandler extends ProcessHandler {
00993         public MapRshProcessHandler(ProActiveDescriptor proActiveDescriptor) {
00994             super(proActiveDescriptor);
00995
00996             UnmarshallerHandler pathHandler = new PathHandler();
00997             BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
00998             bch.addHandler(ABS_PATH_TAG, pathHandler);
00999             bch.addHandler(REL_PATH_TAG, pathHandler);
01000             this.addHandler(SCRIPT_PATH_TAG, bch);
01001         }
01002
01003         public void startContextElement(String name, Attributes attributes)
01004                 throws org.xml.sax.SAXException {
01005
01006
01007
01008             super.startContextElement(name, attributes);
01009
01010             String parallelize = attributes.getValue("parallelize");
01011
01012             if (checkNonEmpty(parallelize)) {
01013                 ((MapRshProcess) targetProcess).setParallelization(
01014                         "parallelize");
01015             }
01016         }
01017
01018         protected void notifyEndActiveHandler(String name,
01019                                               UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
01020
01021             if (name.equals(SCRIPT_PATH_TAG)) {
01022                 ((MapRshProcess) targetProcess).setScriptLocation((String) activeHandler.getResultObject());
01023             } else {
01024                 super.notifyEndActiveHandler(name, activeHandler);
01025             }
01026         }
01027     }
01028
01029
01030     protected class SSHProcessHandler extends ProcessHandler {
01031         public SSHProcessHandler(ProActiveDescriptor proActiveDescriptor) {
01032             super(proActiveDescriptor);
01033         }
01034     }
01035
01036
01037     protected class RLoginProcessHandler extends ProcessHandler {
01038         public RLoginProcessHandler(ProActiveDescriptor proActiveDescriptor) {
01039             super(proActiveDescriptor);
01040         }
01041     }
01042
01043
01044     protected class BSubProcessHandler extends ProcessHandler {
01045         public BSubProcessHandler(ProActiveDescriptor proActiveDescriptor) {
01046             super(proActiveDescriptor);
01047             this.addHandler(BSUB_OPTIONS_TAG, new BsubOptionHandler());
01048         }
01049
01050         public void startContextElement(String name, Attributes attributes)
01051                 throws org.xml.sax.SAXException {
01052
01053
01054
01055             super.startContextElement(name, attributes);
01056
01057             String interactive = (attributes.getValue("interactive"));
01058
01059             if (checkNonEmpty(interactive)) {
01060                 ((LSFBSubProcess) targetProcess).setInteractive(interactive);
01061             }
01062
01063             String queueName = (attributes.getValue("queue"));
01064
01065             if (checkNonEmpty(queueName)) {
01066                 ((LSFBSubProcess) targetProcess).setQueueName(queueName);
01067             }
01068             String jobName = (attributes.getValue("jobname"));
01069
01070             if (checkNonEmpty(jobName)) {
01071                 ((LSFBSubProcess) targetProcess).setJobname(jobName);
01072             }
01073         }
01074
01075         protected class BsubOptionHandler extends PassiveCompositeUnmarshaller {
01076
01077
01078
01079             public BsubOptionHandler() {
01080
01081                 UnmarshallerHandler pathHandler = new PathHandler();
01082                 this.addHandler(HOST_LIST_TAG, new SingleValueUnmarshaller());
01083                 this.addHandler(PROCESSOR_TAG, new SingleValueUnmarshaller());
01084                 this.addHandler(RES_REQ_TAG, new SimpleValueHandler());
01085
01086                 BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
01087                 bch.addHandler(ABS_PATH_TAG, pathHandler);
01088                 bch.addHandler(REL_PATH_TAG, pathHandler);
01089                 this.addHandler(SCRIPT_PATH_TAG, bch);
01090             }
01091
01092             public void startContextElement(String name, Attributes attributes)
01093                     throws org.xml.sax.SAXException {
01094             }
01095
01096             protected void notifyEndActiveHandler(String name,
01097                                                   UnmarshallerHandler activeHandler)
01098                     throws org.xml.sax.SAXException {
01099
01100
01101                 LSFBSubProcess bSubProcess = (LSFBSubProcess) targetProcess;
01102
01103                 if (name.equals(HOST_LIST_TAG)) {
01104                     bSubProcess.setHostList((String) activeHandler.getResultObject());
01105                 } else if (name.equals(PROCESSOR_TAG)) {
01106                     bSubProcess.setProcessorNumber((String) activeHandler.getResultObject());
01107                 } else if (name.equals(RES_REQ_TAG)) {
01108                     bSubProcess.setRes_requirement((String) activeHandler.getResultObject());
01109                 } else if (name.equals(SCRIPT_PATH_TAG)) {
01110                     bSubProcess.setScriptLocation((String) activeHandler.getResultObject());
01111                 } else {
01112                     super.notifyEndActiveHandler(name, activeHandler);
01113                 }
01114             }
01115         }
01116
01117
01118     }
01119
01120
01121     protected class GlobusProcessHandler extends ProcessHandler {
01122         public GlobusProcessHandler(ProActiveDescriptor proActiveDescriptor) {
01123             super(proActiveDescriptor);
01124             this.addHandler(GLOBUS_OPTIONS_TAG, new GlobusOptionHandler());
01125         }
01126
01127         protected class GlobusOptionHandler extends PassiveCompositeUnmarshaller {
01128             public GlobusOptionHandler() {
01129                 this.addHandler(COUNT_TAG, new SingleValueUnmarshaller());
01130                 this.addHandler(GLOBUS_MAXTIME_TAG,
01131                         new SingleValueUnmarshaller());
01132                 this.addHandler(OUTPUT_FILE, new SingleValueUnmarshaller());
01133                 this.addHandler(ERROR_FILE, new SingleValueUnmarshaller());
01134             }
01135
01136             public void startContextElement(String name, Attributes attributes)
01137                     throws org.xml.sax.SAXException {
01138             }
01139
01140             protected void notifyEndActiveHandler(String name,
01141                                                   UnmarshallerHandler activeHandler)
01142                     throws org.xml.sax.SAXException {
01143
01144
01145                 GlobusProcess globusProcess = (GlobusProcess) targetProcess;
01146
01147                 if (name.equals(COUNT_TAG)) {
01148                     globusProcess.setCount((String) activeHandler.getResultObject());
01149                 } else if (name.equals(GLOBUS_MAXTIME_TAG)) {
01150                     globusProcess.setMaxTime((String) activeHandler.getResultObject());
01151                 } else if (name.equals(OUTPUT_FILE)) {
01152                     globusProcess.setStdout((String) activeHandler.getResultObject());
01153                 } else if (name.equals(ERROR_FILE)) {
01154                     globusProcess.setStderr((String) activeHandler.getResultObject());
01155                 } else {
01156                     super.notifyEndActiveHandler(name, activeHandler);
01157                 }
01158             }
01159         }
01160
01161
01162     }
01163
01164     protected class GLiteProcessHandler extends ProcessHandler {
01165         protected Object resultObject = null;
01166
01167         public GLiteProcessHandler(ProActiveDescriptor proActiveDescriptor) {
01168             super(proActiveDescriptor);
01169             UnmarshallerHandler pathHandler = new PathHandler();
01170             BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
01171             bch.addHandler(ABS_PATH_TAG, pathHandler);
01172             bch.addHandler(REL_PATH_TAG, pathHandler);
01173             this.addHandler(GLITE_CONFIG_TAG, bch);
01174             this.addHandler(GLITE_ENVIRONMENT_TAG, new SingleValueUnmarshaller());
01175             this.addHandler(GLITE_REQUIREMENTS_TAG,
01176                     new SingleValueUnmarshaller());
01177             this.addHandler(GLITE_INPUTDATA_TAG, new GLiteInputDataHandler());
01178             this.addHandler(GLITE_RANK_TAG, new SingleValueUnmarshaller());
01179             this.addHandler(GLITE_PROCESS_OPTIONS_TAG, new GLiteOptionHandler());
01180         }
01181
01182         public void setResultObject(Object obj) {
01183             try {
01184                 resultObject = obj;
01185             } catch (Exception e) {
01186                 e.printStackTrace();
01187             }
01188         }
01189
01190         public Object getResultObject() throws org.xml.sax.SAXException {
01191             setResultObject(targetProcess);
01192             return resultObject;
01193         }
01194
01195         public void startContextElement(String name, Attributes attributes)
01196                 throws org.xml.sax.SAXException {
01197             super.startContextElement(name, attributes);
01198
01199             try {
01200                 String type = (attributes.getValue("Type"));
01201                 if (checkNonEmpty(type)) {
01202                     ((GLiteProcess) targetProcess).setJobType(type);
01203                 }
01204                 String jobJobType = (attributes.getValue("jobType"));
01205                 if (checkNonEmpty(type)) {
01206                     ((GLiteProcess) targetProcess).setJobJobType(jobJobType);
01207                 }
01208                 String jdlFile = (attributes.getValue("JDLFileName"));
01209                 if (checkNonEmpty(jdlFile)) {
01210                     ((GLiteProcess) targetProcess).setFileName(jdlFile);
01211                 }
01212                 String hostname = (attributes.getValue("hostname"));
01213                 if (checkNonEmpty(hostname)) {
01214                     ((GLiteProcess) targetProcess).setNetServer(hostname);
01215                 }
01216                 String executable = (attributes.getValue("executable"));
01217                 if (checkNonEmpty(executable)) {
01218                     ((GLiteProcess) targetProcess).setJobExecutable(executable);
01219                     ((GLiteProcess) targetProcess).setCommand_path(executable);
01220                 }
01221                 String stdOutput = (attributes.getValue("stdOutput"));
01222                 if (checkNonEmpty(stdOutput)) {
01223                     ((GLiteProcess) targetProcess).setJobStdOutput(stdOutput);
01224                 }
01225                 String stdInput = (attributes.getValue("stdInput"));
01226                 if (checkNonEmpty(stdInput)) {
01227                     ((GLiteProcess) targetProcess).setJobStdInput(stdInput);
01228                 }
01229                 String stdError = (attributes.getValue("stdError"));
01230                 if (checkNonEmpty(stdError)) {
01231                     ((GLiteProcess) targetProcess).setJobStdError(stdError);
01232                 }
01233                 String outputse = (attributes.getValue("outputse"));
01234                 if (checkNonEmpty(outputse)) {
01235                     ((GLiteProcess) targetProcess).setJobOutput_se(outputse);
01236                 }
01237                 String virtualOrganisation = (attributes.getValue(
01238                         "virtualOrganisation"));
01239                 if (checkNonEmpty(virtualOrganisation)) {
01240                     ((GLiteProcess) targetProcess).setJobVO(virtualOrganisation);
01241                 }
01242                 String retryCount = (attributes.getValue("retryCount"));
01243                 if (checkNonEmpty(retryCount)) {
01244                     ((GLiteProcess) targetProcess).setJobRetryCount(retryCount);
01245                 }
01246                 String myProxyServer = (attributes.getValue("myProxyServer"));
01247                 if (checkNonEmpty(myProxyServer)) {
01248                     ((GLiteProcess) targetProcess).setJobMyProxyServer(myProxyServer);
01249                 }
01250                 String nodeNumber = (attributes.getValue("nodeNumber"));
01251                 if (checkNonEmpty(nodeNumber)) {
01252                     ((GLiteProcess) targetProcess).setJobNodeNumber(Integer.parseInt(
01253                             nodeNumber));
01254                 }
01255             } catch (IllegalArgumentException e) {
01256                 e.printStackTrace();
01257             } catch (Exception e) {
01258                 e.printStackTrace();
01259             }
01260         }
01261
01262         protected void notifyEndActiveHandler(String name,
01263                                               UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
01264             try {
01265                 if (name.equals(GLITE_CONFIG_TAG)) {
01266                     ((GLiteProcess) targetProcess).setConfigFile((String) activeHandler.getResultObject());
01267                 }
01268                 if (name.equals(GLITE_ENVIRONMENT_TAG)) {
01269                     String value = (String) activeHandler.getResultObject();
01270                     ((GLiteProcess) targetProcess).setJobEnvironment(value);
01271                 } else if (name.equals(GLITE_REQUIREMENTS_TAG)) {
01272                     String value = (String) activeHandler.getResultObject();
01273                     ((GLiteProcess) targetProcess).setJobRequirements(value);
01274                 } else if (name.equals(GLITE_RANK_TAG)) {
01275                     String value = (String) activeHandler.getResultObject();
01276                     ((GLiteProcess) targetProcess).setJobRank(value);
01277                 } else {
01278                     super.notifyEndActiveHandler(name, activeHandler);
01279                 }
01280             } catch (IllegalArgumentException e) {
01281                 e.printStackTrace();
01282             } catch (Exception e) {
01283                 e.printStackTrace();
01284             }
01285         }
01286
01287         protected class GLiteInputDataHandler
01288                 extends PassiveCompositeUnmarshaller {
01289             public GLiteInputDataHandler() {
01290                 super();
01291             }
01292
01293             public void startContextElement(String name, Attributes attributes)
01294                     throws org.xml.sax.SAXException {
01295                 super.startContextElement(name, attributes);
01296
01297                 try {
01298                     String dataAccessProtocol = (attributes.getValue(
01299                             "dataAccessProtocol"));
01300                     if (checkNonEmpty(dataAccessProtocol)) {
01301                         ((GLiteProcess) targetProcess).setJobDataAccessProtocol(dataAccessProtocol);
01302                     }
01303                     String storageIndex = (attributes.getValue("storageIndex"));
01304                     if (checkNonEmpty(storageIndex)) {
01305                         ((GLiteProcess) targetProcess).setJobStorageIndex(storageIndex);
01306                     }
01307
01308
01309
01310
01311
01312                 } catch (IllegalArgumentException e) {
01313                     e.printStackTrace();
01314                 } catch (Exception e) {
01315                     e.printStackTrace();
01316                 }
01317             }
01318
01319             protected void notifyEndActiveHandler(String name,
01320                                                   UnmarshallerHandler activeHandler)
01321                     throws org.xml.sax.SAXException {
01322             }
01323         }
01324
01325         protected class GLiteRankHandler extends PassiveCompositeUnmarshaller {
01326             public GLiteRankHandler() {
01327                 super();
01328             }
01329
01330             public void startContextElement(String name, Attributes attributes)
01331                     throws org.xml.sax.SAXException {
01332                 super.startContextElement(name, attributes);
01333
01334                 try {
01335                     String fuzzyrank = (attributes.getValue("fuzzyrank"));
01336                     if (checkNonEmpty(fuzzyrank)) {
01337                         ((GLiteProcess) targetProcess).setJobFuzzyRank(fuzzyrank);
01338                     }
01339                 } catch (IllegalArgumentException e) {
01340                     e.printStackTrace();
01341                 } catch (Exception e) {
01342                     e.printStackTrace();
01343                 }
01344             }
01345
01346             protected void notifyEndActiveHandler(String name,
01347                                                   UnmarshallerHandler activeHandler)
01348                     throws org.xml.sax.SAXException {
01349             }
01350         }
01351
01352         protected class GLiteOptionHandler extends PassiveCompositeUnmarshaller {
01353             public GLiteOptionHandler() {
01354                 UnmarshallerHandler pathHandler = new PathHandler();
01355                 BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
01356                 bch.addHandler(ABS_PATH_TAG, pathHandler);
01357                 bch.addHandler(REL_PATH_TAG, pathHandler);
01358                 this.addHandler(GLITE_PATH_TAG, bch);
01359                 this.addHandler(GLITE_CONFIG_TAG, bch);
01360                 this.addHandler(GLITE_REMOTE_PATH_TAG, bch);
01361                 this.addHandler(GLITE_INPUTSANDBOX_TAG,
01362                         new SingleValueUnmarshaller());
01363                 this.addHandler(GLITE_OUTPUTSANDBOX_TAG,
01364                         new SingleValueUnmarshaller());
01365                 this.addHandler(GLITE_ARGUMENTS_TAG,
01366                         new SingleValueUnmarshaller());
01367             }
01368
01369             public void startContextElement(String name, Attributes attributes)
01370                     throws org.xml.sax.SAXException {
01371             }
01372
01373             protected void notifyEndActiveHandler(String name,
01374                                                   UnmarshallerHandler activeHandler)
01375                     throws org.xml.sax.SAXException {
01376                 try {
01377                     if (name.equals(GLITE_PATH_TAG)) {
01378                         ((GLiteProcess) targetProcess).setFilePath((String) activeHandler.getResultObject());
01379                     } else if (name.equals(GLITE_REMOTE_PATH_TAG)) {
01380                         ((GLiteProcess) targetProcess).setRemoteFilePath((String) activeHandler.getResultObject());
01381                         ((GLiteProcess) targetProcess).setJdlRemote(true);
01382                     } else if (name.equals(GLITE_CONFIG_TAG)) {
01383                         ((GLiteProcess) targetProcess).setConfigFile((String) activeHandler.getResultObject());
01384                         ((GLiteProcess) targetProcess).setConfigFileOption(true);
01385                     } else if (name.equals(GLITE_INPUTSANDBOX_TAG)) {
01386                         String sandbox = (String) activeHandler.getResultObject();
01387                         StringTokenizer st = new StringTokenizer(sandbox);
01388                         while (st.hasMoreTokens()) {
01389                             ((GLiteProcess) targetProcess).addInputSBEntry(st.nextToken());
01390                         }
01391                     } else if (name.equals(GLITE_OUTPUTSANDBOX_TAG)) {
01392                         String sandbox = (String) activeHandler.getResultObject();
01393                         StringTokenizer st = new StringTokenizer(sandbox);
01394                         while (st.hasMoreTokens()) {
01395                             ((GLiteProcess) targetProcess).addOutputSBEntry(st.nextToken());
01396                         }
01397                     } else if (name.equals(GLITE_ARGUMENTS_TAG)) {
01398                         String value = (String) activeHandler.getResultObject();
01399                         ((GLiteProcess) targetProcess).setJobArgument(value);
01400                     } else {
01401                         super.notifyEndActiveHandler(name, activeHandler);
01402                     }
01403                 } catch (IllegalArgumentException e) {
01404                     e.printStackTrace();
01405                 } catch (Exception e) {
01406                     e.printStackTrace();
01407                 }
01408             }
01409         }
01410     }
01411
01412
01413     protected class UnicoreProcessHandler extends ProcessHandler {
01414         public UnicoreProcessHandler(ProActiveDescriptor proActiveDescriptor) {
01415             super(proActiveDescriptor);
01416             this.addHandler(UNICORE_OPTIONS_TAG, new UnicoreOptionHandler());
01417
01418             UnmarshallerHandler pathHandler = new PathHandler();
01419             BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
01420             bch.addHandler(ABS_PATH_TAG, pathHandler);
01421             bch.addHandler(REL_PATH_TAG, pathHandler);
01422             this.addHandler(UNICORE_DIR_PATH_TAG, bch);
01423
01424             pathHandler = new PathHandler();
01425             bch = new BasicUnmarshallerDecorator();
01426             bch.addHandler(ABS_PATH_TAG, pathHandler);
01427             bch.addHandler(REL_PATH_TAG, pathHandler);
01428             this.addHandler(UNICORE_KEYFILE_PATH_TAG, bch);
01429
01430             CollectionUnmarshaller cu = new CollectionUnmarshaller(String.class);
01431             cu.addHandler(ABS_PATH_TAG, pathHandler);
01432             cu.addHandler(REL_PATH_TAG, pathHandler);
01433
01434
01435         }
01436
01437         public void startContextElement(String name, Attributes attributes)
01438                 throws org.xml.sax.SAXException {
01439             super.startContextElement(name, attributes);
01440
01441             String jobName = (attributes.getValue("jobname"));
01442
01443             if (checkNonEmpty(jobName)) {
01444                 ((UnicoreProcess) targetProcess).uParam.setUsiteName(jobName);
01445             }
01446
01447             String keyPassword = (attributes.getValue("keypassword"));
01448
01449             if (checkNonEmpty(keyPassword)) {
01450                 ((UnicoreProcess) targetProcess).uParam.setKeyPassword(keyPassword);
01451             }
01452
01453             String submitJob = (attributes.getValue("submitjob"));
01454
01455             if (checkNonEmpty(submitJob)) {
01456                 ((UnicoreProcess) targetProcess).uParam.setSubmitJob(submitJob);
01457             }
01458
01459             String saveJob = (attributes.getValue("savejob"));
01460
01461             if (checkNonEmpty(saveJob)) {
01462                 ((UnicoreProcess) targetProcess).uParam.setSaveJob(saveJob);
01463             }
01464         }
01465
01466         protected void notifyEndActiveHandler(String name,
01467                                               UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
01468             if (name.equals(UNICORE_DIR_PATH_TAG)) {
01469                 ((UnicoreProcess) targetProcess).uParam.setUnicoreDir((String) activeHandler.getResultObject());
01470             } else if (name.equals(UNICORE_KEYFILE_PATH_TAG)) {
01471                 ((UnicoreProcess) targetProcess).uParam.setKeyFilePath((String) activeHandler.getResultObject());
01472             } else {
01473                 super.notifyEndActiveHandler(name, activeHandler);
01474             }
01475         }
01476
01477         protected class UnicoreOptionHandler
01478                 extends PassiveCompositeUnmarshaller {
01479             public UnicoreOptionHandler() {
01480                 this.addHandler(UNICORE_USITE_TAG, new UsiteHandler());
01481                 this.addHandler(UNICORE_VSITE_TAG, new VsiteHandler());
01482             }
01483
01484             public void startContextElement(String name, Attributes attributes)
01485                     throws org.xml.sax.SAXException {
01486             }
01487
01488
01489
01490
01491
01492
01493
01494
01495
01496
01497
01498
01499
01500
01501
01502         }
01503
01504         protected class UsiteHandler extends PassiveCompositeUnmarshaller {
01505             public UsiteHandler() {
01506             }
01507
01508             public void startContextElement(String name, Attributes attributes)
01509                     throws org.xml.sax.SAXException {
01510                 super.startContextElement(name, attributes);
01511
01512                 String usiteName = (attributes.getValue("name"));
01513
01514                 if (checkNonEmpty(usiteName)) {
01515                     ((UnicoreProcess) targetProcess).uParam.setUsiteName(usiteName);
01516                 }
01517
01518                 String type = (attributes.getValue("type"));
01519
01520                 if (checkNonEmpty(type)) {
01521                     ((UnicoreProcess) targetProcess).uParam.setUsiteType(type);
01522                 }
01523
01524                 String url = (attributes.getValue("url"));
01525
01526                 if (checkNonEmpty(url)) {
01527                     ((UnicoreProcess) targetProcess).uParam.setUsiteUrl(url);
01528                 }
01529             }
01530         }
01531
01532         protected class VsiteHandler extends PassiveCompositeUnmarshaller {
01533             public VsiteHandler() {
01534             }
01535
01536             public void startContextElement(String name, Attributes attributes)
01537                     throws org.xml.sax.SAXException {
01538                 super.startContextElement(name, attributes);
01539
01540                 String vsiteName = (attributes.getValue("name"));
01541
01542                 if (checkNonEmpty(vsiteName)) {
01543                     ((UnicoreProcess) targetProcess).uParam.setVsiteName(vsiteName);
01544                 }
01545
01546                 String nodes = (attributes.getValue("nodes"));
01547
01548                 if (checkNonEmpty(nodes)) {
01549                     ((UnicoreProcess) targetProcess).uParam.setVsiteNodes(Integer.parseInt(
01550                             nodes));
01551                 }
01552
01553                 String processors = (attributes.getValue("processors"));
01554
01555                 if (checkNonEmpty(processors)) {
01556                     ((UnicoreProcess) targetProcess).uParam.setVsiteProcessors(Integer.parseInt(
01557                             processors));
01558                 }
01559
01560                 String memory = (attributes.getValue("memory"));
01561
01562                 if (checkNonEmpty(memory)) {
01563                     ((UnicoreProcess) targetProcess).uParam.setVsiteMemory(Integer.parseInt(
01564                             memory));
01565                 }
01566
01567                 String runtime = (attributes.getValue("runtime"));
01568
01569                 if (checkNonEmpty(runtime)) {
01570                     ((UnicoreProcess) targetProcess).uParam.setVsiteRuntime(Integer.parseInt(
01571                             runtime));
01572                 }
01573
01574                 String priority = (attributes.getValue("priority"));
01575
01576                 if (checkNonEmpty(priority)) {
01577                     ((UnicoreProcess) targetProcess).uParam.setVsitePriority(priority);
01578                 }
01579             }
01580         }
01581     }
01582
01583
01584     protected class NGProcessHandler extends ProcessHandler {
01585         public NGProcessHandler(ProActiveDescriptor proActiveDescriptor) {
01586             super(proActiveDescriptor);
01587             this.addHandler(NG_OPTIONS_TAG, new NGOptionHandler());
01588         }
01589
01590         public void startContextElement(String name, Attributes attributes)
01591                 throws org.xml.sax.SAXException {
01592             super.startContextElement(name, attributes);
01593             String jobname = (attributes.getValue("jobname"));
01594             if (checkNonEmpty(jobname)) {
01595                 ((NGProcess) targetProcess).setJobname(jobname);
01596             }
01597
01598             String queueName = (attributes.getValue("queue"));
01599             if (checkNonEmpty(queueName)) {
01600                 ((NGProcess) targetProcess).setQueue(queueName);
01601             }
01602         }
01603
01604         protected class NGOptionHandler extends PassiveCompositeUnmarshaller {
01605             public NGOptionHandler() {
01606                 this.addHandler(COUNT_TAG, new SingleValueUnmarshaller());
01607                 this.addHandler(OUTPUT_FILE, new SingleValueUnmarshaller());
01608                 this.addHandler(ERROR_FILE, new SingleValueUnmarshaller());
01609                 BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
01610                 UnmarshallerHandler pathHandler = new PathHandler();
01611                 bch.addHandler(ABS_PATH_TAG, pathHandler);
01612                 bch.addHandler(REL_PATH_TAG, pathHandler);
01613                 this.addHandler(EXECUTABLE_TAG, bch);
01614             }
01615
01616             public void startContextElement(String name, Attributes attributes)
01617                     throws org.xml.sax.SAXException {
01618             }
01619
01620             protected void notifyEndActiveHandler(String name,
01621                                                   UnmarshallerHandler activeHandler)
01622                     throws org.xml.sax.SAXException {
01623
01624
01625                 NGProcess ngProcess = (NGProcess) targetProcess;
01626
01627                 if (name.equals(COUNT_TAG)) {
01628                     ngProcess.setCount((String) activeHandler.getResultObject());
01629                 } else if (name.equals(OUTPUT_FILE)) {
01630                     ngProcess.setStdout((String) activeHandler.getResultObject());
01631                 } else if (name.equals(ERROR_FILE)) {
01632                     ngProcess.setStderr((String) activeHandler.getResultObject());
01633                 } else if (name.equals(EXECUTABLE_TAG)) {
01634                     ngProcess.setExecutable((String) activeHandler.getResultObject());
01635                 } else {
01636                     super.notifyEndActiveHandler(name, activeHandler);
01637                 }
01638             }
01639         }
01640     }
01641
01642
01643     protected class MPIProcessHandler extends ProcessHandler {
01644         public MPIProcessHandler(ProActiveDescriptor proActiveDescriptor) {
01645             super(proActiveDescriptor);
01646             this.addHandler(MPI_PROCESS_OPTIONS_TAG, new MPIOptionHandler());
01647         }
01648
01649         public void startContextElement(String name, Attributes attributes)
01650                 throws org.xml.sax.SAXException {
01651             super.startContextElement(name, attributes);
01652
01653             try {
01654                 String mpiFileName = (attributes.getValue("mpiFileName"));
01655                 if (checkNonEmpty(mpiFileName)) {
01656                     ((MPIProcess) targetProcess).setMpiFileName(mpiFileName);
01657                 }
01658                 String hostsFileName = (attributes.getValue("hostsFileName"));
01659                 if (checkNonEmpty(hostsFileName)) {
01660                     ((MPIProcess) targetProcess).setHostsFileName(hostsFileName);
01661                 }
01662                 String mpiCommandOptions = (attributes.getValue(
01663                         "mpiCommandOptions"));
01664                 if (checkNonEmpty(mpiCommandOptions)) {
01665                     ((MPIProcess) targetProcess).setMpiCommandOptions(mpiCommandOptions);
01666                 }
01667             } catch (IllegalArgumentException e) {
01668                 e.printStackTrace();
01669             } catch (Exception e) {
01670                 e.printStackTrace();
01671             }
01672         }
01673
01674         protected void notifyEndActiveHandler(String name,
01675                                               UnmarshallerHandler activeHandler) throws SAXException {
01676             super.notifyEndActiveHandler(name, activeHandler);
01677         }
01678
01679         protected class MPIOptionHandler extends PassiveCompositeUnmarshaller {
01680             public MPIOptionHandler() {
01681                 UnmarshallerHandler pathHandler = new PathHandler();
01682                 BasicUnmarshallerDecorator bch = new BasicUnmarshallerDecorator();
01683                 bch.addHandler(ABS_PATH_TAG, pathHandler);
01684                 bch.addHandler(REL_PATH_TAG, pathHandler);
01685                 this.addHandler(MPI_LOCAL_PATH_TAG, bch);
01686                 this.addHandler(MPI_REMOTE_PATH_TAG, bch);
01687                 this.addHandler(PROCESS_NUMBER_TAG,
01688                         new SingleValueUnmarshaller());
01689             }
01690
01691             public void startContextElement(String name, Attributes attributes)
01692                     throws org.xml.sax.SAXException {
01693             }
01694
01695             protected void notifyEndActiveHandler(String name,
01696                                                   UnmarshallerHandler activeHandler)
01697                     throws org.xml.sax.SAXException {
01698                 try {
01699                     if (name.equals(MPI_LOCAL_PATH_TAG)) {
01700                         ((MPIProcess) targetProcess).setLocalPath((String) activeHandler.getResultObject());
01701                     } else if (name.equals(MPI_REMOTE_PATH_TAG)) {
01702                         ((MPIProcess) targetProcess).setRemotePath((String) activeHandler.getResultObject());
01703                     } else if (name.equals(PROCESS_NUMBER_TAG)) {
01704                         ((MPIProcess) targetProcess).setHostsNumber((String) activeHandler.getResultObject());
01705                     } else {
01706                         super.notifyEndActiveHandler(name, activeHandler);
01707                     }
01708                 } catch (IllegalArgumentException e) {
01709                     e.printStackTrace();
01710                 } catch (Exception e) {
01711                     e.printStackTrace();
01712                 }
01713             }
01714         }
01715     }
01716
01717
01718     public class DependentProcessSequenceHandler
01719             extends AbstractUnmarshallerDecorator
01720             implements ProActiveDescriptorConstants {
01721         protected ProActiveDescriptor proActiveDescriptor;
01722         protected boolean isRef;
01723
01724         public DependentProcessSequenceHandler(
01725                 ProActiveDescriptor proActiveDescriptor) {
01726             super();
01727             this.proActiveDescriptor = proActiveDescriptor;
01728             this.addHandler(PROCESS_REFERENCE_TAG, new ProcessReferenceHandler());
01729             this.addHandler(SERVICE_REFERENCE_TAG, new ProcessReferenceHandler());
01730         }
01731
01732         public void startContextElement(String name, Attributes attributes)
01733                 throws org.xml.sax.SAXException {
01734             String className = attributes.getValue("class");
01735
01736             if (!checkNonEmpty(className)) {
01737                 throw new org.xml.sax.SAXException(
01738                         "Process defined without specifying the class");
01739             }
01740
01741             try {
01742                 targetProcess = proActiveDescriptor.createProcess(id, className);
01743             } catch (ProActiveException e) {
01744
01745                 e.printStackTrace();
01746             }
01747         }
01748
01749
01750         public Object getResultObject() throws org.xml.sax.SAXException {
01751             return null;
01752         }
01753
01754
01755         protected void notifyEndActiveHandler(String name,
01756                                               UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
01757             if (name.equals(PROCESS_REFERENCE_TAG)) {
01758                 DependentListProcess dep = (DependentListProcess) targetProcess;
01759                 Object result = activeHandler.getResultObject();
01760                 proActiveDescriptor.addProcessToSequenceList(dep,
01761                         (String) result);
01762             }
01763             if (name.equals(SERVICE_REFERENCE_TAG)) {
01764                 DependentListProcess dep = (DependentListProcess) targetProcess;
01765                 Object result = activeHandler.getResultObject();
01766
01767                 proActiveDescriptor.addServiceToSequenceList(dep,
01768                         (String) result);
01769             }
01770         }
01771     }
01772
01773
01774     public class SequentialProcessHandler extends AbstractUnmarshallerDecorator
01775             implements ProActiveDescriptorConstants {
01776         protected ProActiveDescriptor proActiveDescriptor;
01777         protected boolean isRef;
01778
01779         public SequentialProcessHandler(ProActiveDescriptor proActiveDescriptor) {
01780             super();
01781             this.proActiveDescriptor = proActiveDescriptor;
01782             this.addHandler(PROCESS_REFERENCE_TAG, new ProcessReferenceHandler());
01783         }
01784
01785         public void startContextElement(String name, Attributes attributes)
01786                 throws org.xml.sax.SAXException {
01787             String className = attributes.getValue("class");
01788
01789             if (!checkNonEmpty(className)) {
01790                 throw new org.xml.sax.SAXException(
01791                         "Process defined without specifying the class");
01792             }
01793
01794             try {
01795                 targetProcess = proActiveDescriptor.createProcess(id, className);
01796             } catch (ProActiveException e) {
01797
01798                 e.printStackTrace();
01799             }
01800         }
01801
01802
01803         public Object getResultObject() throws org.xml.sax.SAXException {
01804             return null;
01805         }
01806
01807
01808         protected void notifyEndActiveHandler(String name,
01809                                               UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
01810             if (name.equals(PROCESS_REFERENCE_TAG)) {
01811                 IndependentListProcess dep = (IndependentListProcess) targetProcess;
01812                 Object result = activeHandler.getResultObject();
01813                 proActiveDescriptor.addProcessToSequenceList(dep,
01814                         (String) result);
01815             }
01816         }
01817     }
01818
01819
01820     private class SimpleValueHandler extends BasicUnmarshaller {
01821         public void startContextElement(String name, Attributes attributes)
01822                 throws org.xml.sax.SAXException {
01823
01824             String value = attributes.getValue("value");
01825
01826             setResultObject(value);
01827         }
01828     }
01829 }
