00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.group.spmd;
00032
00033 import java.lang.reflect.InvocationTargetException;
00034
00035 import org.objectweb.proactive.ActiveObjectCreationException;
00036 import org.objectweb.proactive.ProActive;
00037 import org.objectweb.proactive.core.body.AbstractBody;
00038 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00039 import org.objectweb.proactive.core.group.Group;
00040 import org.objectweb.proactive.core.group.ProActiveGroup;
00041 import org.objectweb.proactive.core.group.ProxyForGroup;
00042 import org.objectweb.proactive.core.mop.ClassNotReifiableException;
00043 import org.objectweb.proactive.core.node.Node;
00044 import org.objectweb.proactive.core.node.NodeException;
00045 import org.objectweb.proactive.core.node.NodeFactory;
00046
00047
00068 public class ProSPMD {
00069
00081 public static Object newSPMDGroup(String className, Object[][] params,
00082 String nodeName)
00083 throws ClassNotFoundException, ClassNotReifiableException,
00084 ActiveObjectCreationException, NodeException {
00085 Node[] nodeList = new Node[1];
00086 nodeList[0] = NodeFactory.getNode(nodeName);
00087 return ProSPMD.newSPMDGroup(className, params, nodeList);
00088 }
00089
00101 public static Object newSPMDGroup(String className, Object[][] params,
00102 String[] nodeListString)
00103 throws ClassNotFoundException, ClassNotReifiableException,
00104 ActiveObjectCreationException, NodeException {
00105 Node[] nodeList = new Node[nodeListString.length];
00106 for (int i = 0; i < nodeListString.length; i++)
00107 nodeList[i] = NodeFactory.getNode(nodeListString[i]);
00108 return ProSPMD.newSPMDGroup(className, params, nodeList);
00109 }
00110
00122 public static Object newSPMDGroup(String className, Object[][] params,
00123 Node node)
00124 throws ClassNotFoundException, ClassNotReifiableException,
00125 ActiveObjectCreationException, NodeException {
00126 Node[] nodeList = new Node[1];
00127 nodeList[0] = node;
00128 return ProSPMD.newSPMDGroup(className, params, nodeList);
00129 }
00130
00143 public static Object newSPMDGroup(String className, Object[][] params,
00144 Node[] nodeList)
00145 throws ClassNotFoundException, ClassNotReifiableException,
00146 ActiveObjectCreationException, NodeException {
00147 Object result = ProActiveGroup.newGroup(className);
00148 Group g = ProActiveGroup.getGroup(result);
00149
00150 if (params != null) {
00151 for (int i = 0; i < params.length; i++) {
00152 g.add(ProActive.newActive(className, params[i],
00153 nodeList[i % nodeList.length]));
00154 }
00155 }
00156 ((ProxyForGroup) g).setSPMDGroup(result);
00157 return result;
00158 }
00159
00172 public static Object newSPMDGroup(String className, Object[][] params,
00173 VirtualNode virtualNode)
00174 throws ClassNotFoundException, ClassNotReifiableException,
00175 ActiveObjectCreationException, NodeException {
00176 return ProSPMD.newSPMDGroup(className, params, virtualNode.getNodes());
00177 }
00178
00179
00180
00181
00182
00193 public static Object newSPMDGroupInParallel(String className,
00194 Object[][] params, String nodeName)
00195 throws ClassNotFoundException, ClassNotReifiableException,
00196 NodeException {
00197 Node[] nodeList = new Node[1];
00198 nodeList[0] = NodeFactory.getNode(nodeName);
00199 return ProSPMD.newSPMDGroupInParallel(className, params, nodeList);
00200 }
00201
00212 public static Object newSPMDGroupInParallel(String className,
00213 Object[][] params, String[] nodeListString)
00214 throws ClassNotFoundException, ClassNotReifiableException,
00215 NodeException {
00216 Node[] nodeList = new Node[nodeListString.length];
00217 for (int i = 0; i < nodeListString.length; i++)
00218 nodeList[i] = NodeFactory.getNode(nodeListString[i]);
00219 return ProSPMD.newSPMDGroupInParallel(className, params, nodeList);
00220 }
00221
00231 public static Object newSPMDGroupInParallel(String className,
00232 Object[][] params, Node node)
00233 throws ClassNotFoundException, ClassNotReifiableException {
00234 Node[] nodeList = new Node[1];
00235 nodeList[0] = node;
00236 return ProSPMD.newSPMDGroupInParallel(className, params, nodeList);
00237 }
00238
00250 public static Object newSPMDGroupInParallel(String className,
00251 Object[][] params, VirtualNode virtualNode)
00252 throws ClassNotFoundException, ClassNotReifiableException,
00253 NodeException {
00254 return ProSPMD.newSPMDGroupInParallel(className, params,
00255 virtualNode.getNodes());
00256 }
00257
00268 public static Object newSPMDGroupInParallel(String className,
00269 Object[][] params, Node[] nodeList)
00270 throws ClassNotFoundException, ClassNotReifiableException {
00271 Object result = ProActiveGroup.newGroup(className);
00272 ProxyForGroup proxy = (org.objectweb.proactive.core.group.ProxyForGroup) ProActiveGroup.getGroup(result);
00273
00274 proxy.createMemberWithMultithread(className, null, params, nodeList);
00275
00276 proxy.setSPMDGroup(result);
00277
00278 return result;
00279 }
00280
00281
00282
00283
00284
00285
00286
00287
00288
00289
00290
00291
00292
00297 public static Object getSPMDGroup() {
00298 AbstractBody body = (AbstractBody) ProActive.getBodyOnThis();
00299 return body.getSPMDGroup();
00300 }
00301
00306 public static int getMySPMDGroupSize() {
00307 return ProActiveGroup.getGroup(ProSPMD.getSPMDGroup()).size();
00308 }
00309
00314 public static int getMyRank() {
00315 return ProActiveGroup.getGroup(ProSPMD.getSPMDGroup()).indexOf(ProActive.getStubOnThis());
00316 }
00317
00322 public static void barrier(String barrierName) {
00323 ProSPMD.barrier(barrierName, ProSPMD.getSPMDGroup());
00324 }
00325
00332 public static void barrier(String barrierName, Object group) {
00333 try {
00334
00335 AbstractBody body = (AbstractBody) ProActive.getBodyOnThis();
00336 body.getProActiveSPMDGroupManager().addToBarrierTags(barrierName);
00337
00338 body.getProActiveSPMDGroupManager().setAwaitedBarrierCalls(barrierName,
00339 ProActiveGroup.size(group));
00340
00341 ProxyForGroup proxy = (ProxyForGroup) ProActiveGroup.getGroup(group);
00342 proxy.reify(new MethodCallBarrier(barrierName));
00343 } catch (InvocationTargetException e) {
00344 System.err.println(
00345 "Unable to invoke a method call to control groups");
00346 e.printStackTrace();
00347 }
00348 }
00349
00354 public static void barrier(String[] methodNames) {
00355 try {
00356 (ProActive.getStubOnThis()).getProxy().reify(new MethodCallBarrierWithMethodName(
00357 methodNames));
00358 } catch (InvocationTargetException e) {
00359 System.err.println(
00360 "Unable to invoke a method call to control groups");
00361 e.printStackTrace();
00362 } catch (Throwable e) {
00363 System.err.println(
00364 "Unable to invoke a method call to control groups");
00365 e.printStackTrace();
00366 }
00367 }
00368 }
