00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.component.adl.types; 00032 00033 import org.objectweb.fractal.adl.types.FractalTypeBuilder; 00034 import org.objectweb.proactive.core.component.type.ProActiveTypeFactory; 00035 import org.objectweb.proactive.core.component.type.ProActiveTypeFactoryImpl; 00036 00040 public class ProActiveTypeBuilder extends FractalTypeBuilder { 00041 public Object createInterfaceType(final String name, final String signature, final String role, 00042 final String contingency, final String cardinality, 00043 final Object context) throws Exception { 00044 00045 // TODO : cache already created types ? 00046 00047 boolean client = "client".equals(role); 00048 boolean optional = "optional".equals(contingency); 00049 00050 String checkedCardinality = (cardinality==null)?ProActiveTypeFactory.SINGLETON_CARDINALITY:cardinality; 00051 // TODO_M should use bootstrap type factory with extended createFcItfType method 00052 00053 return ProActiveTypeFactoryImpl.instance().createFcItfType(name, signature, client, optional, checkedCardinality); 00054 } 00055 }
 1.5.1
