org/objectweb/proactive/core/component/controller/ProActiveSuperControllerImpl.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.component.controller;
00032
00033 import java.io.Serializable;
00034
00035 import org.objectweb.fractal.api.Component;
00036 import org.objectweb.fractal.api.factory.InstantiationException;
00037 import org.objectweb.fractal.api.type.TypeFactory;
00038 import org.objectweb.proactive.core.ProActiveRuntimeException;
00039 import org.objectweb.proactive.core.component.Constants;
00040 import org.objectweb.proactive.core.component.type.ProActiveTypeFactoryImpl;
00041
00042
00048 public class ProActiveSuperControllerImpl extends AbstractProActiveController
00049     implements Serializable, ProActiveSuperController {
00050     public ProActiveSuperControllerImpl(Component owner) {
00051         super(owner);
00052     }
00053
00054     protected void setControllerItfType() {
00055         try {
00056             setItfType(ProActiveTypeFactoryImpl.instance()
00057                                                .createFcItfType(Constants.SUPER_CONTROLLER,
00058                     ProActiveSuperController.class.getName(),
00059                     TypeFactory.SERVER, TypeFactory.MANDATORY,
00060                     TypeFactory.SINGLE));
00061         } catch (InstantiationException e) {
00062             throw new ProActiveRuntimeException("cannot create controller " +
00063                 this.getClass().getName());
00064         }
00065     }
00066
00067     // the following is borrowed from the Julia implementation
00068     public Component[] fcParents;
00069
00070     public Component[] getFcSuperComponents() {
00071         if (fcParents == null) {
00072             return new Component[0];
00073         } else {
00074             return fcParents;
00075         }
00076     }
00077
00078     public void addParent(final Component parent) {
00079         int length = (fcParents == null) ? 1 : (fcParents.length + 1);
00080         Component[] parents = new Component[length];
00081         if (fcParents != null) {
00082             System.arraycopy(fcParents, 0, parents, 1, fcParents.length);
00083         }
00084         parents[0] = parent;
00085         fcParents = parents;
00086     }
00087
00088     public void removeParent(final Component parent) {
00089         int length = fcParents.length - 1;
00090         if (length == 0) {
00091             fcParents = null;
00092         } else {
00093             Component[] parents = new Component[length];
00094             int i = 0;
00095             for (int j = 0; j < fcParents.length; ++j) {
00096                 if (!fcParents[j].equals(parent)) {
00097                     parents[i++] = fcParents[j];
00098                 }
00099             }
00100             fcParents = parents;
00101         }
00102     }
00103 }
Generated on Mon Jan 22 15:16:06 2007 for ProActive by  doxygen 1.5.1
