00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.mpi.control.util;
00032
00033
00045 public class ProActiveMPIUtil {
00046     public static final int BYTE_LEN = 1;
00047     public static final int SHORT_LEN = 2;
00048     public static final int INT_LEN = 4;
00049     public static final int FLOAT_LEN = 4;
00050     public static final int LONG_LEN = 8;
00051     public static final int DOUBLE_LEN = 8;
00052
00060     public static int intToBytes(int num, byte[] bytes, int startIndex) {
00061         bytes[startIndex] = (byte) (num & 0xff);
00062         bytes[startIndex + 1] = (byte) ((num >> 8) & 0xff);
00063         bytes[startIndex + 2] = (byte) ((num >> 16) & 0xff);
00064         bytes[startIndex + 3] = (byte) ((num >> 24) & 0xff);
00065         return startIndex + 4;
00066     }
00067
00072     public static int bytesToInt(byte[] bytes, int startIndex) {
00073         return (((int) bytes[startIndex] & 0xff) |
00074         (((int) bytes[startIndex + 1] & 0xff) << 8) |
00075         (((int) bytes[startIndex + 2] & 0xff) << 16) |
00076         (((int) bytes[startIndex + 3] & 0xff) << 24));
00077     }
00078
00086     public static int floatToBytes(float fnum, byte[] bytes, int startIndex) {
00087         return intToBytes(Float.floatToIntBits(fnum), bytes, startIndex);
00088     }
00089
00094     public static float bytesToFloat(byte[] bytes, int startIndex) {
00095         return (Float.intBitsToFloat(bytesToInt(bytes, startIndex)));
00096     }
00097
00105     public static int shortToBytes(short num, byte[] bytes, int startIndex) {
00106         bytes[startIndex] = (byte) (num & 0xff);
00107         bytes[startIndex + 1] = (byte) ((num >> 8) & 0xff);
00108         return startIndex + 2;
00109     }
00110
00115     public static short bytesToShort(byte[] bytes, int startIndex) {
00116         return (short) (((int) bytes[startIndex] & 0xff) |
00117         (((int) bytes[startIndex + 1] & 0xff) << 8));
00118     }
00119
00131     public static int stringToBytes(String str, byte[] bytes, int startIndex) {
00132         byte[] temp;
00133         int len = str.length();
00134
00135         temp = str.getBytes();
00136         if (len > 255) {
00137             System.err.println(
00138                 "String has more than 255 bytes in \"stringToBytes\", it will be truncated.");
00139
00140             bytes[startIndex++] = (byte) 255;
00141             System.arraycopy(temp, 0, bytes, startIndex, 255);
00142             return startIndex + 255;
00143         } else {
00144             bytes[startIndex++] = (byte) len;
00145             System.arraycopy(temp, 0, bytes, startIndex, len);
00146             return startIndex + len;
00147         }
00148     }
00149
00157     public static String bytesToString(byte[] bytes, int startIndex) {
00158         int len = (int) (bytes[startIndex++]) & 0xff;
00159         return new String(bytes, startIndex, len);
00160     }
00161
00169     public static int longToBytes(long lnum, byte[] bytes, int startIndex) {
00170         for (int i = 0; i < 8; i++)
00171             bytes[startIndex + i] = (byte) ((lnum >> (i * 8)) & 0xff);
00172         return startIndex + 8;
00173     }
00174
00182     public static long bytesToLong(byte[] bytes, int startIndex) {
00183
00184
00185
00186         return (((long) bytes[startIndex] & 0xff) |
00187         (((long) bytes[startIndex + 1] & 0xff) << 8) |
00188         (((long) bytes[startIndex + 2] & 0xff) << 16) |
00189         (((long) bytes[startIndex + 3] & 0xff) << 24) |
00190         (((long) bytes[startIndex + 4] & 0xff) << 32) |
00191         (((long) bytes[startIndex + 5] & 0xff) << 40) |
00192         (((long) bytes[startIndex + 6] & 0xff) << 48) |
00193         (((long) bytes[startIndex + 7] & 0xff) << 56));
00194     }
00195
00203     public static int doubleToBytes(double dnum, byte[] bytes, int startIndex) {
00204         return longToBytes(Double.doubleToLongBits(dnum), bytes, startIndex);
00205     }
00206
00214     public static double bytesToDouble(byte[] bytes, int startIndex) {
00215         return Double.longBitsToDouble(bytesToLong(bytes, startIndex));
00216     }
00217 }
