00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.component.adl.implementations;
00032
00033 import org.objectweb.deployment.scheduling.component.api.FactoryProviderTask;
00034 import org.objectweb.deployment.scheduling.component.lib.AbstractInstanceProviderTask;
00035
00036 import org.objectweb.fractal.adl.ADLException;
00037 import org.objectweb.fractal.adl.Definition;
00038 import org.objectweb.fractal.adl.Node;
00039 import org.objectweb.fractal.adl.TaskMap;
00040 import org.objectweb.fractal.adl.components.Component;
00041 import org.objectweb.fractal.adl.components.ComponentContainer;
00042 import org.objectweb.fractal.adl.implementations.ControllerContainer;
00043 import org.objectweb.fractal.adl.implementations.Implementation;
00044 import org.objectweb.fractal.adl.implementations.ImplementationCompiler;
00045 import org.objectweb.fractal.adl.implementations.ImplementationContainer;
00046 import org.objectweb.fractal.adl.nodes.VirtualNodeContainer;
00047
00048 import org.objectweb.proactive.core.ProActiveRuntimeException;
00049 import org.objectweb.proactive.core.component.Constants;
00050 import org.objectweb.proactive.core.component.ContentDescription;
00051 import org.objectweb.proactive.core.component.ControllerDescription;
00052 import org.objectweb.proactive.core.component.adl.nodes.VirtualNode;
00053 import org.objectweb.proactive.core.component.type.Composite;
00054
00055 import java.util.List;
00056 import java.util.Map;
00057
00058
00062 public class ProActiveImplementationCompiler extends ImplementationCompiler {
00063 private static int counter = 0;
00064
00065 public void compile(final List path, final ComponentContainer container,
00066 final TaskMap tasks, final Map context) throws ADLException {
00067 counter++;
00068
00069 String implementation = null;
00070
00071 if (container instanceof ImplementationContainer) {
00072 ImplementationContainer ic = (ImplementationContainer) container;
00073 Implementation i = ic.getImplementation();
00074
00075 if (i != null) {
00076 implementation = i.getClassName();
00077 }
00078 }
00079
00080 String controller = null;
00081
00082 if (container instanceof ControllerContainer) {
00083 ControllerContainer cc = (ControllerContainer) container;
00084
00085 if (cc.getController() != null) {
00086 controller = cc.getController().getDescriptor();
00087 }
00088 }
00089
00090 String name = null;
00091
00092 if (container instanceof Definition) {
00093 name = ((Definition) container).getName();
00094 } else if (container instanceof Component) {
00095 name = ((Component) container).getName();
00096 }
00097
00098 String definition = null;
00099
00100 if (container instanceof Definition) {
00101 definition = name;
00102 } else {
00103 definition = (String) ((Node) container).astGetDecoration(
00104 "definition");
00105 }
00106
00107
00108 VirtualNode n = null;
00109
00110 if (container instanceof VirtualNodeContainer) {
00111 try {
00112 n = (VirtualNode) ((VirtualNodeContainer) container).getVirtualNode();
00113 } catch (ClassCastException e) {
00114 throw new ProActiveRuntimeException(
00115 "DOCTYPE definition should be the following when using ProActive : \n" +
00116 "<!DOCTYPE definition PUBLIC \"-//objectweb.org//DTD Fractal ADL 2.0//EN\" \"classpath://org/objectweb/proactive/core/component/adl/xml/proactive.dtd\">");
00117 }
00118
00119 if (n == null) {
00120
00121
00122 for (int i = path.size() - 1; i >= 0; --i) {
00123 if (path.get(i) instanceof VirtualNodeContainer) {
00124 try {
00125 n = (VirtualNode) ((VirtualNodeContainer) path.get(i)).getVirtualNode();
00126
00127 if (n != null) {
00128 break;
00129 }
00130 } catch (ClassCastException e) {
00131 throw new ProActiveRuntimeException(
00132 "DOCTYPE definition should be the following when using ProActive : \n" +
00133 "<!DOCTYPE definition PUBLIC \"-//objectweb.org//DTD Fractal ADL 2.0//EN\" \"classpath://org/objectweb/proactive/core/component/adl/xml/proactive.dtd\">");
00134 }
00135 }
00136 }
00137 }
00138 }
00139
00140 AbstractInstanceProviderTask createTask;
00141
00142 ContentDescription contentDesc = null;
00143 ControllerDescription controllerDesc = null;
00144
00145 if (implementation == null) {
00146
00147 if ("composite".equals(controller) || (controller == null)) {
00148 controllerDesc = new ControllerDescription(name,
00149 Constants.COMPOSITE);
00150 contentDesc = new ContentDescription(Composite.class.getName());
00151 } else {
00152 controllerDesc = new ControllerDescription(name,
00153 Constants.COMPOSITE,
00154 getClass().getResource(controller).getPath());
00155 }
00156 } else {
00157
00158
00159
00160
00161 contentDesc = new ContentDescription(implementation);
00162
00163 if ("primitive".equals(controller) || (controller == null)) {
00164 controllerDesc = new ControllerDescription(name,
00165 Constants.PRIMITIVE);
00166 } else {
00167
00168 controllerDesc = new ControllerDescription(name,
00169 Constants.PRIMITIVE,
00170 getClass().getResource(controller).getPath());
00171 }
00172
00173
00174 }
00175
00176 createTask = new CreateTask((ProActiveImplementationBuilder) builder,
00177 container, name, definition, controllerDesc, contentDesc, n,
00178 context);
00179
00180 FactoryProviderTask typeTask = (FactoryProviderTask) tasks.getTask("type",
00181 container);
00182 createTask.setFactoryProviderTask(typeTask);
00183
00184 tasks.addTask("create", container, createTask);
00185 }
00186
00187
00188 static class CreateTask extends AbstractInstanceProviderTask {
00189 ProActiveImplementationBuilder builder;
00190 String name;
00191 String definition;
00192 ControllerDescription controllerDesc;
00193 ContentDescription contentDesc;
00194 VirtualNode vn;
00195 Map context;
00196 ComponentContainer container;
00197
00198 public CreateTask(final ProActiveImplementationBuilder builder,
00199 final ComponentContainer container, final String name,
00200 final String definition,
00201 final ControllerDescription controllerDesc,
00202 final ContentDescription contentDesc, final VirtualNode vn,
00203 final Map context) {
00204 this.builder = builder;
00205 this.container = container;
00206 this.name = name;
00207 this.definition = definition;
00208 this.controllerDesc = controllerDesc;
00209 this.contentDesc = contentDesc;
00210 this.vn = vn;
00211 this.context = context;
00212 }
00213
00214 public void execute(final Object context) throws Exception {
00215 if (getInstance() != null) {
00216 return;
00217 }
00218
00219 Object type = getFactoryProviderTask().getFactory();
00220 Object result = builder.createComponent(type, name, definition,
00221 controllerDesc, contentDesc, vn, (Map) context);
00222 setInstance(result);
00223 }
00224
00225 public String toString() {
00226 return "T" + System.identityHashCode(this) + "[CreateTask(" + name +
00227 "," + controllerDesc + "," + contentDesc + ")]";
00228 }
00229 }
00230 }
