org/objectweb/proactive/core/body/http/ProActiveHttpMetaObjectFactory.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.body.http;
00032
00033 import org.apache.log4j.Logger;
00034 import org.objectweb.proactive.core.ProActiveException;
00035 import org.objectweb.proactive.core.ProActiveRuntimeException;
00036 import org.objectweb.proactive.core.body.ProActiveMetaObjectFactory;
00037 import org.objectweb.proactive.core.body.RemoteBodyFactory;
00038 import org.objectweb.proactive.core.body.UniversalBody;
00039 import org.objectweb.proactive.core.util.log.Loggers;
00040 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00041
00042
00043 public class ProActiveHttpMetaObjectFactory extends ProActiveMetaObjectFactory
00044     implements java.io.Serializable {
00045     protected static Logger logger = ProActiveLogger.getLogger(Loggers.MOP);
00046
00047     //
00048     // -- PROTECTED MEMBERS -----------------------------------------------
00049     //
00050     protected RemoteBodyFactory newRemoteBodyFactorySingleton() {
00051         return new RemoteHttpBodyFactoryImpl();
00052     }
00053
00054     //
00055     // -- INNER CLASSES -----------------------------------------------
00056     //
00057     protected static class RemoteHttpBodyFactoryImpl
00058         implements RemoteBodyFactory, java.io.Serializable {
00059         public UniversalBody newRemoteBody(UniversalBody body) {
00060             try {
00061                 return new HttpBodyAdapter(body);
00062             } catch (ProActiveException e) {
00063                 throw new ProActiveRuntimeException("Cannot create Remote body adapter ",
00064                     e);
00065             }
00066         }
00067     } // end inner class RemoteBodyFactoryImpl
00068 }
Generated on Mon Jan 22 15:16:05 2007 for ProActive by  doxygen 1.5.1
