org/objectweb/proactive/core/component/factory/ProActiveGenericFactory.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.component.factory;
00032
00033 import java.util.List;
00034
00035 import org.objectweb.fractal.api.Component;
00036 import org.objectweb.fractal.api.Type;
00037 import org.objectweb.fractal.api.factory.GenericFactory;
00038 import org.objectweb.fractal.api.factory.InstantiationException;
00039 import org.objectweb.proactive.core.component.ContentDescription;
00040 import org.objectweb.proactive.core.component.ControllerDescription;
00041 import org.objectweb.proactive.core.descriptor.data.VirtualNode;
00042 import org.objectweb.proactive.core.node.Node;
00043
00050 public interface ProActiveGenericFactory extends GenericFactory {
00067     Component newFcInstance(Type type, ControllerDescription controllerDesc,
00068             ContentDescription contentDesc) throws InstantiationException;
00069
00088     Component newFcInstance(Type type, ControllerDescription controllerDesc,
00089             ContentDescription contentDesc, Node node)
00090             throws InstantiationException;
00091
00114     Component newFcInstance(Type type, ControllerDescription controllerDesc,
00115             ContentDescription contentDesc, VirtualNode virtualNode)
00116             throws InstantiationException;
00117
00118
00119
00143     List<Component> newFcInstanceAsList(Type type, ControllerDescription controllerDesc,
00144             ContentDescription[] contentDesc, VirtualNode virtualNode)
00145             throws InstantiationException;
00146
00171     List<Component> newFcInstanceAsList(Type type, ControllerDescription controllerDesc,
00172             ContentDescription contentDesc, Node[] nodes)
00173             throws InstantiationException;
00174
00198     List<Component> newFcInstanceAsList(Type type, ControllerDescription controllerDesc,
00199             ContentDescription contentDesc, VirtualNode virtualNode)
00200             throws InstantiationException;
00201
00223     List<Component> newFcInstanceAsList(Type type, ControllerDescription controllerDesc,
00224             ContentDescription[] contentDesc, Node[] nodes)
00225             throws InstantiationException;
00226
00227 }
Generated on Mon Jan 22 15:16:06 2007 for ProActive by  doxygen 1.5.1
